twystedriffs
Does helix work well with older variax?
Just about to get my helix in the mail, i have an older variax. Should it work fine with the helix? And can i use the alternate tunings in helix without variaz workbench? Thanks
Helix supports the JTV and Standard Variax models. It does not support older models - the Variax 300/500/600/700.
These older models do not support alternate tunings without Workbench.
i have a 500 model and with an older firmware version i had trouble with the helix freezing when it was plugged in. i haven't tested it since tho- i just go in via normal guitar input if i use the variax
Bummer. Does it still control the models if not the tunings? As far as saving an acoustic on one preset and a les paul on the next for example? Thanks for the input, guess ill just have to try it on tuesday, and order a standard soon..
  • Downvote 1
Bummer. Does it still control the models if not the tunings? ......
I tested it with an old Variax 300. It partially worked. Helix was able to control model selection on the Variax and store/recall the models properly in the Helix presets. However, all editing actions had to be done on the Helix. Any changes made on the guitar were not properly communicated back to Helix.
Since this is an unsupported behaviour there is no guarantee that this will work on other older Variax guitars.
I've tested the Helix with two different Variax 300s. With one of them, the Helix did not control the Variax model - but with the other, it does. Not sure why, and unfortunately I don't have the first Vax 300 anymore so can't test further.
 H twystedriffs,
I too have an older/ancient (11years) Variax 600 model and it works fine hooked up on the VDI cable. Thing is, when I say "works fine" it does in as much as it is old technology connected to state of the art technology.
What I mean is it works as a guitar with all the onboard digital models fully functioning, i.e.: the Spank is still a Spank, the Resonator is a Resonator in as much as they ever approximately did. If you have altered tunings assigned to the 2 Custom Banks, DADGAD, Open G, Hawaiian, Cross Note, Vestapol or whatever they will all work. I also have used my Variax Volume to control parameters within some effect blocks (delay feedback and such) no problem, just like an expression pedal. Plus I have it set so some patches load up with the correct Variax model selected already.
There are a couple of caveats to this though. First up Selecting the model - that is determined by the Helix Patch NOT the actual Variax. I'm not sure that it should even do that, but it does. Plus I'm surprised that any of this works at all with this obsolete steam driven stuff. For me, I can live with the restrictions of using old gear, even if I have to repatch Workbench to do a few custom tunings.
Ultimately, I have to concur with the observations made in the posing by "silverhead", above, "Since this is an unsupported behaviour there is no guarantee that this will work on other older Variax guitars".
If you need all singing, all dancing - then sorry, you're gonna have to upgrade your Variax.
Both my Variax 500s work just fine with the Helix. Model changes in Helix presets work great, the VDI cable works just fine, etc.. The one thing that doesn't work, and it doesn't seem like it would have been so terribly hard for Line 6 to have supported it, is using the Helix as an interface between an older Variax and the original Workbench software running on your computer.
So, if you need to use the older Workbench software, you can use a POD HD500 (or 500X) or Firehawk etc., or the original interface that came with Workbench. Save your changes/tunings to the custom preset slots and then move back to your Helix.
So your older Variax should work fine with the Helix, but not for editing in Workbench. If you are like me, this isn't a big deal.
Just found that out LOL even with firmware update.
