ajfkeith Posted May 3 Share Posted May 3 I successfully upgraded by Helix Floor. "Successfully", meaning the install went well, the new amps/effects are there. But after a few minutes the device freezes where it is and doesn't respond to footswitches, encoders, switches...nothing. The connection to HX Edit dies. It does continue to put out sound. A reboot fixes recovers the device for a few minutes until it happens again. I have tried all manner of factory resets, and attempted to re-install 3.60 using Installer 2.70. No luck. Has anyone else seen this? I have a support case open for this and waiting to hear back. Quote Link to comment Share on other sites More sharing options...
silverhead Posted May 3 Share Posted May 3 Just to be sure…. You also updated HX Edit to v3.6? Quote Link to comment Share on other sites More sharing options...
theElevators Posted May 4 Share Posted May 4 I have had certain heavy presets crash HX Edit on my Mac, and it made Helix unresponsive a few times in the past. I had to reboot the Helix to get it to work again. But this was when I had my Helix connected to the computer, which is not how I play live... Maybe you're having issues with one specific preset? What happens if you don't connect the Helix to your computer? Quote Link to comment Share on other sites More sharing options...
ajfkeith Posted May 4 Author Share Posted May 4 On 5/3/2023 at 1:31 PM, silverhead said: Just to be sure…. You also updated HX Edit to v3.6? Yup. First thing I did Quote Link to comment Share on other sites More sharing options...
ajfkeith Posted May 4 Author Share Posted May 4 On 5/4/2023 at 8:35 AM, theElevators said: I have had certain heavy presets crash HX Edit on my Mac, and it made Helix unresponsive a few times in the past. I had to reboot the Helix to get it to work again. But this was when I had my Helix connected to the computer, which is not how I play live... Maybe you're having issues with one specific preset? What happens if you don't connect the Helix to your computer? Same thing happens if not connected. I think the next thing I'll try is to delete all the factory presets - since that's all that's in there now - if I can do that before it crashes again. Quote Link to comment Share on other sites More sharing options...
silverhead Posted May 4 Share Posted May 4 I would open a support ticket. Sounds to me like something is amiss in your PC/Mac environment. Quote Link to comment Share on other sites More sharing options...
datacommando Posted May 4 Share Posted May 4 On 5/3/2023 at 6:26 PM, ajfkeith said: I successfully upgraded by Helix Floor. "Successfully", meaning the install went well, the new amps/effects are there. But after a few minutes the device freezes where it is and doesn't respond to footswitches, encoders, switches...nothing. The connection to HX Edit dies. It does continue to put out sound. A reboot fixes recovers the device for a few minutes until it happens again. I have tried all manner of factory resets, and attempted to re-install 3.60 using Installer 2.70. No luck. Has anyone else seen this? I have a support case open for this and waiting to hear back. Hi, A couple of things about your post confuse me. Firstly, when asking for assistance with an issue it really is a BIG help to know what your computer and OS are. I don’t see that here. Secondly, you said that you installed v3.6 “Successfully”, but other than saying that all “the new amps/effects are there”, no mention of if the device conformed to the auto restart, preset rebuilding process. It is a quite important thing for a clean install. Did you also restore your Helix from the backup bundle you made before updating. Now you have a Helix that freezes after a short period and a reboot clears this but is a temporary fix, including “all manner of factory resets” to no avail. Now what bothers me is that you said “attempted to re-install 3.60 using Installer 2.70. No luck.” I guess you actually mean the Line 6 Updater Utility v.1.27, but once again don’t elaborate on how, or what made this fail. The Updater is the failed update recovery tool. I don’t understand why this didn’t work. Filling in some of these holes in the report might help narrow down what may be causing the issue. If you have opened a ticket on this, then the Line 6 techies are going to require the same sort info in order to help you. Hope this helps/makes sense. Quote Link to comment Share on other sites More sharing options...
