barnsleyboy Posted June 29, 2023 Share Posted June 29, 2023 I posted on here sometime back about problems with the headphone output on my Helix floor. The left channel is significantly quieter than the right. It seemed to correct itself a while back, but has now come back again. I don't use the headphones often, but I wonder if a firmware update could have messed with things. Unfortunately I can't say for sure at what stage the issue corrected itself, or when it came back again in relation to which firmware version i was on. Does this sound like it could be plausible? Has anyone else on here had this issue? If it's possible, I'm tempted to roll back the firmware versions to see if it makes a difference. The only thing is I don't want to brick the unit by messing around with it's inner secret "gubbins". I did raise a ticket with the helpdesk, but there advice was to get it checked out by my UK service centre. I'm tempted, but worried about the likely cost (and that doesn't include the insured courier costs to get it to them!) As an alternative, has anybody got any recommendations for independent repairers in the East Anglian area who would be up to the job? Any assistance or advice, much appreciated. (I've done the usual checking the headphones/ different set/ trying different patches/ etc.) Quote Link to comment Share on other sites More sharing options...
silverhead Posted June 29, 2023 Share Posted June 29, 2023 It sounds unlikely to me that firmware is the issue. I think it’s likely hardware, which is essentially what the help desk said. However, there’s no harm in reinstalling the firmware (unless you don’t follow the instructions). Use HX Edit to make backups first, then use Line 6 Updater to perform the update. Make sure HX Edit is not running when you launch Updater. Quote Link to comment Share on other sites More sharing options...
brue58ski Posted June 29, 2023 Share Posted June 29, 2023 Not sure if this will do anything but if you have some Deoxit D5 https://www.amazon.com/Hosa-D5S-6-DeoxIT-Contact-Cleaner/dp/B00006LVEU/ref=sr_1_3?crid=2JXN83RXV0EW9&keywords=deoxit&qid=1688052672&sprefix=deoxi%2Caps%2C383&sr=8-3 or something like it, put a spritz of it in there. Maybe even just do a puff of compressed air into the ouput. 3 Quote Link to comment Share on other sites More sharing options...
barnsleyboy Posted June 29, 2023 Author Share Posted June 29, 2023 ..... contact cleaner was my 2nd port of call! A liberal squirt of Servisol Super 10, but still didn't fix it Grrrr! Quote Link to comment Share on other sites More sharing options...
rd2rk Posted June 29, 2023 Share Posted June 29, 2023 Spitballing here. IDK how far back your issue goes or how you create your presets, but one thing I've found is that when using dual cabs (or multiple amps/cabs in a stereo preset), different amp, speaker and mic combinations can cause imbalances in the stereo signal. Also panning. Maybe unrelated, but something else to look into? Quote Link to comment Share on other sites More sharing options...
barnsleyboy Posted June 29, 2023 Author Share Posted June 29, 2023 I've done a factory reset and rebuilt the presets to their factory settings, so nothing to do with multiple amps, or indeed scabs!! ;-) Quote Link to comment Share on other sites More sharing options...
barnsleyboy Posted June 29, 2023 Author Share Posted June 29, 2023 One interesting development, I was just tweaking the headphone volume control and noticed that at zero I get sound coming out of the left headphone channel. As I rotate clockwise, the right channel volume increases, but the left channel stays at the same volume. Turn it more clockwise and there is a total imbalance in the stereo signal. I wonder if it could be the volume pot that is faulty or the contacts need cleaning? I'm going to try squirting some contact cleaner in through the top with the hope that it somehow makes it's way down the pot shaft and into the internal wipers. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted June 29, 2023 Share Posted June 29, 2023 On 6/29/2023 at 12:52 PM, barnsleyboy said: One interesting development, I was just tweaking the headphone volume control and noticed that at zero I get sound coming out of the left headphone channel. As I rotate clockwise, the right channel volume increases, but the left channel stays at the same volume. Turn it more clockwise and there is a total imbalance in the stereo signal. I wonder if it could be the volume pot that is faulty or the contacts need cleaning? I'm going to try squirting some contact cleaner in through the top with the hope that it somehow makes it's way down the pot shaft and into the internal wipers. This is sounding like something that's been reported before. Try contacting support and emphasizing that last bit about the zero volume setting. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted June 29, 2023 Share Posted June 29, 2023 On 6/29/2023 at 12:34 PM, barnsleyboy said: I've done a factory reset and rebuilt the presets to their factory settings, so nothing to do with multiple amps, or indeed scabs!! ;-) Yes, scabs can be quite the problem! 1 Quote Link to comment Share on other sites More sharing options...
barnsleyboy Posted June 29, 2023 Author Share Posted June 29, 2023 On 6/29/2023 at 7:57 PM, rd2rk said: This is sounding like something that's been reported before. Try contacting support and emphasizing that last bit about the zero volume setting. No need to contact support, I think I've found the issue. I'd assumed that it was the headphone socket that was the problem. It's actually the headphone pot. As I don't use headphones that often, the pot must have got gacked up with "guitarist dust and dander". I removed the knob, loosened the nut and gave it a good squirt with contact cleaner and with some vigorous twiddling, it seems to have got it going again. If anone has the same problem, this might be the solution that you are looking for ..... Phew! 2 1 Quote Link to comment Share on other sites More sharing options...
