jasonahoule Posted June 10 Share Posted June 10 I have been using the stomp to send midi messages to a laptop to trigger sound effects and audio clips. During my bands practice last night it just stopped working. I have verified with two different laptops and multiple software that the stomp is no longer sending midi over usb. I have triple checked the config parameters and everything is as it should be, I have replaced the cable, and I even tried a factory reset. Does anyone have any other trouble shooting ideas? I am at a loss. It worked fine one song and nothing the next. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted June 10 Share Posted June 10 Are all of your computers Windows 11? A recent update (maybe several) caused the problem. On one of my W11 boxes the problem was caused by a ".net Framework" update (KB5092427). Rolling back to a restore point previous to that update and preventing Windows Update from reinstalling it fixed the problem. On another W11 box I didn't have a similar restore point and simply uninstalling (KB5092427) didn't fix it. On my last remaining W10 box it's not an issue, USB MIDI works fine. 3 Quote Link to comment Share on other sites More sharing options...
theElevators Posted June 17 Share Posted June 17 Check the midi channel on the stomp is selected correctly? Quote Link to comment Share on other sites More sharing options...
TheManx Posted July 16 Share Posted July 16 Was working for me fine yesterday, then not today. MIDI over the MIDI cable was fine. All other MIDI USB controllers I have were fine. Triple checked the settings on the Helix. Using MIDI tester: https://hardwaretester.com/midi in case it was my DAW or its settings. Rebooted the PC and restarted the Helix. None of it did anything to help. Until I rolled back the latest security patch from yesterday: KB5101650 Now it works fine. (Until the next patch?) Quote Link to comment Share on other sites More sharing options...
rd2rk Posted July 16 Share Posted July 16 @jasonahouleDid you ever resolve this? Quote Link to comment Share on other sites More sharing options...
danielseb93 Posted July 17 Share Posted July 17 Hello everyone, I’m experiencing an issue with my Helix Floor after updating my PC to Windows 11 version 24H2. The device is recognized by the system and appears in ShowMIDI, but it does not send any MIDI data into Reaper or any other DAW. On Windows 10, the same Helix unit works perfectly. On Windows 11 24H2, the Helix is detected but no MIDI messages are transmitted. I have already tried reinstalling Line 6 drivers, cleaning hidden devices, resetting Helix global settings, and testing different USB ports. I also confirmed that I do not have the update KB5092427 installed, which some users mentioned could be related. Has anyone found a workaround or confirmation from Line 6/Microsoft about driver compatibility with the new MIDI stack in Windows 11 24H2? Thanks in advance for any help or insights! Quote Link to comment Share on other sites More sharing options...
silverhead Posted July 17 Share Posted July 17 Another patch culprit mentioned above is KB5101650. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted July 17 Share Posted July 17 On 7/17/2026 at 2:46 PM, danielseb93 said: Hello everyone, I’m experiencing an issue with my Helix Floor after updating my PC to Windows 11 version 24H2. The device is recognized by the system and appears in ShowMIDI, but it does not send any MIDI data into Reaper or any other DAW. On Windows 10, the same Helix unit works perfectly. On Windows 11 24H2, the Helix is detected but no MIDI messages are transmitted. I have already tried reinstalling Line 6 drivers, cleaning hidden devices, resetting Helix global settings, and testing different USB ports. I also confirmed that I do not have the update KB5092427 installed, which some users mentioned could be related. Has anyone found a workaround or confirmation from Line 6/Microsoft about driver compatibility with the new MIDI stack in Windows 11 24H2? Thanks in advance for any help or insights! See my previous post. Down load this: Get Windows MIDI Services SDK Runtime and Tools - Windows MIDI Services If you get a not present type message when you run it, you'll just have to keep running Windows Update and installing the updates (including the optional updates) until Microsoft gets around to sending you the correct update. No way to push it except possibly SYSTEM>RECOVERY> FIX PROBLEMS USING WINDOWS UPDATE. IIRC, this worked on one of my machines by forcing the update. If you decide to try this, be sure to set a RESTORE POINT. It shouldn't break anything but, you know, Windows... Quote Link to comment Share on other sites More sharing options...
TheManx Posted August 28 Share Posted August 28 MIDI broke again this week despite having stopped Windows updates - and seemed like nothing got automatically updated without my OK. Seems like its all due to the Windows 11 MIDI 2.0 updates - issues with are discussed here: https://devblogs.microsoft.com/windows-music-dev/windows-midi-services-rollout-known-issues-and-workarounds/ On that discord discussion a recent update allows for rolling back the MIDI 2.0 to legacy while still keeping Windows up to date: https://microsoft.github.io/MIDI/kb/how-to-change-api-mode/ I've updated Windows and set the MIDI API Mode to Legacy, and all is well. Somewhere on the Discord was mentioned that a big drop is expected in November which may address the bug with the Helix and other devices that aren't 'Class Compliant'. Quote Link to comment Share on other sites More sharing options...
guix Posted October 24 Share Posted October 24 Couldn't this be solved by a new Helix Driver!??? @Digital_Igloo? Quote Link to comment Share on other sites More sharing options...
