HX Stomp 2.9 tuner not working
jotacaster
13 minutes ago, Barbarisch said:
Same issue....tuner does not register anything from guitar....Checked all settings, don't see any problem there.....also no sound out on 1/4 inch jack outputs now....
I've updated a Stomp and a Floor without problems.
Check your Global Settings.
If that doesn't fix it:
Do a factory reset.
If that doesn't fix it, open a support ticket.
I posted this in the wrong place it appears.....I have Helix LT...anyway everything ok now....appears to have just needed to be turned on and off one more time since I did update last night...although I did disconnect the usb cable when I powered down and up, but good now...maybe just a glitch from shutting down right after update last night and using today.....
28 minutes ago, pampeo said:
Hello
I got also the same problem with the tuner
And now it's even worse..... When a engage the tuner switch, it freeze the entire pedalboard ...
I really need help please
Have you installed the 2.91 update?
  • Thanks 1
updated yesterday to 2.90 and all works fine. after 2 restarts the tuner did not work and all patches sound the same! today i updated to 2.91 (important: 1st make a backup as suggested in the notes and after the update is done restore the backup and restart helix!!!) now all works fine again! hope tis works for you as well!
  • 5 months later...
Hi!
I'm running a Helix floor 2.92 and have very bad tracking on the tuner. It wasn't there on 2.91 - anyone have the same issue?
Mic input quit last week too.... not good.
Completely lost sound at last rehearsal, most likely to receiving Phantom power, it worked OK when I got home though.
I would hate to have an external tuner, or headstock tuner, it defeats the purpose of the Helix.
1 hour ago, ChristianBoddum said:
Hi!
Perform a factory reset:
If that doesn't work, open a support ticket.
AFAIK, phantom power will make it sound weird, but shouldn't damage the unit.
