Josh_guitarreiru Posted September 27, 2017 Share Posted September 27, 2017 Hi all! I've just recieved my Helix LT yesterday and I'm reading the manual and familiarising with the preset programing. One thing that I would like to do is to change cab models but keeping the microphone model, I mean, every cab comes initially with default mic setings (e.g. when we change cab model to cab A a dinamic 57 is selected, if then we change to cab B a ribbon is initially selected instead) I would like to keep the same mic settings when scrolling between different cab models. Not sure if there is an option for that? Thank you very much beforehand Cheers Quote Link to comment Share on other sites More sharing options...
jbuhajla Posted September 27, 2017 Share Posted September 27, 2017 Hi all! I've just recieved my Helix LT yesterday and I'm reading the manual and familiarising with the preset programing. One thing that I would like to do is to change cab models but keeping the microphone model, I mean, every cab comes initially with default mic setings (e.g. when we change cab model to cab A a dinamic 57 is selected, if then we change to cab B a ribbon is initially selected instead) I would like to keep the same mic settings when scrolling between different cab models. Not sure if there is an option for that? Thank you very much beforehand Cheers Not an option. Cabs have a "default" mic associated with them. You will have to change the mic whey trying different cabs. 1 Quote Link to comment Share on other sites More sharing options...
pbatts Posted September 27, 2017 Share Posted September 27, 2017 Hi all! I've just recieved my Helix LT yesterday and I'm reading the manual and familiarising with the preset programing. One thing that I would like to do is to change cab models but keeping the microphone model, I mean, every cab comes initially with default mic setings (e.g. when we change cab model to cab A a dinamic 57 is selected, if then we change to cab B a ribbon is initially selected instead) I would like to keep the same mic settings when scrolling between different cab models. Not sure if there is an option for that? Thank you very much beforehand Cheers When you say "scrolling between different cab models", do mean changing Presets/Snapshots or when you are auditioning cabs? 1 Quote Link to comment Share on other sites More sharing options...
efrati Posted September 27, 2017 Share Posted September 27, 2017 Hi all! I've just recieved my Helix LT yesterday and I'm reading the manual and familiarising with the preset programing. One thing that I would like to do is to change cab models but keeping the microphone model, I mean, every cab comes initially with default mic setings (e.g. when we change cab model to cab A a dinamic 57 is selected, if then we change to cab B a ribbon is initially selected instead) I would like to keep the same mic settings when scrolling between different cab models. Not sure if there is an option for that? Unfortunately you're right. It works that way, and it's awful and very unpractical! I hope that Line6 will change this in the next firmware revision. 1 Quote Link to comment Share on other sites More sharing options...
Josh_guitarreiru Posted September 27, 2017 Author Share Posted September 27, 2017 Hi all, thanks for your answers! What a pity that there is no option to set a global default mic. Pbatts I was referring to auditioning cabs within the search of the perfect tone! :) It would be much easier to have a feeling about differences in cabs if the mic settings are fixed when auditioning them. Cheers Quote Link to comment Share on other sites More sharing options...
zooey Posted September 27, 2017 Share Posted September 27, 2017 Agree, and not just mics, low and high filters especially. You want to compare the SPEAKERS, not their default settings. Ideally maybe, there should be a global setting for this. Sometimes you might actually want to hear what Line 6 thought was "recommended", if the defaults should be interpreted that way. Quote Link to comment Share on other sites More sharing options...
hideout Posted September 27, 2017 Share Posted September 27, 2017 It seems to me that this is common practice within Line6 and Boss. Highly irritating! I realize that most people like the SM57 for guitar cabs... I do not. I pretty much stick to the Coles Ribbon mic for my overdrive sounds. Quote Link to comment Share on other sites More sharing options...
FlyingsCool Posted September 27, 2017 Share Posted September 27, 2017 Agree, and not just mics, low and high filters especially. You want to compare the SPEAKERS, not their default settings. Ideally maybe, there should be a global setting for this. Sometimes you might actually want to hear what Line 6 thought was "recommended", if the defaults should be interpreted that way. Another reason I control my cuts with an EQ instead of in the cab (not to mention the steeper cut of an EQ cut versus a cut in a cab, which allows "looser" cuts). Quote Link to comment Share on other sites More sharing options...
zooey Posted September 27, 2017 Share Posted September 27, 2017 Yes. But still... Quote Link to comment Share on other sites More sharing options...
AlexKenivel Posted September 28, 2017 Share Posted September 28, 2017 Same thing with dual cabs. You can't change the first cabinet workout resetting the second one Quote Link to comment Share on other sites More sharing options...
MusicLaw Posted September 28, 2017 Share Posted September 28, 2017 Another issue I find frustrating when auditioning amongst Helix's Cabs and the Mic selections is that when pressing the Mic Parameter knob, the Mic selection does not revert to the default Mic parameter value selection! Rather it changes to the first Mic in the list of Mic offerings. The vast majority of parameter knob values, when pressed revert to the default value -- not the first value in the range of parameters for that knob. Many months ago I posted this as a Bug report and was advised this is the designed behavior of the Mic parameter knob. I then submitted the preferred configuration as an IdeaScale post. It is available to be voted up if you desire. Here's the Link: https://line6.ideascale.com/a/idea-v2/871855 Quote Link to comment Share on other sites More sharing options...
pbatts Posted September 28, 2017 Share Posted September 28, 2017 Another issue I find frustrating when auditioning amongst Helix's Cabs and the Mic selections is that when pressing the Mic Parameter knob, the Mic selection does not revert to the default Mic parameter value selection! Rather it changes to the first Mic in the list of Mic offerings. The vast majority of parameter knob values, when pressed revert to the default value -- not the first value in the range of parameters for that knob. Many months ago I posted this as a Bug report and was advised this is the designed behavior of the Mic parameter knob. I then submitted the preferred configuration as an IdeaScale post. It is available to be voted up if you desire. Here's the Link: https://line6.ideascale.com/a/idea-v2/871855 This just seems like common sense. Voted up. Quote Link to comment Share on other sites More sharing options...
MusicLaw Posted September 28, 2017 Share Posted September 28, 2017 Thanks, appreciate the vote! Hopefully, this may gain more voter support and Line 6 may include the feature in future firmware. I just posted to the massive TGP Helix thread, to let others know of this thread. Quote Link to comment Share on other sites More sharing options...
Joepeggio Posted September 28, 2017 Share Posted September 28, 2017 Ideascale for OP issue? Quote Link to comment Share on other sites More sharing options...
hideout Posted September 29, 2017 Share Posted September 29, 2017 Ideascale for OP issue? Here you go. https://line6.ideascale.com/a/idea-v2/811942 Quote Link to comment Share on other sites More sharing options...
Joepeggio Posted September 29, 2017 Share Posted September 29, 2017 Here you go. https://line6.ideascale.com/a/idea-v2/811942 Voted up! Quote Link to comment Share on other sites More sharing options...
hideout Posted September 29, 2017 Share Posted September 29, 2017 Voted up! 😀 Quote Link to comment Share on other sites More sharing options...
hideout Posted September 29, 2017 Share Posted September 29, 2017 Yeah, they’ve got to do something about this as it makes tweaking sounds that much more tedious. Mainly because the first thing I like to experiment with is the cabs. I can’t imagine how anyone could have thought that this behavior of the cab sim was a good idea. It’s insane. Or rather, it drives ME insane. Quote Link to comment Share on other sites More sharing options...