ajfkeith Posted May 6 Author Share Posted May 6 On 5/4/2023 at 2:29 PM, datacommando said: Hi, A couple of things about your post confuse me. Firstly, when asking for assistance with an issue it really is a BIG help to know what your computer and OS are. I don’t see that here. Secondly, you said that you installed v3.6 “Successfully”, but other than saying that all “the new amps/effects are there”, no mention of if the device conformed to the auto restart, preset rebuilding process. It is a quite important thing for a clean install. Did you also restore your Helix from the backup bundle you made before updating. Now you have a Helix that freezes after a short period and a reboot clears this but is a temporary fix, including “all manner of factory resets” to no avail. Now what bothers me is that you said “attempted to re-install 3.60 using Installer 2.70. No luck.” I guess you actually mean the Line 6 Updater Utility v.1.27, but once again don’t elaborate on how, or what made this fail. The Updater is the failed update recovery tool. I don’t understand why this didn’t work. Filling in some of these holes in the report might help narrow down what may be causing the issue. If you have opened a ticket on this, then the Line 6 techies are going to require the same sort info in order to help you. Hope this helps/makes sense. @datacommando - thanks I appreciate you jumping in to try to help. Answers to your questions: 1. Computer and OS: MacBook Pro 2021; Ventura 13.3.1 2. By "successful" I meant to say the upgrade (via HX Edit) completed with no errors; auto-restarted/rebooted and rebuilt the presets; then continued to boot completely in 3.60. Once booted the system operated normally for a several minutes (and connected to and sync'd with HX Edit). It would freeze after several minutes. 3. Yes I restored from the backup bundle. I also removed all presets (first by overwriting them with New Presets, then later with reset sequence (below) in case an existing preset was causing the problem. Other things I tried: - Using Line 6 Updater v1.27 (thanks I used the wrong name for it) I "updated" to 3.60. Again the upgrade completed without error, but the problem (freezing later) persisted. So the Updater Tool didn't "fail" - that method just didn't fix the freezing problem. - I repeated the upgrade (again using Updater) after booting in safe mode. - I reset the system with no presets, no IRs (Power On with FS 5+12 pressed) - I reset the system to "reformat existing presets" (Power on with FS 10+11 pressed) - I opened a support ticket; they have advised me to install again using Updater (already tried this). If that didn't work they said take it in for repair. I'm using past tense here because I got the system working after using Updater to downgrade the firmware to 3.50. This failed twice ("Update Failed") but worked the third time. Now all is well, but I won't be updating to 3.6 any time soon. My Helix is quite old (I was an early buyer). Perhaps old HW revs have something to do with it. 1 Quote Link to comment Share on other sites More sharing options...
datacommando Posted May 6 Share Posted May 6 On 5/6/2023 at 4:54 PM, ajfkeith said: I'm using past tense here because I got the system working after using Updater to downgrade the firmware to 3.50. This failed twice ("Update Failed") but worked the third time. Now all is well, but I won't be updating to 3.6 any time soon. My Helix is quite old (I was an early buyer). Perhaps old HW revs have something to do with it. Hi, Thanks for the clarification, about your situation, and I’m glad you have found that reverting to the previous firmware seems to fixed the issue of “freezing”. Not ideal, but at least it is functioning. It seems to be very odd that you actually managed to install 3.6, but would lock up after a short time. Did this happen while being disconnected from your MBP or was it still on the USB? It appears to me that there is some sort of mysterious voodoo involved with USB and firmware update glitches. As for your Helix being “quite old” - I don’t think that is the real problem. I have and my Helix since 2015 and it is in use in my studio for several hours almost every day. I’ve lways managed to keep up to the latest firmware revision. Hope this helps/makes sense. 1 Quote Link to comment Share on other sites More sharing options...
ajfkeith Posted May 7 Author Share Posted May 7 On 5/6/2023 at 2:04 PM, datacommando said: Hi, Thanks for the clarification, about your situation, and I’m glad you have found that reverting to the previous firmware seems to fixed the issue of “freezing”. Not ideal, but at least it is functioning. It seems to be very odd that you actually managed to install 3.6, but would lock up after a short time. Did this happen while being disconnected from your MBP or was it still on the USB? It appears to me that there is some sort of mysterious voodoo involved with USB and firmware update glitches. As for your Helix being “quite old” - I don’t think that is the real problem. I have and my Helix since 2015 and it is in use in my studio for several hours almost every day. I’ve lways managed to keep up to the latest firmware revision. Hope this helps/makes sense. Yeah the freezing happens while disconnected or connected to the MBP. It seems to be a bug in the 3.6 code rather than an issue with the actual upgrade process. It is strange I'm the only one hitting it apparently. Now that I'm back to 3.5 I'll probably wait for a later 3.6 release and try it again. Fortunately 3.5 has everything I need. Cheers 1 Quote Link to comment Share on other sites More sharing options...
dale_hopalong Posted May 7 Share Posted May 7 I'm experiencing the exact same issue. Sometimes when switching presets, device would go dead. No signal is coming to my audio interface. This has started since 3.6, I bought the unit recently (while on 3.5). Quote Link to comment Share on other sites More sharing options...
