Lone_Poor_Boy Posted June 12, 2020 Share Posted June 12, 2020 I thought this thread from yesterday centered on the input pad had really great feedback throughout. Different approaches to skinning the cat. 1 Quote Link to comment Share on other sites More sharing options...
BBD_123 Posted June 13, 2020 Author Share Posted June 13, 2020 Yes, agreed. In fact I now use the gain block rather than turning the input pad on. Decibels are decibels. Quote Link to comment Share on other sites More sharing options...
robbieb61 Posted June 13, 2020 Share Posted June 13, 2020 Off. Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted June 14, 2020 Share Posted June 14, 2020 I doesn't. Quote Link to comment Share on other sites More sharing options...
SaschaFranck Posted June 14, 2020 Share Posted June 14, 2020 I actually changed from input pad on to off (at least for the time being), pretty much the other way around from what many others seem to be doing. I started with it on after reading several comments about it to improve some things. That was before I bought the Helix. When I finally got it, I compared on/off with what I thought would be my most used amps and some things seemed to sound/react a little better, so I left it on. Ok, over time I was working a bit more with Helix Native (and other software amps), using the straight DI signal (coming from USB 7/8). And even with my hotter guitars, it's always been pretty weak - which is annoying as I have to way zoom in to visually control cuts and such. But well, that wasn't the main reason for me to turn it back off. I noticed that with my particular assortment of guitars (my absolute No.1 being an Anderson with pretty low level PUs) some of the drives would simply work better with Input Pad off, most notably the Top Secret OD (which is indeed my most loved drive within the Helix, actually delivering what I usually expect from a nice fuzz). So I checked all my patches and re-adjusted them. I found most of them to work better in the end. There's some drawbacks, though. I think some Helix amps deliver too much drive, so I have to turn their drive parameter way down or activate a volume block in front - which wasn't necessary with Input Pad on. Now, I have a volume block as the first thing in my signal chain anyway (at least on all of my regular patches), but I prefer to have as little blocks as possible switched on for a basic tone. Whatever, unfortunately my most used amp models for anything slightly driven to standard rock kinda stuff, namely the two 2204s, are affected the most. I like them a lot with very little drive (I rather add gain with some drive models), just as I did back when I owned a JCM800, and with the Input Pad off, without a preceeding drive block I need to go down as low as 1.0 or even 0.8/0.9 on the Drive parameter. I may have to revisit the entire thing one day, for now I decided to live with IP off. Whatever, ideally, there would be a patch setting allowing you to overwrite the global setting (global/on/off). And IMO it'd be even better in case there were more settings (I'd likely go for something inbetween), but that would require new hardware. Quote Link to comment Share on other sites More sharing options...
hideout Posted June 14, 2020 Share Posted June 14, 2020 All my guitars have low output pickups so nope. Quote Link to comment Share on other sites More sharing options...
designwebfocus Posted November 22, 2023 Share Posted November 22, 2023 Very useful posts in this thread, thank you! For me it's worth revisiting as I have had my Helix floor for almost a year now. I used to play two main guitars: my '76 Strat with vintage low outpout pickups 90% of the time and a Player series Tele with its built-in pickups but rewired with traditional wiring ("grease bucket" circuit removed to use a single 0.47 cap). It's a bit higher output than my Strat but not hot by any means. I've had the global input pad off the entire time as I didn't see the need. I recently added a PRS SE Custom 24-08 to my arsenal which will be used a lot more than my Tele ever was (although my Strat remains my #1... I'm a Strat guy ;) I then revisited the input pad thing because the PRS didn't sound that great in my Strat based presets. I turned it on and it improved the PRS tone imeediately without changing settings. I will still need to lower gain on some amps but it sounds way better. But the thing is, so does my Strat without any changes to the patches. higher gain amps sound less compressed and fizzy (I mostly use the Revv Gen Red which I love) and for cleans, I use either the Cali Texas Ch 1 or the Jazz Rivet 120. Everything seems to sound less harsh without loosing definition. Personally, I love the tone with the Pad on now. Quote Link to comment Share on other sites More sharing options...
gourgou Posted November 27, 2023 Share Posted November 27, 2023 On 6/12/2020 at 6:37 PM, donkelley said: […], it has just saved me a ton of trouble on my basses. I play bass and guitar through this (and will play electric violin and cello through it too). One of my basses is pretty high output active, and it happens to sound better with it's on board bass control boosted - and voila, we're talking very high output now. […] So I enabled the pad and voila - it solves my biggest issue. However I change axes all the time, and they are not all the same output. I'm a bass player too, and I can't get a clean sound with any amp model unless I turn the input pad on! My fully passive bass is possibly the punchiest, since I almost never boost anything on my active preamps (I see them more as impedance helpers; I'm not a huge fan of batteries inside instruments, actually). I'm really not a "heavy hitter" but I've been told I'm not quite on the "light touch" side either… On the odd occasion I plug a guitar in, I find the "pad always on" to be a no brainer. It goes very well along my LP. I was curious as to whether it would be "too tame" on single coils. I've recently borrowed a strat and navigated a few presets: damn, some come heavy! ^^' Quote Link to comment Share on other sites More sharing options...
