Automatically changing Pod HD Pro X patches in reaper
Ayiangoullis
So I use an m-audio midiport to change my pod's patches during live shows. However when a patch changes, there is a small interruption of sound (for about half a second) which sounds bad in the mix... Is there a way to make the change faster?
If not, I basicly change between rythm and lead patches, so can I change some parameters of the patch (like turning pedals on/off. or amp settings) using MIDI signals? I just want to make our live sound as perfect as it can get...
There is going to be an audible interruption when changing patches. Not much you can do about that except timing it as best you can, or writing the music to accommodate for it.
Ok. But can I change other parameters, like I said above, with the midi interface?
You can turn effects on and off within a preset by sending the CC# associated with the footswitch you have them assigned to in the preset. As far as controlling parameters directly, you can't do it. You can control some indirectly by assigning them those EXP1 or EXP2 and controlling those with MIDI.
