ecmares Posted July 6, 2020 Share Posted July 6, 2020 Hello. I was wondering if I could get some help with my situation. When I listen through the headphone output of my Helix Floor, the panning/volume is all wonky. With the phones knob all way down, I am still getting sound out of my right speaker (sound of whatever patch I use. The issue is across all my patches). As I turn the volume up, the left speaker comes in until the sound is panned center, as it should be, at halfway (volume knob turned up halfway). I've tried different 1/4 inch adapters and the issue persists. Also, this seemingly started happening out of nowhere. I do not recall making any changes to global settings, but perhaps that is where the problem is. I am updated to firmware version 2.92 and have been since it was released. Everything has been working fine until now. If anybody could help me figure this out, I would really appreciate it! Thank you. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted July 8, 2020 Share Posted July 8, 2020 If you haven't figured this out yet, do a factory reset (don't forget to back up first!). If that doesn't fix it open a support ticket. It's a very unusual problem, as the lack of responses indicates. Quote Link to comment Share on other sites More sharing options...
qwerty42 Posted July 9, 2020 Share Posted July 9, 2020 There have been a few reports of similar issues on this forum. In some cases it appeared to be fixed by a factory reset; in others it was a hardware problem. Before you give up, do what rd2rk said, and also try a different pair of headphones or speakers to make sure it's not your 'phones. Quote Link to comment Share on other sites More sharing options...
ecmares Posted July 12, 2020 Author Share Posted July 12, 2020 Thank you for your suggestions, you guys. I tried a factory reset; no dice. On a whim, I decided to clean the pot with a cloth and it helped immensely! Very strange, since there was no crackling to indicate it was dirty but hey, it helped! Just a note, there is still just the tiniest bit of sound in the right speaker of any headphones I try when the volume is turned down, but the panning issue is gone. I will probably try some contact cleaner when I can get my hands on some. 1 Quote Link to comment Share on other sites More sharing options...
qwerty42 Posted July 12, 2020 Share Posted July 12, 2020 1 hour ago, ecmares said: Thank you for your suggestions, you guys. I tried a factory reset; no dice. On a whim, I decided to clean the pot with a cloth and it helped immensely! Very strange, since there was no crackling to indicate it was dirty but hey, it helped! Just a note, there is still just the tiniest bit of sound in the right speaker of any headphones I try when the volume is turned down, but the panning issue is gone. I will probably try some contact cleaner when I can get my hands on some. That is very odd indeed... how did you clean it? Just wondering if whatever you did changed something else incidentally (e.g., maybe a cracked solder joint that got bumped back into good contact again). Also FWIW, my Helix is only a year old and it has a very faint sound in the right channel with the Phones knob all the way down too. I'm pretty sure it's always been this way. It's barely perceptible but it's there, and you have to turn the volume up just a smidge beyond minimum before the left channel comes in and then they balance out. Patches that have higher output levels are easier to hear this with, while it can't really be heard at all with low output level patches. Quote Link to comment Share on other sites More sharing options...
ecmares Posted July 12, 2020 Author Share Posted July 12, 2020 20 hours ago, qwerty42 said: That is very odd indeed... how did you clean it? Just wondering if whatever you did changed something else incidentally (e.g., maybe a cracked solder joint that got bumped back into good contact again). I popped the knob off the pot and saw dust and dirt around the base of the shaft. So, I just used a cloth to clean it up. Perhaps you're right; as I was cleaning, maybe it got turned in such a way where good contact was made. In any case, hopefully this can help somebody else. Not that I encourage anybody to void their warranty, but this issue could be as simple as a soldering touch up/pot replacement. I bought my Helix used, so I'm kind of on my own :/ 1 Quote Link to comment Share on other sites More sharing options...
glanum3 Posted November 18, 2021 Share Posted November 18, 2021 Did you ever find a solution to this problem? Quote Link to comment Share on other sites More sharing options...
ecmares Posted November 19, 2021 Author Share Posted November 19, 2021 Not quite. I'm fairly certain it is electrical/mechanical, and have singled out the expression pedal as the possible culprit. I've noticed that by messing with it (i.e. gently stomping on it against my carpet floor) it caused some loud popping and eventually was fixed. I'm guessing maybe there is some wire or something loose? In any case, every so often it'll happen again and I just do the same thing. Maybe someday I'll take it in somewhere... Quote Link to comment Share on other sites More sharing options...
gwelbor Posted November 20, 2021 Share Posted November 20, 2021 I'm having the identical symptoms. Faint sound in right speaker when turned all the way down. Most of the output going to left speaker as you turn up the volume on headphones. Appreciate any other tips or suggestions. I tried the 5+6 global reset, but no change in symptoms. Any other resets suggested? Quote Link to comment Share on other sites More sharing options...
