Samdbl Posted August 30, 2020 Share Posted August 30, 2020 I have the hx effects and the hx stomp. I like them both, but I have experienced one nightmare after another trying to make external expression pedals work. I have tried a few Volume and expression pedals from various companies including some of the most common ones (vp jr, being one). All seem to have a notorious incompatibility that causes the 0-100-0 sweep. After months of trying to get these pedals to work, I finally got one to work with the hx effects. The hx stomp is a different story. Please, for the love of god, just tell me what pedals work with this damn thing so I don’t have to keep buying and returning, or worse yet getting stuck with them. And it would be really swell if it’s not some custom built, $300 pedal that can’t be ordered from a typical music store (ie mission). I’m looking for the cheapest solution. In the endless research for this error, I keep seeing mention of a list of compatible models. But I can never find the actual list, can someone post it? Or better yet, sticky the damn thing. Quote Link to comment Share on other sites More sharing options...
lou-kash Posted August 30, 2020 Share Posted August 30, 2020 I had a Roland EV-5 lying around since about 10 years. In its original state, plugged in directly it has worked after tweaking the Global Settings on the HX Stomp (v2.92) accordingly. Not sure if it really worked that well when using a Y cable though. Perhaps I ended up using some patch "TRS-to-TS" cables in between, don't remember. Hence eventually I've modified the EV-5 anyway, removed its silly firm TRS cable, installed a TRS socket instead, plus a small switch to vary the socket between TRS and "true" TS mode. Now I'm using a Y cable for the EV-5 in TS mode on tip for pedal 1, and an old switch on ring for FS5. Works flawlessly. 2 Quote Link to comment Share on other sites More sharing options...
Schmalle Posted August 30, 2020 Share Posted August 30, 2020 I bought a cheap Doner Viper expression pedal from Amazon for about 30 Euros. Opened it, bended the ring metal sheet of the output jack so it doesn't make contact- that was it. 1 Quote Link to comment Share on other sites More sharing options...
datacommando Posted August 30, 2020 Share Posted August 30, 2020 8 hours ago, Samdbl said: In the endless research for this error, I keep seeing mention of a list of compatible models. But I can never find the actual list, can someone post it? Or better yet, sticky the damn thing. Fabled list? The unicorns stole it! Cheap and easy solution that works for me, and many others, is the inexpensive M-Audio expression pedal. So low priced you could have several for the price of one Mission pedal - plus it does the job exactly the same. Downside: Plastic, not metal case, although quite resilient. https://m-audio.com/products/view/ex-p I have 2 hooked up to my floor model and they’re used every day. There were discussions here - no fables though And here Plus this one And finally Quote Link to comment Share on other sites More sharing options...
codamedia Posted August 30, 2020 Share Posted August 30, 2020 10 hours ago, Samdbl said: it would be really swell if it’s not some custom built, $300 pedal that can’t be ordered from a typical music store (ie mission). I’m looking for the cheapest solution. The M-Audio EX-P is the cheapest solution I can think of ... roughly $30. There are two modes and a side pot... you need to find the correct positions but it works fine once you do. The Line 6 EX-1 would be the easiest... just plug it in and it works without trial and error. This one is still under $100.... I think I got mine for $40 on the used market. Quote Link to comment Share on other sites More sharing options...
Samdbl Posted September 3, 2020 Author Share Posted September 3, 2020 Ok, the saga continues. So I got the M Audio, and it works great. However, it has the cable attached. So I can't figure out how I can also get another input so that I can use my footswitch for tap/tuner. The M Audio has a cable integrated into it's design, so I can't do the normal Y cable method. Any ideas? Sidenote: over and over I see that the Line 6 wants to see TS instead of TRS cable for expression and such... but the M Audio, the first that I've found that works correctly with this unit, is using a TRS cable. What's up with that? Sidenote # 2: My trusty VP Jr works just perfectly with the HX effects. Why wouldn't this be universal across the line? 1 Quote Link to comment Share on other sites More sharing options...
lou-kash Posted September 3, 2020 Share Posted September 3, 2020 1 minute ago, Samdbl said: So I got the M Audio, and it works great. However, it has the cable attached. So I can't figure out how I can also get another input so that I can use my footswitch for tap/tuner. The M Audio has a cable integrated into it's design, so I can't do the normal Y cable method. Any ideas? Y cable > TS-female-to-TRS-female adapter > M-Audio cable That's how I made the EV-5 (see above) work at first before even modyfing it. 5 minutes ago, Samdbl said: Sidenote: over and over I see that the Line 6 wants to see TS instead of TRS cable for expression and such... but the M Audio, the first that I've found that works correctly with this unit, is using a TRS cable. What's up with that? I think it's because the recent firmware updates got smarter in detecting the "nature" of an expression pedal. My modified EV-5 plugged in directly in TRS mode works flawlessly with v2.92. But when used with a Y cable, it needs to be in the TS mode. Quote Link to comment Share on other sites More sharing options...
lou-kash Posted September 3, 2020 Share Posted September 3, 2020 https://duckduckgo.com/?q=TS-female-to-TRS-female+adapter&iax=images&ia=images Quote Link to comment Share on other sites More sharing options...
