jefflisboa Posted May 9, 2018 Share Posted May 9, 2018 Hi, always i use my pod it sounds like there was a signal loss, i already tested many cables, different guitars,, another power supply, i did factory reset and reinstalled all the updates but the problem remains. have you ever experienced this? if yes, what was the problem and how to fix?? intro.3gp 1 Quote Link to comment Share on other sites More sharing options...
spaceatl Posted May 9, 2018 Share Posted May 9, 2018 Not sure...by signal loss what do you mean exactly...The volume drops suddenly? Need a bit better description or perhaps you could record and post a clip? Quote Link to comment Share on other sites More sharing options...
jefflisboa Posted May 9, 2018 Author Share Posted May 9, 2018 13 minutes ago, spaceatl said: Not sure...by signal loss what do you mean exactly...The volume drops suddenly? Need a bit better description or perhaps you could record and post a clip? pod hd 300.mp3 Quote Link to comment Share on other sites More sharing options...
psarkissian Posted May 9, 2018 Share Posted May 9, 2018 Check pedal calibrations in the owner's manual. 1 Quote Link to comment Share on other sites More sharing options...
jefflisboa Posted May 9, 2018 Author Share Posted May 9, 2018 53 minutes ago, psarkissian said: Check pedal calibrations in the owner's manual. i already did! this problem is happening as soon as i plug the power supply and remains for like 15 mins some times a bit more, after this time it souds normal Quote Link to comment Share on other sites More sharing options...
spaceatl Posted May 10, 2018 Share Posted May 10, 2018 try parking all of the knobs at zero and recall a patch...It might be that you have a knob that is jittering...drive or channel vol... 1 Quote Link to comment Share on other sites More sharing options...
spaceatl Posted May 10, 2018 Share Posted May 10, 2018 That really sounds strange...sorta like an active guitar with a battery going dead...Does this happen in the headphones also? Quote Link to comment Share on other sites More sharing options...
jefflisboa Posted May 10, 2018 Author Share Posted May 10, 2018 51 minutes ago, spaceatl said: That really sounds strange...sorta like an active guitar with a battery going dead...Does this happen in the headphones also? yes, headphnes, output, balanced output, usb... this problem lasts for like 15 mins, after this time my pod sounds normal but on stage i cant wait 15 mins or more till pod works properly =/ Quote Link to comment Share on other sites More sharing options...
psarkissian Posted May 10, 2018 Share Posted May 10, 2018 15 minutes,... sounds like an internal hardware problem. Not something to do yourself. Log a support ticket, it will need servicing. 2 Quote Link to comment Share on other sites More sharing options...
Triryche Posted May 11, 2018 Share Posted May 11, 2018 Also sounds like it's dancing on the threshold of a noise gate. But that wouldn't explain the 15 minute thing. 1 Quote Link to comment Share on other sites More sharing options...
codamedia Posted May 14, 2018 Share Posted May 14, 2018 On 5/10/2018 at 12:42 PM, psarkissian said: 15 minutes,... sounds like an internal hardware problem. Not something to do yourself. Log a support ticket, it will need servicing. ^^^ This ^^^ Either a failing filter capacitor that is taking a long time to stabilize from a cold start, or solder joints responding to the cold (off) / hot (on) state. Either way, it needs to be serviced. 1 Quote Link to comment Share on other sites More sharing options...
Carlos_Augusto Posted June 2, 2018 Share Posted June 2, 2018 Boa noite, minha POD HD 300 também está assim eu ligo e o sinal fica cortando por uns minutos e depois volta ao normal mas no show não dá pra esperar você conseguiu resolver? Quote Link to comment Share on other sites More sharing options...
ceratonin691 Posted August 19, 2018 Share Posted August 19, 2018 I Have A Pod HD300 that has a fault. It powers up works ok until you place the amp dial to HI gain then the sound just cuts out. And you have to unplug the power supply and plug it back in and everything works again. anyone out there had this problem aswell Quote Link to comment Share on other sites More sharing options...
