khawkins75 Posted June 8, 2018 Share Posted June 8, 2018 New guy here. Any recommendations on budget small-ish speakers for a home setup? My HD500X will be here next week, and I want to run it into some speakers in my home office. I just play at home, not live, so that's what I'm planning to do. The signals going into the speakers will be my guitar from the HD500X, and my computer or iPod. Some options I've checked that look promising are the Mackie CR4 and Edifier R1700BT. Or, there's the passive route with the Polk T15 and a small amp. Any advice? I'd like to just do this once and be done.....for a bit, anyway. 1 Quote Link to comment Share on other sites More sharing options...
Strat2Die4 Posted June 14, 2018 Share Posted June 14, 2018 I use M-Audio BX8, they are decent and compact. Quote Link to comment Share on other sites More sharing options...
stormstudios Posted June 14, 2018 Share Posted June 14, 2018 another supporter of the BX8s right here For your purposes, I checked out the ones you noted above. I would probably choose the Mackie CR4 over the Edifier. I would not go the passive route. One thing I'd look for so you aren't upgrading later is having powered speakers with XLR inputs so you can go direct to the speakers / monitors through a balanced connection. Youc an do the XLR to 1/4" cable but what I like about the BX8s is XLR to XLR and I can still use the unbalanced 1/4" output to the amp if I want and switch between Line level and Amp level. Let us know what you end up choosing! Quote Link to comment Share on other sites More sharing options...
pfsmith0 Posted June 25, 2018 Share Posted June 25, 2018 The IK Multimedia iLoud speakers are quite impressive for their size. Quote Link to comment Share on other sites More sharing options...
stevecu Posted July 4, 2018 Share Posted July 4, 2018 I'm using a single Event ASP8 that I picked up used and am very happy with the sound. Perhaps someone can chime in as to why a second one would add much utility. I suppose it would allow you to run a dual signal path with two different amps, but that seems kind of niche. Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted July 4, 2018 Share Posted July 4, 2018 JBL LSR305's, or the 308's if you want to go a little bigger... just depends on how much room you've got. Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted July 4, 2018 Share Posted July 4, 2018 Quite frankly, it doesn't matter. If you have no intentions of taking it out of your bedroom. And you made no mention of recording. Then, it simply does not matter. You design your tones around the speakers that the noise is coming from. It only makes a difference if you intend on using something different. Take me, as an example. I will use the headphones that came with my cell phone. I have $20 computer speakers (which may have been $5 twenty years ago). I have JBL Eons. I have pa systems. I have Hollywood production studio equipment (I work for ABC/Disney). My home stereo. A guitar amp. I mean, I have access to gear out the wazoo. The list of what I use is endless. But I only design my tones on certain items. Because only certain items give a clear, unbiased, tone which will translate well to any source. I can't design tones on those Samsung ear buds because there is too much bass being added. BUT, if the only thing I was ever going to use was those ear buds, then I could design my tones without the bass to compensate for the extra bass they provide. But design them that way, and then use them on the Eons, they will sound thin and tinty. 1 Quote Link to comment Share on other sites More sharing options...
matonanjin Posted July 17, 2018 Share Posted July 17, 2018 On 6/8/2018 at 5:27 PM, khawkins75 said: Any recommendations on budget small-ish speakers for a home setup? My HD500X will be here next week, and I want to run it into some speakers in my home office. I just play at home, not live, so that's what I'm planning to do. The signals going into the speakers will be my guitar from the HD500X, and my computer or iPod. Thank you for starting this thread. I'm in exactly the same situation and need to find some replacement speakers for my system. The responses are helpful. Quote Link to comment Share on other sites More sharing options...
matonanjin Posted July 18, 2018 Share Posted July 18, 2018 On 6/14/2018 at 11:27 AM, stormstudios said: For your purposes, I checked out the ones you noted above. I would probably choose the Mackie CR4 over the Edifier. I would not go the passive route. One thing I'd look for so you aren't upgrading later is having powered speakers with XLR inputs so you can go direct to the speakers / monitors through a balanced connection. Youc an do the XLR to 1/4" cable but what I like about the BX8s is XLR to XLR and I can still use the unbalanced 1/4" output to the amp if I want and switch between Line level and Amp level. Does anyone have any idea what he said? lol Quote Link to comment Share on other sites More sharing options...
matonanjin Posted July 20, 2018 Share Posted July 20, 2018 On 7/4/2018 at 9:45 AM, cruisinon2 said: JBL LSR305's, or the 308's if you want to go a little bigger... just depends on how much room you've got. 87.3% certain I am going to go with JBL 305's. I really liked the sound. Quote Link to comment Share on other sites More sharing options...
Strat2Die4 Posted July 20, 2018 Share Posted July 20, 2018 13 hours ago, matonanjin said: 87.3% certain I am going to go with JBL 305's. I really liked the sound. Are you sure it is not 88%? ;) Quote Link to comment Share on other sites More sharing options...
joel_brown Posted July 20, 2018 Share Posted July 20, 2018 JBL/M-Audio*iLab+(SquareRoot(Mackie)) = 87.3% But I was never good at Math. I can't count the number of times that Math has alluded me. Quote Link to comment Share on other sites More sharing options...
matonanjin Posted July 21, 2018 Share Posted July 21, 2018 10 hours ago, Strat2Die4 said: Are you sure it is not 88%? ;) Positive. 4 hours ago, joel_brown said: But I was never good at Math. I can't count the number of times that Math has alluded me. OMG. That was awful! Great job. Quote Link to comment Share on other sites More sharing options...
