paulienat Posted May 10, 2022 Share Posted May 10, 2022 Hi guys, I'm new in the Line6 world. I'm trying Helix Native on my Mac and I'm pretty satisfied. I've used Fractal Axe for years and now I have a real amp into an Apollo OX, getting a more pure sound but also very limited in terms of sound shaping options. I work mainly in studio so I don't need a live-tour portable setup, so I was thinking if there are any differences in terms of algorithm and sound between the Native Software version and the Helix Rack for example, in order to save money, since having a dedicated machine in studio its not essential for me. Tks for feedback Quote Link to comment Share on other sites More sharing options...
silverhead Posted May 10, 2022 Share Posted May 10, 2022 There’s no discernible difference in the sound produced by Helix Native vs. a Helix hardware device. The comparison has been made many times by me and others, and reported here. Quote Link to comment Share on other sites More sharing options...
MusicLaw Posted May 10, 2022 Share Posted May 10, 2022 The only discernable difference you might notice could be as a result of using a higher grade Audio Interface than that provided in the Helix Hardware. In a studio context you'd likely also be using the Helix Hardware's SPDIF. If used with the Helix Rack's Controller you'd also have the additional ergonomic advantages of controlling the Helix Rack. All the above, would be in addition to what you might be doing via Helix Native with your DAW. Quote Link to comment Share on other sites More sharing options...
datacommando Posted May 10, 2022 Share Posted May 10, 2022 On 5/10/2022 at 7:26 AM, paulienat said: sound between the Native Software version and the Helix Rack for example Nope - sonically they’re identical. I have both a Helix Floor unit and HX Native in use almost daily. HX Native is the same software “brain” that runs in the hardware. The only difference really is the things that are available in the hardware, eg: Send/Return, FX Loop, Looper are obviously not available in the plug-in. There is a section in the HX Native Pilot’s Guide that explains the Hardware Compatibility Mode for when you import presets created on various HX hardware units. https://line6.com/data/6/0a020a4179ea61fd2e9472da7/application/pdf/Helix Native 3.15 Pilot's Guide - English .pdf Hope this helps/makes sense. Quote Link to comment Share on other sites More sharing options...
waymda Posted May 10, 2022 Share Posted May 10, 2022 Not mentioned above is that using Native allows you to get around any processor limitations in the hardware - ie create larger more CPU intensive patches. Likely assumed you're aware of that. Quote Link to comment Share on other sites More sharing options...
datacommando Posted May 11, 2022 Share Posted May 11, 2022 On 5/11/2022 at 12:24 AM, waymda said: Not mentioned above is that using Native allows you to get around any processor limitations in the hardware - ie create larger more CPU intensive patches. Likely assumed you're aware of that. ^^^THIS^^^ Also, you have the option to add as many instances of the HX Native plug-in as your computer system can handle at one time. It can become a huge asset, even if you are not using any of the amps and simply using the effect available - some of which are interesting and unique, Euclidean Delay and Heliosphere for example. Quote Link to comment Share on other sites More sharing options...
soundog Posted May 11, 2022 Share Posted May 11, 2022 Also worth a mention, be careful with the input level setting in Native. It's easy to overdrive the plugin. Use -8dB or -12dB on peaks, and make up for it at the output end. Quote Link to comment Share on other sites More sharing options...
lawrence_Arps Posted May 11, 2022 Share Posted May 11, 2022 On 5/12/2022 at 4:32 AM, soundog said: Also worth a mention, be careful with the input level setting in Native. It's easy to overdrive the plugin. Use -8dB or -12dB on peaks, and make up for it at the output end. no need to make this gain up. Peaks of -12dBFS or even lower are fine or even advisable.. Quote Link to comment Share on other sites More sharing options...
