dnixon877 Posted July 23, 2023 Share Posted July 23, 2023 I’ve had both an hx stomp, and now a stomp xl, and my expression pedal is not working for swells. I plugged it into the expression 1/2 on the stomp, and then added a volume block to my patch. I tried putting my volume block at the beginning of my signal chain, after my amp, and at the very end. I also tried messing with the global settings. My issue is that it works for turning up and down my volume, but even though it’s before my reverb and delays, it shuts off the echoes and delays when I roll it back. I want the echoes and delay to continue decaying after I turn down my volume. Instead, it starts turning off my reverb and delay instantly as soon as I begin to roll back on my volume pedal. And this keeps happening regardless of where I put the volume block in my signal chain. I also turned up my decay time on my reverb block as far as it will go, and my volume block is still shutting off the decay. What do I need to do to get the volume block to work for swells? Quote Link to comment Share on other sites More sharing options...
phil_m Posted July 23, 2023 Share Posted July 23, 2023 If you have the volume block before the delay and reverb, the repeats should continue with the pedal down. Perhaps you mistakenly assigned some parameters to the expression pedal? Quote Link to comment Share on other sites More sharing options...
