xpanmanx Posted May 1, 2013 Share Posted May 1, 2013 Greetings, If you've seen my other thread, you know I've just brought home my new tobacco-burst JTV-59 from Guitar Center. It's less than 8 hours old. As I was experimenting with the virtual capo, I found that the model selector knob was loose. The whole shaft seems to be wiggling around, not just the knob. I opened up the cavity and it seems that this 1/2" square housing on the back of the knob is loose. The same square part on the back of the alternate tuning knob is rock-solid. I don't want to simply go back to the store and exchange the guitar because 1> they had only one tobacco-burst model in stock, and 2> I was planning on having a lot of fun at this weekend's gigs with my new toy. GC also doesn't seem to have a tobacco-burst model anywhere except for ship-to-store with a 3-5 day lead time. If Line 6 would send me the replacement part, I'm sure I could install it. If a replacement is necessary. It looks like a really easy job. Or maybe GC could send another guitar to a store near me for an exchange. I'm pretty patient with this kind of thing. As long as everyone's working together. Has anyone else encountered this problem? If so, how did you solve it? Thanks -- Quote Link to comment Share on other sites More sharing options...
clay-man Posted May 1, 2013 Share Posted May 1, 2013 If it is loose, all I can think of suggesting is stuffing a piece of paper between the side of the hole and the part where the knob hangs on to tighten the space between it. Quote Link to comment Share on other sites More sharing options...
xpanmanx Posted May 1, 2013 Author Share Posted May 1, 2013 Thanks, clay-man .... Quote Link to comment Share on other sites More sharing options...
xpanmanx Posted May 2, 2013 Author Share Posted May 2, 2013 I called Line 6 today. After about 40 minutes in the phone queue, I spoke with a support rep who was at first skeptical of the idea that a customer could service a day-old JTV-59. After much discussion, he put me on hold for about 10 minutes, and when he came back, he told me that he'd spoken with a repair tech and .... .... what I needed to do was to remove the encoder cavity cover, then unscrew the two small silver screws on either side of the model encoder bracket. Next, remove the model knob and gently push the encoder shaft to pop the assembly out of the guitar. Invert the encoder assembly and remove the two small black screws which fasten the LED circuit board to the assembly, then remove the LED board itself. Don't disconnect any wires. With the encoder assembly hanging loose, and the LED circuit board detached from the assembly, the shaft nut can be tightened with a 12mm wrench. Add a little LockTite Blue for security. Reassemble and rock on. This took me about 15 minutes. Done, and happy. 6 Quote Link to comment Share on other sites More sharing options...
spmartin Posted May 7, 2013 Share Posted May 7, 2013 As always, I am astounded by the poor level of quality control for a guitar that costs $1,400. You never hear of this with PRS SEs or even Fender Squiers, and they are much less expensive. Is there anything more disheartening than getting a NEW guitar home and having a problem with it?? 1 1 Quote Link to comment Share on other sites More sharing options...
phil_m Posted May 7, 2013 Share Posted May 7, 2013 As always, I am astounded by the poor level of quality control for a guitar that costs $1,400. You never hear of this with PRS SEs or even Fender Squiers, and they are much less expensive. Is there anything more disheartening than getting a NEW guitar home and having a problem with it?? I wouldn't say you never hear about it from those other brands. It's odd you bring up the PRS SEs, because the Variax is actually made in the same factory as those. It's just with added complexity, there's more things that could go wrong. So that means there's more to look for in the way of problems, and it means that there's more that could possibly slip through. It's interesting, I was at a training session/factory tour last week for my work at one of the largest theatrical lighting and controls companies in the world. You've undoubtedly seen their products if you've ever gone to a rock concert or Broadway show. They do most of their manufacturing in the US still, and they actually do a lot of testing on their products before they leave the factory. But even then, they said, "we make electronic equipment, and we know we will have failures sometimes. It just happens." A certain failure rate is simply unavoidable when you're dealing with mass production. 1 1 Quote Link to comment Share on other sites More sharing options...
