pott24 Posted October 16, 2018 Share Posted October 16, 2018 I'm still a little confused about the Reserved Midi CC sections (p49 in https://line6.com/data/6/0a020a4010c935bb66a4c0c44f/application/pdf/HX Stomp Manual - English .pdf). Does it mean I cannot configure an external Midi controller (got a Morningstar MC6 on order) to, for example, always have the Looper controls on bank 1? Or, for that matter, to change Play modes (Stomp/Snapshots)? I am trying to decouple the Midi controller from Preset-specific messages as much as possible. I.e., have the controller control as much of the macro-actions (tuner, looper, presets, snapshots) and the HX itself control the micro-actions (blocks on/off). But even with a flexible unit such as the Morningstar, it seems there's limitations to that specifically... Quote Link to comment Share on other sites More sharing options...
d0stenning Posted October 16, 2018 Share Posted October 16, 2018 Yes I come across this issue as a problem for other MIDI controller devices. I own an ActitioN MIDI controller which has fixed MIDI CC for each stomp. So i'd really like for my HELIX ( and soon Stomp ) to be able to have some of its fixed reserved CC made customisable. Special things like Snapshots and effect bypass assignments. Quote Link to comment Share on other sites More sharing options...
pott24 Posted October 16, 2018 Author Share Posted October 16, 2018 Yep... Even with a more dynamic controller, it seems we can't send the reserced CCs. I'm confused as to why... Maybe it's a MIDI limitation but then, can't another CC be allocated for external MIDI commands to the same control? Quote Link to comment Share on other sites More sharing options...
phil_m Posted October 17, 2018 Share Posted October 17, 2018 19 hours ago, pott24 said: I'm still a little confused about the Reserved Midi CC sections (p49 in https://line6.com/data/6/0a020a4010c935bb66a4c0c44f/application/pdf/HX Stomp Manual - English .pdf). Does it mean I cannot configure an external Midi controller (got a Morningstar MC6 on order) to, for example, always have the Looper controls on bank 1? Or, for that matter, to change Play modes (Stomp/Snapshots)? I am trying to decouple the Midi controller from Preset-specific messages as much as possible. I.e., have the controller control as much of the macro-actions (tuner, looper, presets, snapshots) and the HX itself control the micro-actions (blocks on/off). But even with a flexible unit such as the Morningstar, it seems there's limitations to that specifically... No, the reserved CC messages on Page 49 are the messages you want to program into your controller and send to control those specific functions. To select snapshot #1, for instance, you always send CC69, value 0. That will be the same no matter what preset you have the Stomp set to. If you want to have a preset on the Morningstar be the looper controls, you could do that. From what I understand, the Morningstar lets you program the six switches in every preset with pretty much anything you want. The question really becomes how often you want to change presets on the Morningstar. Quote Link to comment Share on other sites More sharing options...
ElPapo Posted October 17, 2018 Share Posted October 17, 2018 I been trying to control the Hx stomp with disasterarea design dpc , I'm able to change presets but can't turn on the turner via or bypass the HX stomp . anyone here have an idea ? Quote Link to comment Share on other sites More sharing options...
pott24 Posted October 17, 2018 Author Share Posted October 17, 2018 5 hours ago, phil_m said: No, the reserved CC messages on Page 49 are the messages you want to program into your controller and send to control those specific functions. To select snapshot #1, for instance, you always send CC69, value 0. That will be the same no matter what preset you have the Stomp set to. If you want to have a preset on the Morningstar be the looper controls, you could do that. From what I understand, the Morningstar lets you program the six switches in every preset with pretty much anything you want. The question really becomes how often you want to change presets on the Morningstar. Thanks for clarifying! I think I applied the word 'learn' to something less specific than it really is. I thought it meant that an external controller couldn't use these controls at all. Re-reading the instructions and applying your clarifications, 'learn' here refers to attempting to assign a preset MIDI stomp through the Bypass assignment setup. That's fantastic news! In particular, the ability to both assign Snapshot up/down AND 4 presets per bank on the Morningstar frees-up using the HX for stomps, in Stomp-mode, and brings a TON of flexibility (using multiple banks of presets instead of banking up/down using the HX). Quote Link to comment Share on other sites More sharing options...
pott24 Posted October 17, 2018 Author Share Posted October 17, 2018 13 hours ago, Tsachou said: I been trying to control the Hx stomp with disasterarea design dpc , I'm able to change presets but can't turn on the turner via or bypass the HX stomp . anyone here have an idea ? See https://line6.com/data/6/0a020a4010c935bb66a4c0c44f/application/pdf/HX Stomp Manual - English .pdf for the relevant tuner and bypass commands. Not sure of the disaster area can send fully-customized Midi PC/CC as the Morningstar can though... Quote Link to comment Share on other sites More sharing options...
phil_m Posted October 17, 2018 Share Posted October 17, 2018 14 hours ago, Tsachou said: I been trying to control the Hx stomp with disasterarea design dpc , I'm able to change presets but can't turn on the turner via or bypass the HX stomp . anyone here have an idea ? The thing about the Disaster Area Design products is that they're built around the idea that there are different pre-made templates for different products. Some of them have modes that allow you to program the switches with certain CCs or PCs, but the DPC doesn't allow that as far as I can tell. There is a Line 6 M13/M9/M5 mode, but, unfortunately, the Stomp uses different CCs for functions than the M-series. I expect DAD will update the firmware with templates for the Stomp soon, but right now, I don't think there's much you can do. Quote Link to comment Share on other sites More sharing options...
