GlennDeLaune Posted November 22, 2016 Share Posted November 22, 2016 Helix Firmware 2.10 Release NotesHelix v2.10.0 is a firmware update that includes new models, features, fixes, stability improvements, and optimizations. It is highly recommended that all Helix users perform this update!IMPORTANT! YOU *MUST* FOLLOW THESE INSTRUCTIONS TO INSTALL 2.10! 1. Shut down all Line 6 software as well as any software that streams audio, including, but not limited to: iTunes, Spotify, DAWs, browsers, etc.2. Use your CURRENT EXISTING Helix application to back up all of your presets and IRs (if you want to keep them). For example, if you’re running Helix FW 1.12, your current Helix application version should be 1.12. NOTE: You may want to back up individual Setlists so you can restore them to empty setlists without affecting the new 2.10 factory presets.3. Quit the CURRENT EXISTING Helix editor application and download and install the NEW Helix editor application (2.10), available here: http://line6.com/software/ This also installs the newest version of Line 6 Updater (1.10).4. If you’re using Helix Rack with Helix Control, turn off Helix Control.5. Using the latest Line 6 Updater (1.10), update Helix/Helix Rack to the newest firmware (2.10). At the end of the update process, Helix/Helix Rack will reboot automatically and begin rebuilding presets. Wait for this process to complete.6. If you’re using Helix Control with Helix Rack, connect and power on Helix Control. The inspector will ask if you want to update its firmware. Press Knob 6 (OK). Wait for the update to finish.​ YOU MUST RESET GLOBALS AND RESTORE PRESETS, OTHERWISE HELIX 2.10 WILL NOT WORK PROPERLY. DO IT. DO IT NOW: 7. To reset globals and restore presets, turn off Helix/Helix Rack.HELIX FLOOR ONLY: While holding footswitches 9 and 10 (middle two switches on the bottom row), turn on Helix. Wait for the message “Will reset Globals and restore stock Presets, Setlists and IRs…†to appear and let go.HELIX RACK ONLY: While holding knobs 5 and 6 below the screen, turn on Helix Rack. Wait for the message “Will reset Globals and restore stock Presets, Setlists and IRs…†to appear and let go.​ 8. Using the NEW Helix editor application (2.10), restore the user presets you backed up in step 2.​ New Amp Models Archetype Clean, based on* the clean channel of the Paul Reed Smith® Archon® Archetype Lead, based on* the lead channel of the Paul Reed Smith® Archon® Line 6 Litigator, new Line 6 Original inspired by boutique mid-gain amps New Effects Models Distortion > Stupor OD (Mono, Stereo), based on* the BOSS® SD-1 Overdrive Delay > Pitch Echo (Mono, Stereo), Line 6 Original New Features Auto Enable/Bypass blocks from EXP 1/2/3 and Variax Volume/Tone Knobs—Processing blocks (such as Wah, Pitch Wham, etc.) can now be enabled/bypassed by simply moving EXP 1, EXP 2, EXP 3, or Variax’s Volume or Tone knob. Press MENU and then Knob 1 (Bypass Assign). Turn Knob 1 (Switch) to select the desired switch. When selecting a continuous controller as a switch, Knob 2 (Position) and Knob 3 (Wait) appear. Bypass Assign > Position—Position determines the location in the Exp Pedal or Variax knob’s travel where the block is engaged. For example, if set to 1%, the block will turn off as soon as the pedal is moved to the heel position. If set to 99%, the block will only turn on when the pedal is moved to the toe position. To swap the on/off state regardless of position, press the BYPASS button. Bypass Assign > Wait—Wait determines how long it takes after the Exp Pedal or Variax Knob is moved below the Position location before the block turns off. For example, you may not want the Wah to turn off instantly every time you hit the heel position during your big funk solo. Also, does your song really need a big funk solo? Block Bypass via MIDI—Individual processing blocks can now be enabled/bypassed via incoming MIDI CC messages. Press MENU and then Knob 1 (Bypass Assign). Turn Knob 4 (MIDI In) to choose the desired MIDI CC. Incoming CC values 0-63 will turn the block off; values 64-127 will turn the block on. Note that some MIDI CCs are reserved for global functions and cannot be selected. Learn Bypass Assign—As with Controller Assign, you can also now quickly learn a source for bypassing the selected block instead of assigning it manually. On the Bypass Assign screen, press Knob 6 (Learn) and then engage the desired footswitch, expression pedal, Variax knob, or MIDI CC. Helix will show the switch above Knob 1 (Switch) or if it’s a MIDI CC message, above Knob 4 (MIDI In). Clear All Bypass Assignments—You can now clear all bypass assignments at once. From the Bypass Assign screen, press ACTION and then Knob 1 (Clear All Assignments). Press Knob 6 (OK) to confirm. Snapshot footswitch LED color—You can now choose a color for each snapshot footswitch. Press the PRESETS knob and then Knob 6 (Rename Snapshot). Turn knob 5 (LED Color) to select the desired color. “Auto Color†is the default red. NOTE: There is currently no way to set snapshot footswitch color from the Helix application. Split > Y Balance parameters—The old Split > Y block sends both left and right signals to Paths A and B equally. 2.10 adds individual balance (pan) control of the signals sent to Path A and B. By default, they’re set to “Centerâ€, which behaves exactly like the old Split > Y block. Support for MIDIpants Quote Link to comment Share on other sites More sharing options...