xpanmanx Posted May 11, 2013 Author Share Posted May 11, 2013 Academic discussion of failure rates generally leads to the consensus that a very low percentage is acceptable. When the discussion becomes practical, it rubs a nerve. You guys probably noticed this in the OP: "I'm pretty patient with this kind of thing. As long as everyone's working together." For such an easy repair, if Line 6 had insisted that my guitar be taken to a service center, it would be back on the hanger at GC, and I'd be playing a new Taylor 314 and getting by on my trusty Tele. Believe me, I understand the complexity of the instrument and the likelihood that a sufficient care must be taken to avoid cascade failure. Fortunately for all involved, Line 6 rose to the occasion and directed me through the repair in the comfort of my own living room :) Quote Link to comment Share on other sites More sharing options...
toneman2121 Posted May 12, 2013 Share Posted May 12, 2013 Academic discussion of failure rates generally leads to the consensus that a very low percentage is acceptable. When the discussion becomes practical, it rubs a nerve. You guys probably noticed this in the OP: "I'm pretty patient with this kind of thing. As long as everyone's working together." For such an easy repair, if Line 6 had insisted that my guitar be taken to a service center, it would be back on the hanger at GC, and I'd be playing a new Taylor 314 and getting by on my trusty Tele. Believe me, I understand the complexity of the instrument and the likelihood that a sufficient care must be taken to avoid cascade failure. Fortunately for all involved, Line 6 rose to the occasion and directed me through the repair in the comfort of my own living room :) what is the repair Quote Link to comment Share on other sites More sharing options...
Dark-Star Posted May 16, 2013 Share Posted May 16, 2013 xpanmanx, Good, you fixed it. I remember the inquiry. Sorry he took a while on the phone with you, it took me a few minutes to show him how it's done, so that he could explain it to you. And it only took about 15-minutes, good. Glad it worked out. Way to go. -The Tech 2 Quote Link to comment Share on other sites More sharing options...
evanteatum Posted June 10, 2013 Share Posted June 10, 2013 SAME thing just happened to mine- Now cant access the MODELED Guitars / cant Custom save - Brans new JTV59 ! Gig Friday w/ Beatles cover project NEED THIS guitar ! 1 Quote Link to comment Share on other sites More sharing options...
theoptimizers Posted June 10, 2013 Share Posted June 10, 2013 I returned a new Black JTV-59P last week because it had a loose selector switch and a flaw on the neck. Customer service is good, but QC seems lacking. 1 Quote Link to comment Share on other sites More sharing options...
evanteatum Posted June 13, 2013 Share Posted June 13, 2013 Quote Link to comment Share on other sites More sharing options...
davidb7170 Posted June 14, 2013 Share Posted June 14, 2013 Can you take the model knob off the shaft on the top of the guitar and get at any nut on the front of the unit? Maybe it can be tightened from that side? You probably can't engage your models because the knob hits the surface of the guitar top because it retreats into the body slightly when you press it down. Just a thought. Others -- chime in here. Dave Quote Link to comment Share on other sites More sharing options...
sonicvent Posted November 18, 2015 Share Posted November 18, 2015 thx for the instructions. You saved me from anxiety attack :P easy fix when you know what to do Quote Link to comment Share on other sites More sharing options...
gregguitarjones Posted January 29, 2016 Share Posted January 29, 2016 Thanks xpanmanx, I had the loose model knob on my JTV 59 and with your instructions I fixed it in 15 minutes. Quote Link to comment Share on other sites More sharing options...
sidsimo Posted January 30, 2017 Share Posted January 30, 2017 I have the same problem , but in reverse. Now when I spin the tunings knob, let's say to DADGAD and beyond, in a clockwise manner, it becomes more restricted. At this point I'm unable to press the "push push" feature. As the owner of several JTV's, I can tell you that these guitars are definitely more complicated than a PRS....but that's apples and oranges. I've had a variety of failures on all but one JTV59. I have 4 of them and one 69...... Anyone out there had to resolve a sticky open tuning/push situation like the one I described? If so, how? thanks. Quote Link to comment Share on other sites More sharing options...
delswick Posted December 13, 2018 Share Posted December 13, 2018 Thanks xpanmanx, 15 minutes and my JTV Goldtop is back in business. But... mad me realize just how good these P90's sound. Quote Link to comment Share on other sites More sharing options...