datacommando Posted November 22, 2021 Share Posted November 22, 2021 On 11/20/2021 at 6:36 PM, gwelbor said: Any other resets suggested? As you have already tried FS 5&6 Global Reset, there aren’t really anymore that may clear a possible glitch. For your reference, here is a full list of reset options: https://helixhelp.com/tips-and-guides/universal/reset-options Hope this helps/makes sense. Quote Link to comment Share on other sites More sharing options...
rolly99 Posted May 19, 2022 Share Posted May 19, 2022 On 7/6/2020 at 9:52 PM, ecmares said: Hello. I was wondering if I could get some help with my situation. When I listen through the headphone output of my Helix Floor, the panning/volume is all wonky. With the phones knob all way down, I am still getting sound out of my right speaker (sound of whatever patch I use. The issue is across all my patches). As I turn the volume up, the left speaker comes in until the sound is panned center, as it should be, at halfway (volume knob turned up halfway). I've tried different 1/4 inch adapters and the issue persists. Also, this seemingly started happening out of nowhere. I do not recall making any changes to global settings, but perhaps that is where the problem is. I am updated to firmware version 2.92 and have been since it was released. Everything has been working fine until now. If anybody could help me figure this out, I would really appreciate it! Thank you. Exacly the same experience with Bose headphones. Turned low the right one is active, turning up only right. I had this issue ca. 1.5 years ago. Then it changed to goog, by exchanging all the cables over the weeks, turning them left to right and the other way around. Suddenly it was OK, but i did not realize, what action was the solving of the REALLY NERVING Problem. And now: It is back again!!!! Nerving! I did not any changes. Just turned it on and it was there. Ordered new Cables... nothing changes. THIS MUST BE A CONSTANT BUG! Any help? Quote Link to comment Share on other sites More sharing options...
stigvai Posted November 5, 2022 Share Posted November 5, 2022 My Helix does some of the same... It tyrning the volume up and down by is self... Some time it loud some time not.. It chancing while i using it... So fustrating.. Quote Link to comment Share on other sites More sharing options...
Noosphere01 Posted April 30, 2023 Share Posted April 30, 2023 Did anyone ever find out why the Helix is doing this? I just submitted a ticket for this issue. Quote Link to comment Share on other sites More sharing options...
Jamiegaskin107 Posted August 15, 2023 Share Posted August 15, 2023 Also having the same issue and no luck with factory resets or cleaning the jack Quote Link to comment Share on other sites More sharing options...
rd2rk Posted August 15, 2023 Share Posted August 15, 2023 IDK about those who are reporting sound on one side when hard panned the other way or volume all the way down, I've never had the problem. For those who report unbalanced R/L levels, check anything in the signal chain that's stereo. Not just panning, but Stereo cabs/IRs. Different speakers/IRs and or mics used in the Helix Dual Cab/IR Blocks will output different levels. Likewise, fx in split paths can have different apparent levels, even if the actual levels are equal. Just some thoughts. Since I've never had the problem, I can't suggest an absolute solution. One thing though. If you open a support ticket and get a solution, PLEASE come back here and tell the rest of the community! 2 Quote Link to comment Share on other sites More sharing options...
Smashcraaft Posted August 19, 2023 Share Posted August 19, 2023 From my experiences in handling Hard- and Software and even developing and selling my own Antiperspirant-line I found out that of 100 People having a problem Just 80 recognize that there is a problem which should be taken a closer look at. The other 20 don't even care. 20 out of 80 will search for help in the WWW. 10 will contact the seller or manufacturer for help, after searching the web. 1 of those will come back to a forum or group to help others with the solution. 90 % will rant about the problem, seller, manufacturer and all the big efforts they have made. But nothing helped :/ 1 Quote Link to comment Share on other sites More sharing options...
datacommando Posted August 19, 2023 Share Posted August 19, 2023 On 8/19/2023 at 2:21 PM, Smashcraaft said: 1 of those will come back to a forum or group to help others with the solution. I think you would be very lucky to find that single one in this forum. Only very occasionally does anyone bother to update a thread, where they may have been desperate to find a solution. If they contacted Customer Support, and solved the problem, it would be nice to know how, just for all the other "Me too" posters. I think that a lot of the time it might be due to sheer embarrassment, after having kicked up a fuss about something that then, ultimately, could turn out to be user error. Having said that, there are always going to be lots of "update bricked my Helix" posts, of which, many really are self inflicted, but it's very nice when some one actually takes time to post a "thank you". I always give those folks an upvote. Otherwise it can feel as if you are banging your head against a brick wall. 1 Quote Link to comment Share on other sites More sharing options...
