sigitar Posted October 29, 2015 Share Posted October 29, 2015 Hi, Is there a in-depth-description of the FX-parameters? The accordingly M13-manual is not really compliant. Thanks 1 Quote Link to comment Share on other sites More sharing options...
duncann Posted October 29, 2015 Share Posted October 29, 2015 For some of the Line 6 original effects, you can sort of find out what some parameters do through experimentation. At least what they do sonically but not necessarily technically. For other models, take a look at the manual to find out what an effect is modeled from, and then search the internet for that effect for an explanation of the parameters. It would be helpful for Line 6 to provide a nicely laid out document for this though. Quote Link to comment Share on other sites More sharing options...
jaeger28 Posted October 29, 2015 Share Posted October 29, 2015 Yea please. Use an intern to write it up in English. Some of the parameters are neither self explaining, nor available in the originals. Quote Link to comment Share on other sites More sharing options...
spawn2031 Posted October 29, 2015 Share Posted October 29, 2015 According to DI, the effects have been modeled to behave as close to the real thing as possible. So if you want to know how to use an effect, look up how to use the item it was modeled after and you should be good to go. Quote Link to comment Share on other sites More sharing options...
cornerstonetom Posted October 29, 2015 Share Posted October 29, 2015 What "spawn2031" said is right AND make sure your monitor is flat in terms of EQ. Some monitors, while seemingly "flat" are actually weighted to either accentuate or attenuate certain frequencies, mainly mids in most cases. Quote Link to comment Share on other sites More sharing options...
brue58ski Posted October 29, 2015 Share Posted October 29, 2015 Most effects don't have a mix parameter, for example, and based on some things in the "Bug" pinned post, it doesn't always react the way you would expect. A least create something that tells me what the extra parameters are and where they need to be to be "normal". Quote Link to comment Share on other sites More sharing options...
PiFromBRC Posted October 30, 2015 Share Posted October 30, 2015 Perhaps this is an opportunity for a Crowd Sourced Answer. I doubt the original models (those which were used to create the FX, Amp, and Cab models) are going to be too thrilled with Line 6 copying or linking their manuals. So, for instance, IF the Helix had an MXR Distortion + model, one would post a link to a pinned topic: http://www.jimdunlop.com/files/manuals/M104_man_WEB.pdf Quote Link to comment Share on other sites More sharing options...
ronaldoolson Posted January 16, 2017 Share Posted January 16, 2017 Where are the Trem effects ? A lot of the effects in the M13 are missing - ? Quote Link to comment Share on other sites More sharing options...
phil_m Posted January 16, 2017 Share Posted January 16, 2017 Where are the Trem effects ? A lot of the effects in the M13 are missing - ? There are three different tremolo effects - Optical Trem, Bias Trem and the one just called Tremolo, which is actually the deepest as far as parameters available for editing. Quote Link to comment Share on other sites More sharing options...
gbbaker Posted January 16, 2017 Share Posted January 16, 2017 As for the OP . . . there is a LINE6 WiKia for the HELIX here: www.Line6.WIKIA.com. It is not "complete" but there is a lot of good info and it continues to get better as the community adds info. There is another address which links the Amps, Effects, Cabs and Mics to the original manufacturer's User Manuals but I can't seem to recall that one. I'll do a lttle research and EDIT HERE if I do locate it. See MisicLaw's post below for the other LINKS. Thanks MusicLaw! Bo Quote Link to comment Share on other sites More sharing options...
MusicLaw Posted January 16, 2017 Share Posted January 16, 2017 See: http://dshowmusic.com/line-6-helix-effect-models/ and the other Helix related segments of the site. Each section does contain current content, notwithstanding their original post dates (at the top right of each section) not having been updated. Also see: http://helixhelp.com/pmwiki.php Quote Link to comment Share on other sites More sharing options...