Digital_Igloo Posted November 22, 2016 Share Posted November 22, 2016 More below (TGP posts are limited to 1000 characters): Improvements/Changes Added a Headroom parameter to Delay > Vintage Digital Snapshots now recall the currently active expression controller (EXP 1 or EXP 2) for the built-in treadle Split > Y can now be bypassed; when bypassed, the block sends both left and right signals to both paths equally (like the old Split Y block) Looper Mode switch LEDs now display a dim/lit state to better reflect their current states Non-selected Pedal Edit Mode parameter switch LEDs now display a dim state Added forward slash [/] to list of characters for naming presets, setlists, snapshots, and Stomp mode custom labels Bypass Assign > Knob 1 (Footswitch) has been relabeled “Switch†to better reflect all values Tap Tempo no longer affects a preset’s dirty state (“E†icon) Minor updates to the Factory Preset bundle If a user fails to read and follow the update instructions, Helix will cause their car radio to play only polka death metal every Thursday from 1-3pm PST Bug Fixes Errant graphics could appear when selecting an IR block from the Controller Assign page - FIXED When assigning a command to EXP 3 on the Command Center page, the turquoise indicator could occasional fail to appear - FIXED When sending/receiving Looper MIDI CC messages through external devices, MIDI feedback could occur - FIXED General stability improvements Other minor bug fixes and optimizations Known Issues In very rare cases, corrupted presets containing a Volume/Pan > Volume Pedal block can cause volume to drop to 0%. In such cases, completely clear the Volume Pedal block and add again. If the same preset exhibits this behavior again, please contact Line 6 Customer Service and be ready to email us the raw preset so we can analyze it Bypass Assign > Wait defaults to 300ms from the hardware and 100ms when selected within the Helix edit application Copying and pasting a block assigned to auto enable/bypass from the Helix editor may result in a “Cannot paste block†error message while the Helix hardware confirms the block was indeed pasted correctly. Workaround: Save the preset to re-sync the application 1 Quote Link to comment Share on other sites More sharing options...
Lachdanan0121 Posted November 22, 2016 Share Posted November 22, 2016 Nice, super duper Nice! I really like the additions in the amp department, very good choices on the modelled and on the choice of doing a completely original. (I would like to see a bit more of that honestly. A Bogner XTC, and I think I am tapped out on which amps I could recommend, other than more originals from L6. Way to go L6. I look forward to updating my Helix. Also if this is what you call a "minor" update I can't wait to see what you call a major update that you hinted at in the coming year. ;) Quote Link to comment Share on other sites More sharing options...
MonkeyXT Posted November 22, 2016 Share Posted November 22, 2016 Seconded - just reading through the release notes, I'm stoked. Very interested in the new models in general, especially Litigator. Excellent! Quote Link to comment Share on other sites More sharing options...
taylorbeats Posted November 22, 2016 Share Posted November 22, 2016 Great timing, although will have to stop playing for Turkey. Quote Link to comment Share on other sites More sharing options...
Digital_Igloo Posted November 22, 2016 Share Posted November 22, 2016 Also if this is what you call a "minor" update I can't wait to see what you call a major update that you hinted at in the coming year. I consider it minor because most of the new features deal with the Bypass Assign page. That thing needed a rethink anyway. 1 Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted November 22, 2016 Share Posted November 22, 2016 What's the over/under on how long it will take for the first firmware-related whining to begin? ;) Quote Link to comment Share on other sites More sharing options...
Verne-Bunsen Posted November 22, 2016 Share Posted November 22, 2016 Solid update, well done guys! I shed a little tear of joy for the expression pedal auto-enable, and I'm very intrigued by the Litigator. I'm heading out of town for a few days for work, but look very forward to hearing about peoples experiences with the new toys in the mean time and to updating my unit when I get home! Thanks, DI and company! Quote Link to comment Share on other sites More sharing options...
judsonmwall Posted November 22, 2016 Share Posted November 22, 2016 soooo the new Archon model absolutely rules :D Quote Link to comment Share on other sites More sharing options...
Zzz123 Posted November 22, 2016 Share Posted November 22, 2016 +1 for the Archon. Kudos line 6... What are MIDIpants though? Quote Link to comment Share on other sites More sharing options...
HonestOpinion Posted November 22, 2016 Share Posted November 22, 2016 +1 for the Archon. Kudos line 6... What are MIDIpants though? This is a running joke based on a 'Saturday Night Live' skit about 'space pants'. Quote Link to comment Share on other sites More sharing options...
davidb7170 Posted November 22, 2016 Share Posted November 22, 2016 Looking forward to updating today! Good stuff. Hopefully the Variax HD Workbench moved up on the que for the next firmware update... Quote Link to comment Share on other sites More sharing options...
Guitarzman Posted November 22, 2016 Share Posted November 22, 2016 Great and thank you Line 6 can;t wait to update the new firmware!..... Quote Link to comment Share on other sites More sharing options...
Ka5par Posted November 22, 2016 Share Posted November 22, 2016 What are MIDIpants though? 1 Quote Link to comment Share on other sites More sharing options...
