titchyblackcat
Beatles Vox Tone.
I'm trying to get a Beatles Vox Tone, the question is.
Which Vox on the Helix would be closest to the Vox that The Beatles used ?
I'd go for the Essex A30. It is a model of a top boost channel which gives you an extra dose of british jangle. But I think all Essex and Fawn models are a good choice and it depends on what you would define to be "The Beatles Sound".
13 hours ago, titchyblackcat said:
Thanks, most of them are for variax so, i thought i'd try and make one of my own.
You can just change the input to your non Variax guitar and use the signal chain as is.
It should work just fine unless the Variax has parameter assignments to control any blocks in the CustomTone preset(s).
If I were looking to replicate those tones I'd reach for the AC30 Fawn Normal...
I tried that and the presets sound awful.
Thanks, Ill try that first.
Helix can only get you so far.
Many times it's the guitar that gets you that last 15% to 20%  of the way to the tone you're after.
In this case that would mean a Rickenbacker 3 series.
I find it's the same with Mike Campbell  (Tom Petty).  I've got a pretty good Petty preset but it definitely works better with the Ric.
Assuming you don't have a Ric, maybe try a Tele?  See if that can help?  It won't be perfect but it will be better than a Strat or Les Paul.
I was going to suggest a Gretsch for many of George's sounds... but I agree fully, the guitar choice is very important and a typical Strat or Les Paul will not be as convincing.
One of the things that are very important to the Beatles guitar sound is the compression.  A bright sustain-y compressed sound.
I'm a much bigger Petty fan than I ever was a Beatles fan.  You could very well be right about the Gretsch.  I recall seeing George playing a Pac-Man guitar on TV and that's why I said that.
My own Ric is a 6 series and it is very good at doing a convincing Campbell sound.
  • Like 2
