jazfunk Posted December 31, 2013 Share Posted December 31, 2013 I just received my new DT50 today and first tried it with a guitar directly into the amp. Sounds amazing! Then, I hooked up my POD HD500 with an XLR cable to the L6 link and I get no sound. I hear some popping and when I change presets I can hear some relays switching, but no audio. I've searched and found very little on this topic, some statements regarding updates and flash memory, etc. Just wanted to throw it out to the forum and see if anyone has had or heard of this type of problem. Thanks. Quote Link to comment Share on other sites More sharing options...
Charlie_Watt Posted December 31, 2013 Share Posted December 31, 2013 I believe that you may have to set up the link on the HD500. In Edit there is a whole setup section. (I have not tried it - do not have anything with Link to try it on) Quote Link to comment Share on other sites More sharing options...
jazfunk Posted January 1, 2014 Author Share Posted January 1, 2014 Yes, you are correct. I did check the output settings and all are appropriately set. Quote Link to comment Share on other sites More sharing options...
pol2711 Posted January 1, 2014 Share Posted January 1, 2014 I have the same issue after upgrading my hd500 to firmware 2.20. Before it worked well, now I have the same: no sound, only popping sounds Other thing: my variax JTV59 sounds wonderfull on amp1 on my dt-25, the fender one..clean On number 2 and 3, the marshall/vox one it sounds terrible. digital clipping, one harsh thin sound.... Quote Link to comment Share on other sites More sharing options...
robyone Posted January 1, 2014 Share Posted January 1, 2014 ...same issue. Tried to re-flash hd500 and dt50 212, no lucky..... :angry: Quote Link to comment Share on other sites More sharing options...
phil_m Posted January 1, 2014 Share Posted January 1, 2014 I just received my new DT50 today and first tried it with a guitar directly into the amp. Sounds amazing! Then, I hooked up my POD HD500 with an XLR cable to the L6 link and I get no sound. I hear some popping and when I change presets I can hear some relays switching, but no audio. Do you have the master volume on the HD500 turned up? That was the one thing that changed in the update. Before the master volume on the HD500 was bypassed when using L6 Link. Now it's in the signal path, so if it's down, you wouldn't be getting any sound out of the DT-25. Quote Link to comment Share on other sites More sharing options...
robyone Posted January 1, 2014 Share Posted January 1, 2014 ...all way up....tried to move any switch....strange issue Quote Link to comment Share on other sites More sharing options...
jazfunk Posted January 3, 2014 Author Share Posted January 3, 2014 Yes, I've turned the master volume up. I too just upgraded to 2.2. Clearly this is related. Quote Link to comment Share on other sites More sharing options...
edstar1960 Posted January 3, 2014 Share Posted January 3, 2014 Did you try the standard power off and then power on for both the HD500 and the DT50? Try powering on HD500 first while connected via L6 LINK to DT50 and then power on the DT50. I used to have a similar issue with my HD500 and DT25 and a power off of both and then a power on always fixed the issue. However, I have not tried it since going to v2.2 fw on the HD500, so fingers crossed it still helps. Quote Link to comment Share on other sites More sharing options...
radatats Posted January 3, 2014 Share Posted January 3, 2014 1. Could be the cable. Swap XLR cables with a known good one. 2. Could be the patch. Start a new patch with nothing but an amp Pre model of your choice. Keep it in the default position with default settings. 3. Could be the order of turning them on. They are still computers and need to talk to each other. (This has helped me in the past) start with everything off. turn HD500 on let it stabilize. turn DT50 to Standby, Master off, PWR on and wait. There will be no light around master or topology settings. wait and it will click on, it will click again in a few seconds as the topology syncs with the POD and the lettering will be lit up. turn DT Standby to ON, Master up a quarter. POD Master to half, guitar volume up, should have sound now. always use the reverse to shutdown if you want to use HDEdit, turn POD on first, then HDEdit before DT on. Let us know if any of this helps... Quote Link to comment Share on other sites More sharing options...
stumblinman Posted January 3, 2014 Share Posted January 3, 2014 Anyone else notice if you turn the DT off with Pod attached, even in standby there is a "chunk" noise? Doesn't happen when using the DT by itself. Just an observation. Quote Link to comment Share on other sites More sharing options...
jacopo_costella Posted November 15, 2014 Share Posted November 15, 2014 Hi there, same problem. I followed the instructions from radatats but still mute. Any updates about such issue? Quote Link to comment Share on other sites More sharing options...
radatats Posted November 15, 2014 Share Posted November 15, 2014 Hi there, same problem. I followed the instructions from radatats but still mute. Any updates about such issue? give more details please. check the input settings are correct too... Quote Link to comment Share on other sites More sharing options...
chuberto Posted November 15, 2014 Share Posted November 15, 2014 I take it you are going Guitar - guitar cable - HD500 guitar in - L6 Link - XLR cable - DT L6 Link Input? Quote Link to comment Share on other sites More sharing options...
asarratori Posted January 3, 2015 Share Posted January 3, 2015 Same thing here - Pro x 2nd time I turned it on - no sound with the L6 link. Got it to work - unplugged the L6 at my DT25 - Turned the DT back on and then plugged in the HD pro x that was already on. It worked but was very frustrating. Thought it was me - Thinking of bringing my old pedal to rehearsal tonight. Must be the DT25 no syncing properly. Quote Link to comment Share on other sites More sharing options...
