Smashcraaft Posted August 30, 2017 Share Posted August 30, 2017 JTV-59 & POD HD500x users: How do you use the "Guitar in pad/normal"-switch on the POD HD? I feel and read that the PUps on the 59 are very hot, so I use "pad" to prevent peaking the gain-stages at the POD. Quote Link to comment Share on other sites More sharing options...
amsdenj Posted August 31, 2017 Share Posted August 31, 2017 Digital audio interfaces have limited dynamic range and there is no such thing as "good" digital clipping. So you need to make sure your guitar is not overdriving the inputs of your audio interface - whether its a Pod HD500, Helix, or your typical computer audio interface. Many interfaces provide input level meters or clip indicator lights and a gain control so that you can adjust the gain to provide a good signal level while avoiding any clipping. The Pod HD500 doesn't provide level meters or clip indicators, so you have to use your ears. The input level switch plays the role of a simplified, two-state input gain control. When in doubt, use the lower gain setting and makeup the gain in the amp drive setting. That will ensure you're getting the proper kind of clipping. Quote Link to comment Share on other sites More sharing options...
Smashcraaft Posted September 1, 2017 Author Share Posted September 1, 2017 Some answers on FB are more inclusive, saying: "Pad mode is only for instruments with active pickups. Passive pickups never overload the gain stage even with high output Pickups." Any opinions on that? When in doubt, use the lower gain setting and makeup the gain in the amp drive setting. That will ensure you're getting the proper kind of clipping. That's the way I use it at the moment. If the pad is not needed anything I loose (in worst case) should be some tone-thickness and dynamics, didn't it? Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted September 1, 2017 Share Posted September 1, 2017 Some answers on FB are more inclusive, saying: "Pad mode is only for instruments with active pickups. Passive pickups never overload the gain stage even with high output Pickups." Any opinions on that? There's not much room for opinion here... this is as close to objective fact as anything that ever gets discussed around here. If you have signal clipping issues, it ain't the guitar's fault. An instrument level signal is barely sufficient to drive a pair of ear buds by itself. 1 Quote Link to comment Share on other sites More sharing options...
psarkissian Posted September 1, 2017 Share Posted September 1, 2017 It's helpful. Pad or Attenuation is generally useful for attenuation signals that are "too hot" and need to be attenuated or trimmed before continuing on down the signal path. Active pick-ups is only one circumstance where a "pad" comes in handy. Quote Link to comment Share on other sites More sharing options...
bhavneet Posted March 3, 2024 Share Posted March 3, 2024 So "normal" mode makes sense for most of the times I assume? Quote Link to comment Share on other sites More sharing options...