craig180guitar Posted February 28, 2024 Share Posted February 28, 2024 I play a strat single coil - classic rock and country. I set up Presets with an Emsley amp. I setup an A/B preset test (A) with Input Pad off, and (B) Input On by selecting in the Global settings. I increased the amp channel volume on the Input Pad ON option to match the volume of the OFF option using a LUFS meter at approx -20db. I noticed a much clearer tone with the Input PAD ON. If have 4 snapshots from edge of breakup to hi gain and all options more clear. With Input OFF, the snapshots clean to hi gain were all muddier and overdriven. They also have a clipping nuance on the cleaner (less drive) options. I do use a subtle compressor with unity gain and reverb. I also use ownhammer IRs, and EQ block with a hicut at 4 and low cut at 80. Quote Link to comment Share on other sites More sharing options...
Schmalle Posted February 28, 2024 Share Posted February 28, 2024 On 2/28/2024 at 4:09 PM, craig180guitar said: I play a strat single coil - classic rock and country. I set up Presets with an Emsley amp. I setup an A/B preset test (A) with Input Pad off, and (B) Input On by selecting in the Global settings. I increased the amp channel volume on the Input Pad ON option to match the volume of the OFF option using a LUFS meter at approx -20db. I noticed a much clearer tone with the Input PAD ON. If have 4 snapshots from edge of breakup to hi gain and all options more clear. With Input OFF, the snapshots clean to hi gain were all muddier and overdriven. They also have a clipping nuance on the cleaner (less drive) options. I do use a subtle compressor with unity gain and reverb. I also use ownhammer IRs, and EQ block with a hicut at 4 and low cut at 80. Do this comparison: patch with Gtr Pad Off same patch with Gtr Pad On and a +7dB gain block first in the path Quote Link to comment Share on other sites More sharing options...
somebodyelse Posted June 22, 2024 Share Posted June 22, 2024 Old thread, nevertheless... Usually play with the pad off, however, I have a couple of presets, where I have a few Snapshots set up specifically for use with an E-Bow. In these cases, I have the pad switched on (via the Snapshots). That was a 'eureka moment' when I discovered I could toggle the Pad in the Snapshots. 2 Quote Link to comment Share on other sites More sharing options...
SaschaFranck Posted June 22, 2024 Share Posted June 22, 2024 On 6/14/2020 at 9:41 AM, SaschaFranck said: Whatever, ideally, there would be a patch setting allowing you to overwrite the global setting (global/on/off). Fwiw, you can call me Cassandra. And fortunately they did it exactly like that, a) because as a global tool it's not offering fine enough adjustement options and b) because some amps profit a lot from input padding (making their gain controls way more efficient) whereas others are working better without the pad. 1 Quote Link to comment Share on other sites More sharing options...
somebodyelse Posted June 23, 2024 Share Posted June 23, 2024 On 6/22/2024 at 12:48 PM, SaschaFranck said: Fwiw, you can call me Cassandra. And fortunately they did it exactly like that, a) because as a global tool it's not offering fine enough adjustement options and b) because some amps profit a lot from input padding (making their gain controls way more efficient) whereas others are working better without the pad. Absolutely. The moral of the story is 'learn your gear properly, before writing it off'. I've had my Helix 3 or 4 years and only found I could do this on Thursday. Quote Link to comment Share on other sites More sharing options...
SaschaFranck Posted June 23, 2024 Share Posted June 23, 2024 On 6/23/2024 at 10:59 AM, somebodyelse said: I've had my Helix 3 or 4 years and only found I could do this on Thursday. Don't worry, I don't think that feature is as old - and it's pretty common for "utility" functions added in updates being sort of overlooked (also happened to me when they changed the dreaded old "IR must be in an identical slot" behaviour to "it's enough once it exists inside the unit"). 1 Quote Link to comment Share on other sites More sharing options...
somebodyelse Posted June 25, 2024 Share Posted June 25, 2024 On 6/23/2024 at 12:14 PM, SaschaFranck said: Don't worry, I don't think that feature is as old - and it's pretty common for "utility" functions added in updates being sort of overlooked (also happened to me when they changed the dreaded old "IR must be in an identical slot" behaviour to "it's enough once it exists inside the unit"). Buddy, I don't worry about it... I'm 57 years old, I've been using the same MIDI rack mount setup up for 30 years and I'm still finding out things it can do that I didn't know about. Makes me chuckle when I read posts where people have given up on a piece of gear after a week with it, though. 1 Quote Link to comment Share on other sites More sharing options...
