markwesse Posted November 15, 2023 Share Posted November 15, 2023 I have just had to pay $200 to have the mic preamp/phantom chip replaced...ok its fragile. This happened before I got it (2nd hand) when the guy was demoing and plugged a dynamic in with phantom on and it killed it. So my question is, does the frailty extend to having a mic plugged in, with phantom on and then booting. Do I sit there in terror at a gig while it boots, praying that the phantom wont die? (since I use a pga181 for live vocals...which is actually brilliant btw) Quote Link to comment Share on other sites More sharing options...
brue58ski Posted November 15, 2023 Share Posted November 15, 2023 I have never heard of either scenario. Are you sure the guy was truthful when describing how the chip got burned out. Quote Link to comment Share on other sites More sharing options...
Schmalle Posted November 15, 2023 Share Posted November 15, 2023 I can't comment on what actually caused the "frying of the chip" without knowing the circuit (and mic and cabling). But here is an educated guess of the cause: When you plug in a mic then two the XLR contacts are connecting only roughly simultaneously. It's possible that plugging in a electrostatically charged mic isn't connected to ground for a very short moment and discharging happens partly through the phantom power circuit - it's only a small fraction of a second but the current might be high enough to damage something in the circuit. So taking this hypothesis seriously there is no need to fear when the mic is already plugged in. It seems to be a good rule of thump to put the phantom power off before you plug or unplug a mic. Quote Link to comment Share on other sites More sharing options...
datacommando Posted November 15, 2023 Share Posted November 15, 2023 On 11/15/2023 at 10:21 AM, markwesse said: So my question is, does the frailty extend to having a mic plugged in, with phantom on and then booting. Hi, There appears to be very little specific info about this subject, other than this statement from the Helix Owner’s Manual. ”IMPORTANT! Never connect the Helix device’s XLR outputs to a device whose XLR inputs have 48V phantom power enabled!” Clear as mud! Hope this helps/makes sense. Quote Link to comment Share on other sites More sharing options...
brue58ski Posted November 15, 2023 Share Posted November 15, 2023 I asked about what the guy did because I've never heard of that before. And I've plugged many a mic into phantom power with no issues. Quote Link to comment Share on other sites More sharing options...
Schmalle Posted November 15, 2023 Share Posted November 15, 2023 On 11/15/2023 at 2:34 PM, datacommando said: Hi, There appears to be very little specific info about this subject, other than this statement from the Helix Owner’s Manual. ”IMPORTANT! Never connect the Helix device’s XLR outputs to a device whose XLR inputs have 48V phantom power enabled!” Clear as mud! Hope this helps/makes sense. Not sure what the XLR outs have to do with the mic in. Quote Link to comment Share on other sites More sharing options...
datacommando Posted November 15, 2023 Share Posted November 15, 2023 On 11/15/2023 at 6:27 PM, Schmalle said: Not sure what the XLR outs have to do with the mic in. Exactly - I think they must mean that if Phantom Power in the Helix is turned, on and you connect to FOH via XLR and that also has Phantom Power engaged. Quote Link to comment Share on other sites More sharing options...
TLF2007 Posted November 15, 2023 Share Posted November 15, 2023 I had to get the io board replaced in my Helix due to "hot swapping" condenser (48V Phantom) mics. Now when I use them, I plug it, turn it on. Use accordingly, then turn off and take the mic out 1 1 Quote Link to comment Share on other sites More sharing options...
line-6-user Posted November 22, 2023 Share Posted November 22, 2023 On 11/15/2023 at 6:47 PM, TLF2007 said: I had to get the io board replaced in my Helix due to "hot swapping" condenser (48V Phantom) mics. Now when I use them, I plug it, turn it on. Use accordingly, then turn off and take the mic out The same happened to me. I also plug and unplug the same way as you do. I always worry if it fries the chip again... Maybe the device could have been designed better? Quote Link to comment Share on other sites More sharing options...
markwesse Posted November 22, 2023 Author Share Posted November 22, 2023 I have been hot plugging/mute for 30 years and never an issue...EVER lol Until...Helix. I got it fixed and the tech said it was a pretty frail design. He had never replaced a fry due to hot plugging Ribbons on phantom and bad cables...is a completely different thing :-) Now I have to remember when setup is done at the gigs, not to let anyone plug my mic in (which is mostly for a custom mic on guitar) until everything is booted...yet another management issue! Its from the studio but it really works live...esp on 12 string...SDCs rule! Quote Link to comment Share on other sites More sharing options...
