Some_Donkus Posted March 18, 2018 Share Posted March 18, 2018 I know it's happened in the past... and it seems to have happened again. My line 6 Monkey cannot connect to Line 6 Servers. I tried the three older methods of "fixing" the problem by uninstalling/reinstalling (including a registry clean). I also tried to deleting content of the app data folder (windows 7), as well downgrading to various older versions of Monkey. No joy. I'd really like to flash my new HD500x with the latest firmware... any help? 1 2 Quote Link to comment Share on other sites More sharing options...
ktownson Posted March 19, 2018 Share Posted March 19, 2018 Having the same problem, running Win 10 and just performed a clean install. First time trying to access Line 6 since the hard drive swap. Line 6 Monkey cannot access the server and eventually times out. Quote Link to comment Share on other sites More sharing options...
daxtichy Posted March 19, 2018 Share Posted March 19, 2018 Ditto here... Tried some work-arounds with no luck. Socket time out when "Check for Updates" is clicked in Monkey. License Manager is more of the same "Server not responding (connection timed out). Code 8000204e. Quote Link to comment Share on other sites More sharing options...
cmavra Posted March 19, 2018 Share Posted March 19, 2018 I'm having the same problem as well. My UX2 is not showing up under the device in the license manager as well. Quote Link to comment Share on other sites More sharing options...
IronCouncil Posted March 19, 2018 Share Posted March 19, 2018 The same problem: 8000204e error in License Manager Quote Link to comment Share on other sites More sharing options...
wn6134 Posted March 19, 2018 Share Posted March 19, 2018 The same problem. Quote Link to comment Share on other sites More sharing options...
smith Posted March 19, 2018 Share Posted March 19, 2018 having same problem Quote Link to comment Share on other sites More sharing options...
bakergtr Posted March 19, 2018 Share Posted March 19, 2018 Same problem, monkey and license program can't connect to server. Quote Link to comment Share on other sites More sharing options...
bmaynard Posted March 20, 2018 Share Posted March 20, 2018 (edited) Same here, and this is a day later than the original post. What's up Line 6? Edited March 20, 2018 by bmaynard spelling Quote Link to comment Share on other sites More sharing options...
kvs89 Posted March 20, 2018 Share Posted March 20, 2018 Also experiencing this issue. Occurs with 1.74 and 1.72 monkey. Guessing a server is down. Quote Link to comment Share on other sites More sharing options...
gpq1971 Posted March 20, 2018 Share Posted March 20, 2018 Same here. v1.74. Can't download drivers. Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted March 20, 2018 Share Posted March 20, 2018 9 hours ago, bmaynard said: Same here, and this is a day later than the original post. What's up Line 6? Whatever it is, nobody from L6 is gonna answer you in here... this is a user forum. Open a support ticket... that they'll respond to. Quote Link to comment Share on other sites More sharing options...
bakergtr Posted March 20, 2018 Share Posted March 20, 2018 I got a response. "I apologize for the delay. You may access your bundle by running our software Line 6 License Manager. Unfortunately, we must apologize as the servers pertaining to this software are currently undergoing maintenance. This issue should be resolved shortly. " All of my drivers and software are up to date but since the licensed manager can't connect I can't access the complete bundle. Thanks for the workaround solution, but it doesn't address the problem I'm having. Quote Link to comment Share on other sites More sharing options...
barkerm Posted March 20, 2018 Share Posted March 20, 2018 I thought I was having the same problem. So I just did the long wait and finally it connected and opened. Just taking a LOT longer than usual. Quote Link to comment Share on other sites More sharing options...
ktownson Posted March 20, 2018 Share Posted March 20, 2018 5 hours ago, hurghanico said: guys I gave you a working workaround solution a few posts above here.. why you don't read and try it?... it's not that difficult I'm not even getting it to recognize the Pod XTLive or the Variax--tried both 1.72 and 1.74 Quote Link to comment Share on other sites More sharing options...
Some_Donkus Posted March 21, 2018 Author Share Posted March 21, 2018 On 3/19/2018 at 10:19 AM, hurghanico said: you can flash the firmware in offline mode, ie go to the DOWNLOAD section of this site, choose your device, choose flash memory, and your operating system, and save the latest firmware file on your desktop.. then disconnect you computer from internet otherwise the monkey app will hung forever if the L6 servers are not responding and the internet connection is active, with the device connected, open the monkey app, when it recognizes your device, select Flash Memory and press Update From File button, and when asked where is the firmware file, point to the one previously saved on your desktop, and let the procedure start and finish I would love to try this particular method, except Monkey will not recognize my HD500x. For some reason, when the servers are disconnected, it will only recognize devices that have been recognized during a previous load (when the network was able to connect). So, I cannot even offline flash my firmware. :( Hopefully they get this server back up soon. I've even tried using VPN's , hoping that an EU or JPN line6 server would connect...no dice. Quote Link to comment Share on other sites More sharing options...
ktownson Posted March 21, 2018 Share Posted March 21, 2018 Good news..was able to connect, update and all is well. Thx, Line6! Quote Link to comment Share on other sites More sharing options...
Sadders Posted June 17, 2018 Share Posted June 17, 2018 Is this happening again? None of my Line6 products will connect to server. No problem logging in on the website, just Licence manager and Monkey wont log in. Quote Link to comment Share on other sites More sharing options...
jacobkrauss Posted October 30, 2020 Share Posted October 30, 2020 im having this problem now, what is the sollution Quote Link to comment Share on other sites More sharing options...
pipelineaudio1 Posted August 28, 2022 Share Posted August 28, 2022 me too Quote Link to comment Share on other sites More sharing options...