brue58ski Posted June 30, 2023 Share Posted June 30, 2023 Contact cleaner does it again. With that, duct tape and a hammer, you can fix anything. If you can't, it can't be fixed. Quote Link to comment Share on other sites More sharing options...
sboggs71 Posted November 27, 2023 Share Posted November 27, 2023 Quote It's actually the headphone pot. As I don't use headphones that often, the pot must have got gacked up with "guitarist dust and dander". I removed the knob, loosened the nut and gave it a good squirt with contact cleaner and with some vigorous twiddling, it seems to have got it going again. Yes! I had the exact same issue - with the headphone knob all the way off, there was a little output in the left side, and turning up the headphone knob only increased the volume of the right side. For years, I assumed it was a hardware problem. I completely removed the headphone knob, nut, and washer, and being careful not to let the pot knob fall into the unit, sprayed CLP (Cleaner Lubricant Protectant, or tuner cleaner) on there, even though you can't see where it is going. After vigorously turning the knob up and down all the way about ten times, wipe up the mess, reassemble and test. Praise God, this worked. I am so glad. Thanks for posting the solution. 1 Quote Link to comment Share on other sites More sharing options...
irish_admiral Posted October 6, 2025 Share Posted October 6, 2025 Very late response, and apologies for dusting this off, but i've had this problem multiple times with my Helix Floor unit - low output on the RHS and some distorting of the sound. Has been sent off to Yamaha's repairer a few times where they've done something with the socket and "fixed" it, but a more recent investigation from Puretech seems to have outed the problem as (you've guessed it) the headphone volume circuit. Will be interesting to see if this fix lasts, but helpful to know some of the potential solutions above and adding my experience in case it's of use to others in future. Quote Link to comment Share on other sites More sharing options...
PoolieFritz Posted Tuesday at 08:16 AM Share Posted Tuesday at 08:16 AM @barnsleyboy @sboggs71 @irish_admiral Hi all, apologies for dusting off this old thread but I'm having a similar problem with a Helix Floor; with Helix connected to my computer via USB and headphones connected to the Helix, I can barely hear any audio (e.g. from a YouTube video) or DAW through the phones, this is with output from the computer at 100%. Similarly, there's nothing in the phones if I disconnect from the computer and just play the guitar into Helix. The Helix (firmware v3.80, just upgraded from v2.30) has already had a Global Reset and all default factory patches restored, Global Settings all checked to ensure the knobs are controlling the headphone output. My main question is, when you guys above had your headphone issues did it also affect the volume of the audio hitting the PC, e.g. for recording into your DAW? TIA Quote Link to comment Share on other sites More sharing options...
barnsleyboy Posted Tuesday at 02:57 PM Author Share Posted Tuesday at 02:57 PM Mine was purely the headphone output. A longshot, but try the squirty-squirty contact cleaner trick on both volume and headphones pots - it might be a clump of guitarist dander stuck in there! 1 1 Quote Link to comment Share on other sites More sharing options...
PoolieFritz Posted Tuesday at 07:33 PM Share Posted Tuesday at 07:33 PM I'll give that a try tonight, thanks for the quick response! Quote Link to comment Share on other sites More sharing options...
jpdennis Posted Wednesday at 01:49 AM Share Posted Wednesday at 01:49 AM On 6/23/2026 at 1:16 AM, PoolieFritz said: @barnsleyboy @sboggs71 @irish_admiral Hi all, apologies for dusting off this old thread but I'm having a similar problem with a Helix Floor; with Helix connected to my computer via USB and headphones connected to the Helix, I can barely hear any audio (e.g. from a YouTube video) or DAW through the phones, this is with output from the computer at 100%. Similarly, there's nothing in the phones if I disconnect from the computer and just play the guitar into Helix. The Helix (firmware v3.80, just upgraded from v2.30) has already had a Global Reset and all default factory patches restored, Global Settings all checked to ensure the knobs are controlling the headphone output. My main question is, when you guys above had your headphone issues did it also affect the volume of the audio hitting the PC, e.g. for recording into your DAW? TIA @PoolieFritz My personal choice is Deoxit for the cleaner. It has never let me down. 1 Quote Link to comment Share on other sites More sharing options...
PoolieFritz Posted Wednesday at 10:18 AM Share Posted Wednesday at 10:18 AM I cleaned both pots but sadly that hasn't worked. The main output Volume knob works fine on the signal from the 1/4” out socket, but I still get nothing from the Phones output. I'm using a standard stereo TRS plug to connect (I know to avoid the 'headset with mic' type plug which has another connection as that shorts-out the contacts in the Phone socket). The audio signal into the computer from Helix via USB is also barely audible, so I suspect there's more going on here than simply a faulty pot. Any other suggestions would be appreciated, thanks. Quote Link to comment Share on other sites More sharing options...
theElevators Posted Wednesday at 01:26 PM Share Posted Wednesday at 01:26 PM Just for fun: turn on the Helix, plug something into the "right 1/4" out jack, then unplug.. Same result? Quote Link to comment Share on other sites More sharing options...
PoolieFritz Posted Wednesday at 06:37 PM Share Posted Wednesday at 06:37 PM @theElevators Thanks for the suggestion, same result unfortunately. I got all excited there for a moment, too. :) Quote Link to comment Share on other sites More sharing options...
