rd2rk Posted December 29, 2016 Share Posted December 29, 2016 Playing along, volume disappears. Operate volume pedal, fixed. I've had the unit since 2.01, never had the problem, but remember people talking about it. I'm up to 2.11 now, suddenly, there it is. Can't believe this still isn't fixed. Anybody know anything? Quote Link to comment Share on other sites More sharing options...
dbdbdb Posted December 29, 2016 Share Posted December 29, 2016 I posted about this in the "Bug Report" sub forum recently. http://line6.com/support/topic/16083-helix-bug-reports/page-17?do=findComment&comment=189561 It happens unexpectedly and I'm not even using the volume pedal when it occurs ...... Any additional information would be helpful. Quote Link to comment Share on other sites More sharing options...
jjcor Posted December 30, 2016 Share Posted December 30, 2016 Having the same issue here. Quote Link to comment Share on other sites More sharing options...
twystedriffs Posted December 30, 2016 Share Posted December 30, 2016 I rarely use a Vol Block but I have been noticing this a little bit myself. I always thought I was tapping the volume as I was tweaking my sounds, but I'm beginning to realize that's not what is happening. So far it has never done it during a gig Just What I Am at home doodling. And I prefer editing on the machine sitting in front of my speakers so it's not connected to the PC. Quote Link to comment Share on other sites More sharing options...
MusicLaw Posted December 30, 2016 Share Posted December 30, 2016 I have encountered this same problem. It occurs randomly while using and exploring the Factory Presets and Templates on my Helix running fw 2.10. I do not use my Helix connected to a PC! It has also occurred in the single customized Preset I created from scratch using Templates > New Preset 06A. User reports of unresolved (persisting) problems and confirmed report of a newly appearing blaring audio issue in the incremental firmware update 2.11, have lead me to forgo installing fw 2.11. Once the next fw build is released, I will consider it's merits. Quote Link to comment Share on other sites More sharing options...
jbuhajla Posted January 1, 2017 Share Posted January 1, 2017 Playing along, volume disappears. Operate volume pedal, fixed. I've had the unit since 2.01, never had the problem, but remember people talking about it. I'm up to 2.11 now, suddenly, there it is. Can't believe this still isn't fixed. Anybody know anything? Do you have your volume pedal blocks assigned to EXP1 or EXP2? I reassigned all of mine to EXP2 (default) and don't see the issue any more. I have a feeling something to do with that. I was seeing the issue with 2.01, 2.10. I am at 2.11 with no issues after reassigning expression pedals. Quote Link to comment Share on other sites More sharing options...
brain-donor Posted January 9, 2017 Share Posted January 9, 2017 I have exp1 set as volume pedal on all my patches and I am experiencing this about once per gig. If changing to exp2 solves it I guess it's worth it but would rather use exp1 for volume and have 2 and 3 open for external pedals. I'll try it out. Quote Link to comment Share on other sites More sharing options...
AlexKenivel Posted January 9, 2017 Share Posted January 9, 2017 I have the same problem but with a switch less wah. Position parameter jumps to 1%. I'm wondering if it were connected to a volume block I'd get the same problem... Hasn't happened since 2.11 but then it did again recently Quote Link to comment Share on other sites More sharing options...
rd2rk Posted January 9, 2017 Author Share Posted January 9, 2017 Even better...today I was playing and the volume cut out. Hitting the volume pedal didn't fix it. Had to switch presets and back to fix it. Don't know if it's the same problem getting worse or a new one. Being a random problem it's pointless calling tech support. They must know about this, enough people are seeing it. Sure hope they fix it soon! Quote Link to comment Share on other sites More sharing options...
AlexKenivel Posted January 9, 2017 Share Posted January 9, 2017 Keep an eye on the Position parameter. Does it jump? Quote Link to comment Share on other sites More sharing options...
rd2rk Posted January 9, 2017 Author Share Posted January 9, 2017 It's random, I'm never looking at the display when it happens. Quote Link to comment Share on other sites More sharing options...
