GenotypeX Posted December 14, 2016 Share Posted December 14, 2016 Hello, anyboy have any luck recording a HELIX wet and dry signal on seperate tracks similtaniously in Reaper? I'm trying to get a dry siginal recording In Reaper via USB 7-8 but for the life of me can find how to select USB 7-8 in Reaper... :unsure: Quote Link to comment Share on other sites More sharing options...
silverhead Posted December 14, 2016 Share Posted December 14, 2016 The dry track is mono. Default setting in Helix is Guitar input on 7 and mic input on 8 though you can change those. In Reaper you need to set up two tracks for recording, one stereo for the default input of USB1&2 and a mono track for the dry guitar. Once you arm the tracks for recording you can select the Input Source for each track. Select USB7 for the dry track. Quote Link to comment Share on other sites More sharing options...
Chappie Posted December 14, 2016 Share Posted December 14, 2016 The dry track is mono. Default setting in Helix is Guitar input on 7 and mic input on 8 though you can change those. In Reaper you need to set up two tracks for recording, one stereo for the default input of USB1&2 and a mono track for the dry guitar. Once you arm the tracks for recording you can select the Input Source for each track. Select USB7 for the dry track. This definitely works....did it just last night! Helix is so damn cool!! Quote Link to comment Share on other sites More sharing options...
duncann Posted December 14, 2016 Share Posted December 14, 2016 When selecting the audio device, make sure the audio system is ASIO, the ASIO driver is ASIO Helix, the first input is Input 1, last input is Input 8, and the same for the output range, Output 1 and Output 8. It shouldn't be necessary to arm any track for recording to select the input to that track (but you have to arm it to actually record something). If the above is done, there should be an Input Mono -> Input 7 selection available for any track you want to change. 2 Quote Link to comment Share on other sites More sharing options...
Ka5par Posted December 14, 2016 Share Posted December 14, 2016 It shouldn't be necessary to arm any track for recording to select the input to that track (but you have to arm it to actually record something). If the above is done, there should be an Input Mono -> Input 7 selection available for any track you want to change. You need to rec arm it and enable monitoring to hear it though. Quote Link to comment Share on other sites More sharing options...
DarrellM5 Posted December 14, 2016 Share Posted December 14, 2016 When selecting the audio device, make sure the audio system is ASIO, the ASIO driver is ASIO Helix, the first input is Input 1, last input is Input 8, and the same for the output range, Output 1 and Output 8. It shouldn't be necessary to arm any track for recording to select the input to that track (but you have to arm it to actually record something). If the above is done, there should be an Input Mono -> Input 7 selection available for any track you want to change. This is what I ran into as well. By default, the ASIO driver was set with the first and last inputs and outputs as 1 and 2. Changing this to 1 and 8 fixed my problem. Quote Link to comment Share on other sites More sharing options...
gunpointmetal Posted December 14, 2016 Share Posted December 14, 2016 You need to rec arm it and enable monitoring to hear it though. Just the dry track, but why would you want to do that when you can monitor a wet track straight off the Helix? Quote Link to comment Share on other sites More sharing options...
duncann Posted December 14, 2016 Share Posted December 14, 2016 You need to rec arm it and enable monitoring to hear it though. Yes, you have to have recording armed to record something. For monitoring, it depends on how you're monitoring things, I guess. For example, I take the spdif output from Helix into a pci-e soundcard to headphones. No DAW monitoring necessary in that situation. Quote Link to comment Share on other sites More sharing options...
GenotypeX Posted December 14, 2016 Author Share Posted December 14, 2016 Thank you lads, I was pretty close by the sounds of things but was missing selecting the input after record arming in mono. Will try this tonight after work, thanks a bunch. B) Quote Link to comment Share on other sites More sharing options...
GenotypeX Posted December 15, 2016 Author Share Posted December 15, 2016 Woooo, it worked thank you all! I was unsure wheather the ASIO options were at all affecting the procees first time round. Now I can be organised and "professional" and all with my recordings ^_^ Quote Link to comment Share on other sites More sharing options...
