GeraGrind
Line 6 Spider V problems
Hi. I found some issues in my Line 6 Spider 240HC amp that probably have other discussions opened, but i decided to record them.
https://youtu.be/67unAeUulCA
In the first one, the display flashes when it's turned off.
https://youtu.be/477VH-TT4W8
That sound happens when i turn off the amp. That happens sometimes using different IEC cables.
https://youtu.be/Fy6RwlY-xHk
This problem started when i changed my IEC cable too. Sorry for the sound quality, there is a clicking sound when i activate the reverb.
I though the it could be caused by the cable, but they are universal and i guess that it could be produced by digital issues. I really like this amp but it's difficult to play a gig calmed with that kind of problems.
Is anyone having these problems?
Sorry for my english.
Hi GeraGrind, the things you are experiencing are certainly not intended functions. Do you experience these problems with the IEC cable that came with you Spider 240HC? It sounds like it may be something in the amp that needs to be fixed/replaced. I would recommend exchanging the unit at point of sale or opening a support ticket with Line 6.
Yes! The display flash. Mine does it too. When its turned off.
I've only ever seen it in my peripheral vision, never when I was looking directly at the amp.
Often thought I was seeing things or it was a reflection of something.
Perhaps it is caused by capacitors draining slowly. Don't see this as a problem, more of a curiosity.
Went to zZounds today to buy the 240 MK II AND THE GT RECIEVER, They posted that the receiver was no longer avaiable, so I Sent to musicians friend and they didn't have the 240 or 120 mk II Or the reciever.. Sweetwater either
What the he'll is going on?????
My friend, this is why those equipments are too cheap... es because the after-sales service is awful. I always wait some answer from the manufacturer defending the product, but I think the goal is to sell only.
Your problem is very simple, I don't know why some technical expert from Line6 didn't replies you....
You need to connect your head-amp to a powerline with ground... because the electronic circuit needs to drain some electricity when is turned off. I had the some issues as you and I resolved as I said.
Try to connect your amp to an electrical plug with GROUND connection.
Simple as water, difficult answer for Line6
BYEEEEE
Have you updated to the new Mk II firmware?  If not, does making that upgrade help?
I just checked Musicians Friend, they have both items in stock and ready to ship. I don't know why you got that info.