dreamseller Posted August 24, 2023 Share Posted August 24, 2023 I have had same issue last evening. I opened the back plate of Helix and cleaned everyting with compressed air. It worked for me :) Quote Link to comment Share on other sites More sharing options...
guillermocaez Posted November 4, 2023 Share Posted November 4, 2023 Hi guys, I don’t usually comment on forums, but I spent many hours finding a solution, here it is. The issue is with the Phones Pot, you only have to clean it with some electronic cleaner and that’s it. I leave here the solution after hours of dealing with this. Pretty sure this will fix it, please make sure the electronic cleaner goes inside the pot and move it all way down and up a few times. seems dust get stuck inside the pot and this does not make work as usual. 1 Quote Link to comment Share on other sites More sharing options...
tptptp Posted December 24, 2023 Share Posted December 24, 2023 Compressed air worked for me. I was skeptical. It's been a few days and it's still ok. Simply pulled the headphone volume knob up and off the pot. There's a small hole to the left of the pot shaft where it emerges from the panel. Shot the compressed air in there and bingo! Have to think that the hole could be the source of the trouble. Should I put some tape over it to prevent debris passing through? Can't think of a downside? Quote Link to comment Share on other sites More sharing options...
theElevators Posted December 25, 2023 Share Posted December 25, 2023 I vacuum my Helix periodically. Like one time I played a gig and the stage was not just dusty, it had like pieces of threads and foam. This stuff is definitely no good inside the electronics. I dusted off my Helix after the show and vacuumed it first thing when I got home. I put a hose to every button and jack. Also it’s a good idea to cover the Helix when not in use. I put a microfiber cloth on it and cover it with the plastic it came with. The microfiber absorbs all the dust particles pretty well. Quote Link to comment Share on other sites More sharing options...
tptptp Posted September 6, 2024 Share Posted September 6, 2024 Update: Still having an issue with the headphone out. I was fooled into thinking that the issue was resolved because of the behaviour of phones output. If the phone output dial is set to just below 9 o'clock, the left and right channels are balanced and sound ok. And here's the unexpected behaviour: If the the output dial is turned all the was anti-clockwise (about 7 o'clock) then the left channel has no output, as expected, but the right continues to have some output, albeit reduced in volume. If the output dial is then turned clockwise, to about 2 or 3 o'clock, the left channel's output increases normally without distortion, but the right channel's output increases at a lesser rate and sounds distorted and crackly. Confirmed this behaviour with 3 headphones. Ideally, there's solution, but I can live it if I limit myself to using the headphones with the output set just below 9 o'clock. Quote Link to comment Share on other sites More sharing options...
theElevators Posted September 15, 2024 Share Posted September 15, 2024 On 9/6/2024 at 8:37 AM, tptptp said: Update: Still having an issue with the headphone out. I was fooled into thinking that the issue was resolved because of the behaviour of phones output. If the phone output dial is set to just below 9 o'clock, the left and right channels are balanced and sound ok. And here's the unexpected behaviour: If the the output dial is turned all the was anti-clockwise (about 7 o'clock) then the left channel has no output, as expected, but the right continues to have some output, albeit reduced in volume. If the output dial is then turned clockwise, to about 2 or 3 o'clock, the left channel's output increases normally without distortion, but the right channel's output increases at a lesser rate and sounds distorted and crackly. Confirmed this behaviour with 3 headphones. Ideally, there's solution, but I can live it if I limit myself to using the headphones with the output set just below 9 o'clock. Maybe it's your 1/4" -> 1/8" adapter then? That's bizarre. It should be changing the sound programmatically. it's not a physical volume pot. Quote Link to comment Share on other sites More sharing options...
tptptp Posted September 24, 2024 Share Posted September 24, 2024 On 9/15/2024 at 10:20 PM, theElevators said: Maybe it's your 1/4" -> 1/8" adapter then? That's bizarre. It should be changing the sound programmatically. it's not a physical volume pot. One of the three sets of headphones I tried has a 1/4" jack -- no adapter in play. Quote Link to comment Share on other sites More sharing options...
tptptp Posted yesterday at 04:19 AM Share Posted yesterday at 04:19 AM Update: Took my Helix to an authorised repairer. Diagnosis: headphone pot needs replacement. The tech also noticed that the main output level was unusually low. While I was there, we confirmed this was so, by comparing mine to another Helix that was in for service. The cause is failure of coupling capacitors. Apparently, these have a given life-span that can be reduced by exposure to heat. My Helix is 10 years old, which depending on your point of view, may or may not be a long time. I will say that my now ancient HD 500 and DT 25 are both still functioning well. It's taken too long to get these issues resolved -- and the Helix is still with the tech -- but I'm happy that a resolution is in sight. Quote Link to comment Share on other sites More sharing options...
