jcfetterhoff Posted January 17, 2019 Share Posted January 17, 2019 Hello all. Quick question. I recently purchased a used helix floor. I am getting usb device not recognized error. I realized that the cable i ordered off of amazon says comoatible with helix lt. Is there any difference between the cables. If not which is what i assume, im not sure whats going wrong. Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted January 17, 2019 Share Posted January 17, 2019 A USB cable is a USB cable...but without more details, troubleshooting will be difficult. Did you install the HX Edit software, Line 6 Updater, drivers, etc. etc.? Quote Link to comment Share on other sites More sharing options...
jcfetterhoff Posted January 17, 2019 Author Share Posted January 17, 2019 Yes. Using windows 7. Installed the updater. Tried the driver install alone. Installed editor. Tried 2 different usb ports. Rebooted pc etc etc. Device not recognized every time. Quote Link to comment Share on other sites More sharing options...
silverhead Posted January 17, 2019 Share Posted January 17, 2019 Maybe time to try a different cable? Quote Link to comment Share on other sites More sharing options...
jcfetterhoff Posted January 17, 2019 Author Share Posted January 17, 2019 Its new just bought off amazon. I suppose it could be faulty but i highly doubt that. Quote Link to comment Share on other sites More sharing options...
foxmeister Posted January 17, 2019 Share Posted January 17, 2019 Before going too much further, I suggest trying on a different PC as problems like this are usually at the PC end. That being said, have you tried the advice in this thread? https://line6.com/support/topic/34099-helix-driver-windows-7-installation/ Quote Link to comment Share on other sites More sharing options...
jcfetterhoff Posted January 17, 2019 Author Share Posted January 17, 2019 Thanks foxmeister. Sadly it didnt resolve the issue. Says the best driver is already installed. Unfortunately i dont have another pc. Part of the reason i bought the floor unit instead of the rack is to have a pedalboard to edit at my pc. Starting to get frustrated. I suppose ill use a friends laptop and see what i get. Quote Link to comment Share on other sites More sharing options...
psarkissian Posted January 17, 2019 Share Posted January 17, 2019 First, register the product in your account, or it won't see it as a valid device. Quote Link to comment Share on other sites More sharing options...
MusicLaw Posted January 18, 2019 Share Posted January 18, 2019 Not all USB cables are equivalent! If you have it available use the USB cable provided with the Helix Floor. The Line 6 provided cable has an in-line ferrite to help filter spurious RFI and EMI. If the OEM USB cable is unavailable, try several other known functional USB cables. By known functional, I am referring to the fact that they have been confirmed to be able to convey data and charging power with other devices. Some USB cables that are adequate for charging will not work to convey data! And, always try to connect the USB cable to your computer's buss USB ports. Many have had problems when attempting to connect via remote USB Hubs or peripheral USB jacks. Quote Link to comment Share on other sites More sharing options...
jcfetterhoff Posted January 18, 2019 Author Share Posted January 18, 2019 8 hours ago, psarkissian said: First, register the product in your account, or it won't see it as a valid device. That did nothing but thanks. Quote Link to comment Share on other sites More sharing options...
jcfetterhoff Posted January 18, 2019 Author Share Posted January 18, 2019 Musiclaw, i bought the unit used and did not recieve a cable. Did a google search to purchase the one i have. Quote Link to comment Share on other sites More sharing options...
jcfetterhoff Posted January 18, 2019 Author Share Posted January 18, 2019 One thing i have found out is that my aging pc only has usb 2.0. Not sure if that could be the cause of the issue or not. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted January 18, 2019 Share Posted January 18, 2019 USB 2.0 is what it is designed for. I'm in the "try different cables" group. I've used mine with an old Core2Duo, so it's not like you need a lot of processing power. If you're using a desktop, be aware that usually the USB ports on the front are a Hub, the ones on the back are attached directly to the mb/buss. If you're using a laptop make sure that the port you're connecting to actually works. Failing all that, you must know somebody that has a PC and is willing to let you install HXEdit and the drivers to test it out? Quote Link to comment Share on other sites More sharing options...
Droopy_TX Posted January 18, 2019 Share Posted January 18, 2019 My brother used to have problems with using various USB cables for his Fender Mustang amplifier. We figured out that the cable had to be designed for charging devices, as well as sending data. I don't think there's a wiring difference. I think it's the signal amplitude capacity that makes the difference. Quote Link to comment Share on other sites More sharing options...