Ratiug2018 Posted November 2, 2018 Share Posted November 2, 2018 Bom dia! Eu tenho um pode HD 300 , ele fica reiniciando sozinho, o visor vai enfraquecendo os caracteres, até desligar, depois liga de novo e assim fica por minutos, depois de algum tempo aparece a frase "panic" code 1, alguém pode me ajudar? Quote Link to comment Share on other sites More sharing options...
bishwa86 Posted December 1, 2018 Share Posted December 1, 2018 Same problem here... I have a 4 years old HD 300 which started to show similar problem mention by you.. It's a disaster... Try searching POD HD 500 SOUND CUTTING PROBLEM on YouTube.. That guy had the same problem with his unit... There is no service near by me to fix the problem.. It's a total disaster.. Will have to think a million times before buying a line 6 product next time. Quote Link to comment Share on other sites More sharing options...
omikl Posted December 12, 2018 Share Posted December 12, 2018 I have a POD HD400 that has been exhibiting the same problem for over a year now. For the first 10-15 minutes after power on from cold it goes through the following: 1) Silence apart from a crackle when you hit the strings really hard 2) Sound sounds like it has a really awful heavily gated fuzz or the world's worst noise gate attached it it 3) Settles down and works properly. I suspect that a truly awful batch of capacitors was used at some point that break down and quit after 6 years or so... Dear Line 6 - I know we're out of warranty, but a technical advisory highlighting a fix would be nice. Quote Link to comment Share on other sites More sharing options...
psarkissian Posted December 12, 2018 Share Posted December 12, 2018 Failed amp chip, old solder points,... hardware related. Needs to be serviced by an authorized tech who knows the insides. 10 hours ago, omikl said: I suspect that a truly awful batch of capacitors was used at some point that break down Caps? More than likely not. Not if it's gating. Quote Link to comment Share on other sites More sharing options...
omikl Posted January 22, 2019 Share Posted January 22, 2019 I bit the bullet and took my HD400 in to the Yamaha service centre. To cut a long story short: They can't fix it. "Spare part is not available". They were going to quote to replace the main PCB. So, I have an HD400 that seems to be en route to the landfill as there is no way to get it fixed by Yamaha/Line 6. Is there a service manual available that has circuit diagrams and diagnostic info? The technician said over the phone that the voltages on the main board were unstable. Quote Link to comment Share on other sites More sharing options...
psarkissian Posted January 22, 2019 Share Posted January 22, 2019 Sorry to say then, if it's what I think it is, then it's a lost cause. Schematics not available and it won't help. Quote Link to comment Share on other sites More sharing options...
codamedia Posted January 22, 2019 Share Posted January 22, 2019 2 hours ago, psarkissian said: Sorry to say then, if it's what I think it is, then it's a lost cause. Schematics not available and it won't help. That's some bedside manner you have there :) Really disappointing with with the credentials listed with your avatar. Quote Link to comment Share on other sites More sharing options...
psarkissian Posted January 22, 2019 Share Posted January 22, 2019 Even Superman couldn't save everyone. 1 1 Quote Link to comment Share on other sites More sharing options...
codamedia Posted January 22, 2019 Share Posted January 22, 2019 35 minutes ago, psarkissian said: Even Superman couldn't save everyone. I fail to see the humor when a representative for the business basically gives the person having issues ZERO reason to ever have trust in purchasing a Line 6 product moving forward. Normally a business will engage a customer with a problem, not tell them they are S#!^ out of luck :) Quote Link to comment Share on other sites More sharing options...
psarkissian Posted January 22, 2019 Share Posted January 22, 2019 Not meant to be humor, just an analogy. Didn't want him wasting time and energy on search. Having worked on a number of those, I know at what point, when it's time to let it go. And I'm not a tech that gives in, yet I know when it's time to fish or cut bait, as the saying goes. If there's a unit on eBay to use, or take parts from, then that's an option. Hope that works. 1 Quote Link to comment Share on other sites More sharing options...