Samdbl Posted September 9, 2020 Author Share Posted September 9, 2020 On 9/3/2020 at 5:16 PM, lou-kash said: https://duckduckgo.com/?q=TS-female-to-TRS-female+adapter&iax=images&ia=images yeah, but none of those really specify ts to trs. In fact, I did just get one of the ones on that picture line up, and it’s still not working. I got a female to female coupler that will link two male 1/4 cables... and it says tr and/or trs. But yeah, it’s still not working with the y cable setup. Is there something more specific I need? this feature is so silly. They should’ve just put another pedal input on the unit as a posed to some hyper specific thing you have to scour the earth for to make two of the most basic features work. Quote Link to comment Share on other sites More sharing options...
lou-kash Posted September 9, 2020 Share Posted September 9, 2020 (edited) 16 minutes ago, Samdbl said: but none of those really specify ts to trs Um, I haven't analyzed those search results myself. That was just a gentle hint that a specific internet search may help you find what you need. You could also solder an adapter yourself. That's what I do since decades. If you don't know how to solder, ask your friends/relatives/neighbors if someone can do it for you. Since this connection is not transporting any audio signal, there's not much that can actually break if something is connected incorrectly. Either it will just work or it won't. On 9/3/2020 at 10:39 PM, Samdbl said: it has the cable attached That's the problem with those cheap things. 16 minutes ago, Samdbl said: I got a female to female coupler that will link two male 1/4 cables... and it says tr and/or trs. That's a good start, but it's still TRS-to-TRS That means if you plug the TS from the Y cable, it will short the ring and the sleeve from the pedal. Have you tried all the "EXP/FS Tip", "EXP/FS Ring", "Tip Polarity" and "Ring Polarity" options in the Global Settings? Depending on how the M-Audio pedal is wired inside, one of these combinations might actually work. Edited September 9, 2020 by lou-kash Quote Link to comment Share on other sites More sharing options...
Samdbl Posted September 9, 2020 Author Share Posted September 9, 2020 God of gods after trying a slew of combinations that I had already tried, it finally works. my last question and I’ll be set for ages: how do I tell the stomp that I want the toe down of the pedal to be less that 10? In other words, if I want my full channel volume to be 6, or something? Quote Link to comment Share on other sites More sharing options...
lou-kash Posted September 9, 2020 Share Posted September 9, 2020 3 hours ago, Samdbl said: how do I tell the stomp that I want the toe down of the pedal to be less that 10? In other words, if I want my full channel volume to be 6, or something? Edit mode > select the effect > open Menu via Page buttons > Controller Assign > Page Right button > Min Value / Max Value or HX Edit > select the effect > Bypass/Controller Assign tab > select the parameter > Min Position / Max Position 1 Quote Link to comment Share on other sites More sharing options...
soundog Posted January 18, 2021 Share Posted January 18, 2021 Just rewired a beat up old Ernie Ball VP JR volume pedal with a linear taper 25k pot. Put in a new string just for added fun. Its working perfectly with my Stomp, so I wired a little "fourth" switch on the side of the Stomp for using the tuna in Snapshot mode. Quote Link to comment Share on other sites More sharing options...
carlosferrao Posted September 3, 2021 Share Posted September 3, 2021 My M-Audio used to work perfectly until patch 3.0 (or maybe 3.1?) and then it stopped working, or rather, its values go from 96% to 100%, or from 0% to only 60%, etc. Any other off-the-shelf exp pedal works? Quote Link to comment Share on other sites More sharing options...
datacommando Posted September 3, 2021 Share Posted September 3, 2021 16 hours ago, carlosferrao said: My M-Audio used to work perfectly until patch 3.0 (or maybe 3.1?) and then it stopped working, or rather, its values go from 96% to 100%, or from 0% to only 60%, etc. Any other off-the-shelf exp pedal works? Strange, I have 2 M-Audio EXP permanently hooked up to my Helix since 2016. Working perfectly, never any issues. Possibly a Global reset has changed something. Hope this helps/makes sense. 1 Quote Link to comment Share on other sites More sharing options...
carlosferrao Posted September 4, 2021 Share Posted September 4, 2021 It worked! Reset it holding 5+6 and all of a sudden it was working again. Thank you. 1 Quote Link to comment Share on other sites More sharing options...
carlosferrao Posted September 4, 2021 Share Posted September 4, 2021 And now after switching it on again after the global reset, it's back to behaving oddly. I'll contact support. 1 Quote Link to comment Share on other sites More sharing options...
gvaslin Posted January 23, 2022 Share Posted January 23, 2022 Hi, I'm using an Ernie Ball VPJr as expression pedal and I'd like to use it to activate or deactivate PolySustain block... In a part it works because going from heel to toes it switches on the block but at the end of the course it switches off again !? Do you know how I can do to only have a on/off action pushing from heel to toes ? Thanks for your help ! Quote Link to comment Share on other sites More sharing options...
fazz1977 Posted October 25, 2024 Share Posted October 25, 2024 The Nektar NX-P Is a super budget expression pedal, cheaper than the M Audio, and works out of the box on HX stomp with no mods. Plug n play! No issues whatsoever. https://nektartech.com/np-1_np-2_nx-p/ Quote Link to comment Share on other sites More sharing options...