Kirklandrock Posted October 17, 2018 Share Posted October 17, 2018 Could I use a Tech 21 Midi Mongoose to call up presets and then use the 3 HX Stomp buttons to turn effects on/off??? Example: Button 1 on my midi controller pulls up my favorite CLEAN patch/preset and Button 1 on the HX Stomp turns on/off the effect of my choice... same for the other HX Stomp buttons. Am I on the right track here??? Quote Link to comment Share on other sites More sharing options...
soundog Posted October 19, 2018 Share Posted October 19, 2018 Yes, you could do that. And you should get together with this guy: Quote Link to comment Share on other sites More sharing options...
MooseTaylor Posted November 30, 2018 Share Posted November 30, 2018 I'm setting up a controller for my stomp using TouchOSC and the Yamaha MD-BT01 via my iPhone. So far all good.... got the FS-1 to FS-5 switches all working and tap tempo, tuner, and bypass buttons...... but what I REALLY want, is to be able to control the global EQ via sliders etc.... Is that something we can do? That way I can set the EQ from iPhone, while playing a loop, listening from the back of the room. Are there some mystic midi messages we can use? Quote Link to comment Share on other sites More sharing options...
neilius Posted November 30, 2018 Share Posted November 30, 2018 i found this quite informative for the MC6 users: Quote Link to comment Share on other sites More sharing options...
forasong Posted December 6, 2018 Share Posted December 6, 2018 I am planning on setting up my iphone/ipad with touchosc as well. I have just started researching this and haven't even downloaded the app yet. my yamaha wireless midid is on its way. i would love to get your (Moose) template if possible....id like to have tuner and tap on my ipad and then, i think, just a simple list of my named presets on the screen so i can change to the presets i have set up for specific songs or choose a general rig if i don't have something programmed for a song in my set list. Also, can midi commands from the touchosc determine the state that a preset shows up in? There are some presets i'd like to load in stomp mode and some i'd like to load in snapshot shot when they come up on the stomp. Thanks.......M Quote Link to comment Share on other sites More sharing options...
reyesfearofnone Posted December 6, 2018 Share Posted December 6, 2018 Have any of you guys tried using the midi mouse by tech 21 to try to change preset on the HX stomp its my first time using midi any help would be greatly appreciated Quote Link to comment Share on other sites More sharing options...
MooseTaylor Posted December 26, 2018 Share Posted December 26, 2018 On 12/6/2018 at 5:43 AM, forasong said: I am planning on setting up my iphone/ipad with touchosc as well. I have just started researching this and haven't even downloaded the app yet. my yamaha wireless midid is on its way. i would love to get your (Moose) template if possible....id like to have tuner and tap on my ipad and then, i think, just a simple list of my named presets on the screen so i can change to the presets i have set up for specific songs or choose a general rig if i don't have something programmed for a song in my set list. Also, can midi commands from the touchosc determine the state that a preset shows up in? There are some presets i'd like to load in stomp mode and some i'd like to load in snapshot shot when they come up on the stomp. Thanks.......M hi forasong, I don't have it on this computer but I did post it to the Helix Stomp facebook group (which, if you are not a member, you should join). you'll find the .touchosc file in the "files" section. There are a couple from me (the newest is the best), as well as files from other users. Hope it helps Moose Quote Link to comment Share on other sites More sharing options...
pott24 Posted December 27, 2018 Author Share Posted December 27, 2018 On 12/6/2018 at 6:17 AM, reyesfearofnone said: Have any of you guys tried using the midi mouse by tech 21 to try to change preset on the HX stomp its my first time using midi any help would be greatly appreciated Nothing to actually do. Plug it in, and that's exactly what the Midi Mouse does, and nothing else. Just preset scroll up/down, and you can use Active/Search modes. The midi mouse doesn't do anything else, doesn't require any setups, has no available configuration to change. You do not need to know Midi either. Just make sure its midi send Channel is set to your HX Stomp's (1 on both units by default). Quote Link to comment Share on other sites More sharing options...
Jakeallen Posted January 26, 2019 Share Posted January 26, 2019 On 11/29/2018 at 4:49 PM, MooseTaylor said: I'm setting up a controller for my stomp using TouchOSC and the Yamaha MD-BT01 via my iPhone. So far all good.... got the FS-1 to FS-5 switches all working and tap tempo, tuner, and bypass buttons...... but what I REALLY want, is to be able to control the global EQ via sliders etc.... Is that something we can do? That way I can set the EQ from iPhone, while playing a loop, listening from the back of the room. Are there some mystic midi messages we can use? Please Mr. MooseTaylor, Can you explain the control setting for the tuner control? For the life of me I cannot get TouchOSC to toggle the Stomp Tuner On and stay on and then toggle it back off again. Any help is much appreciated! Quote Link to comment Share on other sites More sharing options...