Kilrahi Posted January 22, 2019 Share Posted January 22, 2019 Yeah, I'm the shmuck one who laughed in this case, and to me the original poster's plight was NOT funny, but the Superman riff was funny. I don't know . . . I tend to enjoy life and laugh a lot though (I rarely get invited to funerals. :-( ), and the whole Zack Snyder version of Superman that basically leveled all of Metropolis to try and save it is still, to me, such a painfully funny bad moment in cinematic history that psarkissian's comment reminded me of it and made me laugh. I really feel for jefflisboa and hope he can find a workable solution. That's my honest to God opinion there. I'll admit, that when you compare the old school way of doing guitar (tube amps, Stratocasters, analog pedals) a nine year old device just doesn't seem that ancient, and for a guitar world used to tinkering and keeping guitars and amps around for decades a device that dies before it hits ten years old is jarring. So there is merit in that perspective. However, multi effects boards share A LOT more in common with their tech cousins than they do the simplistic circuits and tube amps of yesteryear. Asking for Line 6 to service a discontinued almost ten years old tech product is a lot like if I asked Sony to service a PlayStation portable, or HTC to service my HTC Dream. You MIGHT be able to get Apple to do a few things with the debut Iphone or Ipad . . . but certainly not much beyond a battery replacement. Asking Samsung to service an old plasma TV is going to be a straight up no. I'm not even saying that in a fair world it should be this way. I'm only saying as a consumer I recognize that there are a lot of reasons why it is that way and I have to navigate that reality in the best way possible. The best I can always hope to do is to support the companies that create the most reliable long lasting products and that give me the best consumer support when compared to their peers during any time period of that product. All of you have to decide which company that is. Personally, I've been happy with my Line 6 experience. Now, If my HX Stomp broke today and I was up a creek I'd be pissed. FURIOUS even. Will I see it the same way if it breaks eight years from now? Personally, I don't think I will. Each of you has to make that call though. Good luck again jefflisboa. It looks like they go for about $180 to $250 used on eBay, and you can nab used HD500x's at that price, or new for maybe as low as $350, so I'd kind of recommend that route if money is the primary concern. Not that those costs aren't painful because, at least if you're comparable to me, that's a painful amount to particularly for something you already had. 1 Quote Link to comment Share on other sites More sharing options...
Eemelamsi Posted January 23, 2019 Share Posted January 23, 2019 7 hours ago, Kilrahi said: Good luck again jefflisboa. It looks like they go for about $180 to $250 used on eBay, and you can nab used HD500x's at that price, or new for maybe as low as $350, so I'd kind of recommend that route if money is the primary concern. Not that those costs aren't painful because, at least if you're comparable to me, that's a painful amount to particularly for something you already had. I bought HD500 for 180€ used and I think it was totally worth the money. I would recommend upgrading to (used or new) 500 or 500x too. Quote Link to comment Share on other sites More sharing options...
jlogan57 Posted May 18, 2019 Share Posted May 18, 2019 I have a Pod HD 400 doing the same thing. First no sound, then crackly broken up sound then mysteriously will begin working. Never will I buy Line 6 again. I am 0 for 2 with their stuff. Had a Floor Pod + that began smoking and french fried the IC chip and circuit board Quote Link to comment Share on other sites More sharing options...
vanroboli Posted October 15, 2019 Share Posted October 15, 2019 Volume failure or if you need to wait for 10, 20 minutes to your HD300 show some sound or effect, the problem is in the pre-amplifier of the guitar input. First thing to do is remove the metallic shield that cover the connector and the circuit of the preamplifier. So, you must remove the four electrolitic capacitors (pictures atached), and replace-it by new ones. Chean the place with alchool. You probably will see some leaking or rust signals there. Dry the place before replace the capacitors. As old this device is, more corrosion you will see. 1 1 Quote Link to comment Share on other sites More sharing options...
zoxhet Posted October 18, 2019 Share Posted October 18, 2019 Quote Link to comment Share on other sites More sharing options...
kymbo58 Posted November 28, 2019 Share Posted November 28, 2019 Can anyone confirm this works? My POD HD300 also has no guitar input or output or tuner working, however everything else works, mp3, usb lights up as normal.Get sound in mac and windows so working as a sound card still, but no effects. Quote Link to comment Share on other sites More sharing options...
diegoteta Posted February 23, 2020 Share Posted February 23, 2020 On 10/15/2019 at 4:25 PM, vanroboli said: Volume failure or if you need to wait for 10, 20 minutes to your HD300 show some sound or effect, the problem is in the pre-amplifier of the guitar input. First thing to do is remove the metallic shield that cover the connector and the circuit of the preamplifier. So, you must remove the four electrolitic capacitors (pictures atached), and replace-it by new ones. Chean the place with alchool. You probably will see some leaking or rust signals there. Dry the place before replace the capacitors. As old this device is, more corrosion you will see. Value of capacitors? Quote Link to comment Share on other sites More sharing options...