AlexKenivel Posted January 9, 2017 Share Posted January 9, 2017 Neither do I, but when it happens, I flip over to a block that shows the position and it always says 1 (heel) when it's obviously resting at 100, or does it happen momentarily and come back on for you? Quote Link to comment Share on other sites More sharing options...
jbuhajla Posted January 9, 2017 Share Posted January 9, 2017 It's random, I'm never looking at the display when it happens. When it does happen, use the joystick to go over to the volume block to see what position (%) it is at. If it is at 1%, then you have the "bug". Mine went away after reassigning all of my volume blocks to be controlled by EXP2, which is default. Quote Link to comment Share on other sites More sharing options...
dbdbdb Posted January 9, 2017 Share Posted January 9, 2017 Do you have your volume pedal blocks assigned to EXP1 or EXP2? I reassigned all of mine to EXP2 (default) and don't see the issue any more. I have a feeling something to do with that. I was seeing the issue with 2.01, 2.10. I am at 2.11 with no issues after reassigning expression pedals. Thank you jbuhajla!!! After reading your post in the "Bug Report" thread, I changed all patches from EXP1 to EXP2 and also changed the "min" on all patches to 10% and I haven't experienced the volume drops since. So, the work-around does work, though I'd still rather have the underlying issue addressed by Line6, for long-term stability. Quote Link to comment Share on other sites More sharing options...
jbuhajla Posted January 9, 2017 Share Posted January 9, 2017 Thank you jbuhajla!!! After reading your post in the "Bug Report" thread, I changed all patches from EXP1 to EXP2 and also changed the "min" on all patches to 10% and I haven't experienced the volume drops since. So, the work-around does work, though I'd still rather have the underlying issue addressed by Line6, for long-term stability. I wasn't sure if the EXP2 thing was just a coincidence. I'd like to see if more people experiencing this issue have theirs set to EXP1. I have my minimums set to 0% and still haven't had the issue. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted January 9, 2017 Author Share Posted January 9, 2017 Alex - Thanks, never thought of that - usually just thinking "SMASH! KILL! DESTROY!" When it happens. I'll try that next time. Quote Link to comment Share on other sites More sharing options...
haidesuva Posted March 24, 2017 Share Posted March 24, 2017 hey guys, I just updated to 2.11 and am now having this issue though I didn't before. So annoying... I have the vol set to exp1, will try setting to exp2 and hopefully it doesn't do it. Quote Link to comment Share on other sites More sharing options...
jbuhajla Posted March 25, 2017 Share Posted March 25, 2017 hey guys, I just updated to 2.11 and am now having this issue though I didn't before. So annoying... I have the vol set to exp1, will try setting to exp2 and hopefully it doesn't do it. The bug still exists in the most current firmware 2.12. To get around this, assign all of your volume blocks to EXP2, and not EXP1 then you will be fine. The default for volume is EXP1 and default for wah is EXP1 Quote Link to comment Share on other sites More sharing options...
robiox Posted November 14, 2018 Share Posted November 14, 2018 Hello! I have the same problem with my Helix updated to firmware 2.70. I use two Expression Pedals. I think that change Exp jack out isn't a good solution. For me, It's impossible for line6 to sell a pedalboard with this serious problem. Does someone solved it? Quote Link to comment Share on other sites More sharing options...
crowy79 Posted January 5, 2019 Share Posted January 5, 2019 Hi i have the same issue, my Helix was fine till I updated to 2.70, today I updated to 2.71 and it was even worse, has anyone got this, or is the solution to still change the exp pedals from 1 to 2? Thanks Quote Link to comment Share on other sites More sharing options...
swift Posted January 6, 2019 Share Posted January 6, 2019 Having the same problem as well with no change in parameters or touching the expression pedal. Thanks Quote Link to comment Share on other sites More sharing options...
crowy79 Posted January 7, 2019 Share Posted January 7, 2019 Hi Swift is your issue as if you have a faulty cable and the volume drops quite considerably? I have bought new leads, tried different amps and also guitars, but get the same results. thanks Quote Link to comment Share on other sites More sharing options...
rd2rk Posted January 7, 2019 Author Share Posted January 7, 2019 Last time I had this issue was back in April of 2018. I was also having problems with random noise. I sent it in for service, and they replaced "some of the boards". I haven't had any problems since. Maybe time to open a service ticket? Quote Link to comment Share on other sites More sharing options...
crowy79 Posted January 8, 2019 Share Posted January 8, 2019 Hi rd2rk thanks for your reply, that’s not good as only had the unit a few months and only used at home. Was your fix covered under the warranty or did you end up paying for it? Thanks Quote Link to comment Share on other sites More sharing options...
rd2rk Posted January 8, 2019 Author Share Posted January 8, 2019 Mine was still under warranty. Open a support ticket, they'll take care of you! Quote Link to comment Share on other sites More sharing options...
crowy79 Posted January 10, 2019 Share Posted January 10, 2019 Thanks for the info, I will open a ticket this weekend, shame I can’t just take it back to the shop I purchased it from. Quote Link to comment Share on other sites More sharing options...
