jbright44 Posted February 27, 2018 Share Posted February 27, 2018 What USB Cables have you guys had good luck with? I still have lots of USB issues with my Helix and one thing I noticed is that when I'm connected to the PC (Mac) whenever I step on the volume pedal, the helix drops connection. We'll go through this dance where I disconnect, reconnect and restart the helix 4 or 5 times with it doing this and then it will eventually stop screwing up and work. I'm wondering if it's the cable. What USB cables have you guys had good luck with?? Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted February 27, 2018 Share Posted February 27, 2018 A USB cable is a USB cable....try another one. Marketing bull$hit will attempt to convince you that magic alloy connectors, or fancy braided coverings are "better" at moving 1's and 0's from point A to point B, but that's a load of crap...all they are is more expensive. It either works, or it doesn't. 1 Quote Link to comment Share on other sites More sharing options...
Lachdanan0121 Posted February 27, 2018 Share Posted February 27, 2018 A USB cable is a USB cable....try another one. Marketing bull$hit will attempt to convince you that magic alloy connectors, or fancy braided coverings are "better" at moving 1's and 0's from point A to point B, but all they are is more expensive. It either works, or it doesn't. Exactly, for the most part (as there may be rare exceptions) digital cables either work, or they don't. Quote Link to comment Share on other sites More sharing options...
jbuhajla Posted February 27, 2018 Share Posted February 27, 2018 Same cables as you would use to connect a printer. They are generic. Quote Link to comment Share on other sites More sharing options...
prudenjim Posted February 27, 2018 Share Posted February 27, 2018 I noticed random disconnects when I plug into a USB 3 port. When plugged into my USB 2 port, no connection issues. Quote Link to comment Share on other sites More sharing options...
nippyjun Posted February 27, 2018 Share Posted February 27, 2018 I only use mogami or monster USB cables. They are the best............. :D Quote Link to comment Share on other sites More sharing options...
soundog Posted February 27, 2018 Share Posted February 27, 2018 Something else may be going on .... maybe a bad USB connector? FYI, 1's and 0's aren't moving through a USB cable, its not digital. Larger, more conductive wires are better. Shorter lengths are better. Ferrite chokes (those lumpy things on some cables) aren't required. But for sure, a USB usually work or it doesn't, and there's no need buy snake oil cables. But check you connectors ... wiggle the end of the cable and test it. Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted February 27, 2018 Share Posted February 27, 2018 Something else may be going on .... maybe a bad USB connector? FYI, 1's and 0's aren't moving through a USB cable, its not digital... OK fine...encoded voltage changes travel along the wire. But what's being encode? 1's and 0's, no? If I'm wrong, so be it... but if not, we're splitting hairs. Either way, the data either gets there, or it doesn't. Quote Link to comment Share on other sites More sharing options...
VirtualGuitars Posted February 27, 2018 Share Posted February 27, 2018 Make sure you're using a USB 2.0 high-speed or higher certified cable. I use a 30-foot cable going to my DAW and have no problems whatsoever. Quote Link to comment Share on other sites More sharing options...
soundog Posted February 27, 2018 Share Posted February 27, 2018 OK fine...encoded voltage changes travel along the wire. But what's being encode? 1's and 0's, no? If I'm wrong, so be it... but if not, we're splitting hairs. Either way, the data either gets there, or it doesn't. Sorry, wasn't trying to throw any shade your way .... and you're absolutely right, its splitting hairs in this case ... either way the OP might be losing connection via either a faulty cable (intermittent wire or shield) or a faulty USB connector on Helix or the PC. @jbright44, you aren't using a USB hub by any chance, are you — they are notorious for messing up connections. Quote Link to comment Share on other sites More sharing options...
thenickhill81 Posted February 28, 2018 Share Posted February 28, 2018 I had some connection issues with my Helix and ended up buying a new, longer one on amazon. An amazon basics actually and have not had a single issue since. Quote Link to comment Share on other sites More sharing options...
jbright44 Posted March 1, 2018 Author Share Posted March 1, 2018 I'm using a long Amazon basics cable. No hub. Although I'm about to get a new laptop that is USBC only and I'll be forced to use a hub Quote Link to comment Share on other sites More sharing options...