hurghanico Posted February 25, 2020 Share Posted February 25, 2020 On 2/23/2020 at 7:48 PM, diegoteta said: Value of capacitors? Those shown in photo are 16V 10uF aluminium electrolytic smd chip capacitors https://www.ebay.com/itm/20pcs-16V-10UF-SMD-chip-Aluminum-Electrolytic-Capacitor-4x5mm/291539738493?hash=item43e11f5f7d:g:X8wAAOSwgQ9VzhLn _______________________________________________________________________________________________________________________________________________________________________ All about POD HD500/X help and useful tips Quote Link to comment Share on other sites More sharing options...
lucamufra Posted June 25, 2020 Share Posted June 25, 2020 Hello everybody, do you have the R206 value? 1 Quote Link to comment Share on other sites More sharing options...
lidertronic Posted July 13, 2020 Share Posted July 13, 2020 R206 is a 0 ohms R. Quote Link to comment Share on other sites More sharing options...
as500 Posted October 1, 2020 Share Posted October 1, 2020 Just to add a bit more information to the topic of debugging this input problem... I spent some time working on a HD 400 recently (same guitar input circuitry). I attempted replacing the four caps mentioned above and also the opamp (U8). Neither solved the problem for me, so I did a bit more investigation and found that the input to the opamp from the guitar (through R58) was sitting at around -5.5 volts. After reverse engineering the circuit a bit more, this seemed to be caused by D31 - the high side (+7.5V) diode wasn't engaged and the voltage on the middle pin was almost the same as the low side (around -7V). I didn't have a replacement on hand, so I said a prayer and attempted just reflowing each of its pins. That seems to have fixed the input for me, works good as new now. Also note, the only difference in the input circuits between HD 300 and 400 that I could see was that the component designators change. In the above, I'm referring to the HD 300 designators. Quote Link to comment Share on other sites More sharing options...
musickalservice Posted October 2, 2020 Share Posted October 2, 2020 help my pod hd300 ""Panic"" code1 Quote Link to comment Share on other sites More sharing options...
naeem4rush Posted October 27, 2020 Share Posted October 27, 2020 in this motherboard locate place R120 what is the ic number because it is damage by rust .. i need the chip number to find ? Quote Link to comment Share on other sites More sharing options...
as500 Posted October 27, 2020 Share Posted October 27, 2020 10 hours ago, naeem4rush said: in this motherboard locate place R120 what is the ic number because it is damage by rust .. i need the chip number to find ? On the HD400 (which has the same layout for the headphone input circuit that R120 is attached to), this part has "4241103E" written on it - I believe it is this digital pot: https://au.mouser.com/datasheet/2/268/22059b-46028.pdf I think it is quite safe to say it will be the same part on the HD300. Quote Link to comment Share on other sites More sharing options...
marxman6 Posted January 5, 2021 Share Posted January 5, 2021 Hi all, I just fixed my hd300 with these symptoms definitively, as has previously been mentioned and shown in these great photos ,the problem is very close to D3 under the metal input jack shield . I Repaced the 4x 10uf caps and thought all was well but after a week the same problem occured again .There were too many false positives .Eventually I got some freeze it spray and after shielding areas with kapton tape and cooling and reheating components one by one I got it to cycle the exact fault .even under the microscope all looked ok I resoldered with liquid flux all the U8(072 op amp) and D3 legs and straight away all was well even after freezing and heating again . So it was a thermal expansion fracture of solder legs problem No new parts needed! Thanks to ALL here that made this fix possible , Great community. and Good luck to the next person who finds this thread Quote Link to comment Share on other sites More sharing options...
ben_sparkyspark Posted February 17, 2021 Share Posted February 17, 2021 marxman6. I'm about to perform surgery on my Pod HD 300 as well. Should I simply go straight to the U8 and D3 legs and skip the caps? Quote Link to comment Share on other sites More sharing options...
marxman6 Posted February 19, 2021 Share Posted February 19, 2021 Getting the metaI shield off is the worse bit ,it is in two parts, I left it off until the fix was well proven . I would NOT remove the caps , just systematicly reflow each leg of all components in the vicinity, make sure you use liquid "no clean" flux and a nice needle point iron, hot air is too hit and miss. If you want to replace any surface mount can caps (no need) twist them with pliers and they snap off niceley ,do not attempt to desolder as the solder pads will be damaged or rip off the board. I think the cause of the fault is that it is easy for input jack plug put direct leverage stress on the board with use and abuse, maybe 90degree jacks plugs would stop this in future. Good luck ,let us know how you get on . 2 Quote Link to comment Share on other sites More sharing options...