GuitarGuy19 Posted May 28 Share Posted May 28 I'm also experiencing the same issue. My Helix never froze before upgrading to 3.60. Since the upgrade, it occasionally freezes when switching between complex presets, and the only resolution is to power off/on. Quote Link to comment Share on other sites More sharing options...
silverhead Posted May 28 Share Posted May 28 On 5/7/2023 at 6:25 PM, dale_hopalong said: I'm experiencing the exact same issue. . On 5/27/2023 at 10:59 PM, GuitarGuy19 said: I'm also experiencing the same issue. .. I suggest you both open a support ticket if you haven’t already done so. 1 Quote Link to comment Share on other sites More sharing options...
Ricky02 Posted June 6 Share Posted June 6 I’ve got the same problem. Since I upgraded to 3.60 my Helix keeps freezing when switching presets and snapshots too. I’ve tried to downgrade to 3.50 but but I didn’t solve anything Quote Link to comment Share on other sites More sharing options...
dgtr890 Posted June 11 Share Posted June 11 I too have had this same problem and I think it's a software issue. I think something went wrong with HX Edit What I did was 1. rebuild the patches 2. Reset Globals This was done AFTER the 3.61 update To Native and Edit. So far, so good. 1 Quote Link to comment Share on other sites More sharing options...
mikeabbs67 Posted July 15 Share Posted July 15 Same Issue. Quite annoying Quote Link to comment Share on other sites More sharing options...
MGW-Alberta Posted July 15 Share Posted July 15 I had the same issue in an earlier version of the firmware. Possibly 2.6 or so but can't remember for sure. It lasted through several firmware updates until 3.0 when it went away. In my case it took me a long time to recognise what might be triggering it. I started paying closer attention and it turned out whenever I hit the Amp button to shortcut to the amp block it froze. No amount of button or knob touching would do anything at all. It still made sound in the last snapshot it was in before it froze. Rebooting the unit always unfroze it until I hit the button again. Once I figured that out I started navigating manually with the joystick to the amp block and it never crashed on me again after that ... unless I absentmindedly hit the amp button again that is. With each update I tried it again but it persisted. As I mentioned it went away after updating to 3.0. I did start a support ticket at the time but I was already off warranty and they wanted me to ship it to an authorised repair depot at my expense and of course the repair would have been at my expense as well, which is all understandable being off warranty. I chose to save the money and just use my work-around solution. I'm glad I did since it went away for free and I was not without my Helix for however many weeks or months it might have taken. I suggest you guys who are having the issue try to pay attention to what your action(s) might be immediately preceding the freeze. Even if this particular bug isn't related to the amp button, knowing what triggers it will definitely be helpful when communicating with L6 about your support ticket. Quote Link to comment Share on other sites More sharing options...
MGW-Alberta Posted July 15 Share Posted July 15 I will add one more thing. If one (or preferably all) of you do figure out what's triggering it, please come back here and report your findings. It will be of help to other owners who might be searching for the same answers. Quote Link to comment Share on other sites More sharing options...
wbowen Posted July 15 Share Posted July 15 My HX Edit is freezing after the latest update to Windows (10.0.19045) on a desktop PC. It opens, sees my Helix Floor (as window title changes), graphic at bottom says "Connecting" then hangs (title says "Not responding). I have to use Task Manager to kill the app. Helix Floor is fine but I'm now unable to edit presets - I've had Helix for 5 years without issue beforehand plus know my way round Windows software I have opened a support ticket For the record I'm using HX Edit 3.61 and Firmware 3.60.0 (latest version) Nor have I changed USB cable or port :-) Quote Link to comment Share on other sites More sharing options...
alexa973 Posted August 31 Share Posted August 31 Firmware 3.6 HX Edit 3.61 Rebuilt Global, rebuilt presets doesn't solve the problem. Exact same behaviour. Narrow down to USB connectivity problem/bug. When it freeze, unplug - re plug USB and it's alive again for some period of time. Will try to revert back to 3.5 Disappointing Quote Link to comment Share on other sites More sharing options...
