Sumatra_Gold Posted May 7, 2016 Share Posted May 7, 2016 Hi all, As my post title states, I'm trying to find out the pickup specs in the JTV 89 F, the reason being I have another guitar that truly love just as much as the JTV, but I hate the bridge pup on it. I'm looking to either buy an actual JTV bridge pup, or find a replacement that is a close match specwise. Specifically, I'd like to know what Alnico magnet type is used in that pup along with the DCR if anyone knows. Allegedly this pup is a high output PAF style pup, but a lot of different alnico magnet types have been used in the PAF family and I want to make sure I get an exact match if possible. In researching this I looked at the Seymour Duncan 59 and Little 59 for possible replacements, as this guitar is an SSS pu configuration. The regular 59 boasts an alnico 5, but the Little 59 is ceramic. This worries me as ceramic pickups tend to sound to brittle to my ear. And as for the Alnico 5, I have no idea if that is the magnet used in the JTV 89 pickup set. Any help is, of course, appreciated. Thanks! Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted May 8, 2016 Share Posted May 8, 2016 L6 won't even divulge pickup HEIGHT specs...let alone what's actually under the hood. Doesn't much matter anyway. Having the info isn't gonna help you much. Even if you went out and bought another pickup that claims to have the same magnet in it, there's no predictive value there. Buying pickups is a crap-shoot. Always was, always will be. I've transferred the same pickup from one guitar to another, and had it sound VERY different. It's the combination of guitar and pick-up that either works, or doesn't. Bottom line, if you don't like the pickup in the other axe, try something else. It's all guesswork anyway. Quote Link to comment Share on other sites More sharing options...
stonegroveguitar Posted May 15, 2017 Share Posted May 15, 2017 I know it's been a year since your post, but did you find the pickups that worked? Quote Link to comment Share on other sites More sharing options...
Palico Posted May 15, 2017 Share Posted May 15, 2017 this is like over a year old post, but since someone asked. Don't know the specs but you can get a JTV89 pickup here: http://www.fullcompass.com/prod/235223-Line-6-11-26-0006 Quote Link to comment Share on other sites More sharing options...
Sumatra_Gold Posted May 15, 2017 Author Share Posted May 15, 2017 I did find the replacement from Full Compass. I do appreciate your responses. Thank you!!! Quote Link to comment Share on other sites More sharing options...
specracer986 Posted May 17, 2017 Share Posted May 17, 2017 That description doesn't say if it's a neck or bridge pup. Does that mean both the neck and bridge are the same pup? Quote Link to comment Share on other sites More sharing options...
psarkissian Posted May 17, 2017 Share Posted May 17, 2017 That's a bridge pick-up. http://www.fullcompass.com/category/Guitar-Parts2.html?brand_id=&rewrite_name=Guitar-Parts2&query=&categoryOrder=Bestselling&brand[]=LN6&view=&ipp=24 ... for Line 6 parts in general. There would be a neck pick-up in there as well. Quote Link to comment Share on other sites More sharing options...
sdre9096 Posted February 4, 2018 Share Posted February 4, 2018 Does anyone have and suggestions for pickups that would utilize the 5 way switch on the 89f? I hate the stock PU's Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted February 4, 2018 Share Posted February 4, 2018 Does anyone have and suggestions for pickups that would utilize the 5 way switch on the 89f? "Utilize" how? It's a toggle switch, they all do the same thing...buy whatever pickups float your boat. Quote Link to comment Share on other sites More sharing options...
brue58ski Posted February 4, 2018 Share Posted February 4, 2018 Does anyone have and suggestions for pickups that would utilize the 5 way switch on the 89f? I hate the stock PU's Check this out. It may help https://www.vguitarforums.com/smf/index.php?topic=16980.0 1 Quote Link to comment Share on other sites More sharing options...
Sumatra_Gold Posted February 4, 2018 Author Share Posted February 4, 2018 Any splittable pu should do the trick. So think 4 wire pups here. Then you can utilize the switching array for magnetics in the same way L6 does with the stock P.U.s in your JTV. You'll want to research pups which not only allow you to split the coils, but sound good in that configuration. Not all split coil pups are created equal. Some sound terrible when split, either sounding to thin and/or sounding too shrill. So you'll want humbuckers with a good track record utilizing split coils. Good luck to you! Quote Link to comment Share on other sites More sharing options...
