GenoBluzGtr Posted October 29, 2017 Share Posted October 29, 2017 Am I crazy or is the indentation for the pedal on the wrong side of the backpack? If I put the Helix in the way it appears that it's intended, then resting the back flat on it's back means the weight is pushing down on the footswitches.. doesn't seem to make sense to me? I know it's intended to sit on it's edge or bottom... but when I'm transporting it works best to lie on it's back... but I don't like knowing that those footswitches are underneath the weight of the unit. Quote Link to comment Share on other sites More sharing options...
DoeWoe Posted October 29, 2017 Share Posted October 29, 2017 So the way you put the unit in are the switches facing the shoulder straps? I’ve always got the back of the Helix facing the straps. Quote Link to comment Share on other sites More sharing options...
pbatts Posted October 29, 2017 Share Posted October 29, 2017 Switches and Pedal should be facing the pockets, right? Quote Link to comment Share on other sites More sharing options...
pbatts Posted October 29, 2017 Share Posted October 29, 2017 I don't see an indentation for the pedal, so, I'm not understanding that part. Quote Link to comment Share on other sites More sharing options...
DoeWoe Posted October 29, 2017 Share Posted October 29, 2017 Yeah that’s how I have mine. Quote Link to comment Share on other sites More sharing options...
MusicLaw Posted October 29, 2017 Share Posted October 29, 2017 Grasp the Helix by long side edge of the foot treadle. Hold it vertically and descend/insert it into the Helix backpack such that it is resting on the interior side of the pack's back cusioned area. If the large outer lower pouch of the Backpack contains gear (, other pedals, powerstrip, cables, etc., the pack will stand naturally as you insert the Helix. If the outer pouches are empty, you may find it easier to insert the Helix with the pack positioned horizontally. I don't recollect ever laying the loaded backpack with the large Helix Logo "> <" facing downward. Quote Link to comment Share on other sites More sharing options...
GenoBluzGtr Posted October 29, 2017 Author Share Posted October 29, 2017 If you open the main compartment, and look at the bottom of the pack, there is an indentation (trough??) that looks like it's the exact size of the built-in pedal. it's on the side facing the shoulder straps. If you use that as it is apparently indended, that puts the pedal and switches facing the shoulder strats. It will still fit the other way (and that's how I'm doing it for now), but it appears to be built to accept the helix exactly the opposite of how we all (I think) think that it should go. Quote Link to comment Share on other sites More sharing options...
GenoBluzGtr Posted October 29, 2017 Author Share Posted October 29, 2017 Grasp the Helix by long side edge of the foot treadle. Hold it vertically and descend/insert it into the Helix backpack such that it is resting on the interior side of the pack's back cusioned area. If the large outer lower pouch of the Backpack contains gear (, other pedals, powerstrip, cables, etc., the pack will stand naturally as you insert the Helix. If the outer pouches are empty, you may find it easier to insert the Helix with the pack positioned horizontally. I don't recollect ever laying the loaded backpack with the large Helix Logo "> <" facing downward. Thanks for the basic directions... and I do understand these... but when I'm transporting my gear, the Helix bag needs to lay flat. there is not room among all the PA gear to stand it upright or on it's edge. So I have to lay it down flat.... it would make sense if the footswitches are up (and that's what I do - but my point is that it seems the backpack is built to use it differently. Quote Link to comment Share on other sites More sharing options...
GenoBluzGtr Posted October 29, 2017 Author Share Posted October 29, 2017 I just realized where I'm mistaken... I went to get my backpack to take a photo of the interior... the "indentation" or "trough" is not designed the way I thought. It's only there because of the way the shoulder straps are 'bulging' up the interior portion of the padding (they are raising the "floor" padding for about 80% leaving a small area that not "bulged up"). I have never pulled the straps out and they are apparently causing the interior padding to "puff up" for all but the lower 3" or so... that makes a small "trough" that looks like it should be for the pedal. My mistake... sorry for raising a false issue. Quote Link to comment Share on other sites More sharing options...
Joepeggio Posted October 30, 2017 Share Posted October 30, 2017 Not a false issue. Great info for others to know. Quote Link to comment Share on other sites More sharing options...
MusicLaw Posted October 30, 2017 Share Posted October 30, 2017 @GenoBluzGuitar: Thanks for posting your follow up description about how the stored and bunched up shoulder straps are creating a high and low area between the backpack's rear padding and Helix storage area which created the appearance of a recessed pocket specifically to accomodate the foot treadle. Removing all content from the backpack and flattening the shoulder straps when stowed should also allow for easier Helix loading and removal. Quote Link to comment Share on other sites More sharing options...
brue58ski Posted October 30, 2017 Share Posted October 30, 2017 Sounds like this is resolved but here is an official Line 6 Helix pack pic showing the Helix's orientation. Quote Link to comment Share on other sites More sharing options...
davidb7170 Posted October 31, 2017 Share Posted October 31, 2017 The picture above is how I've been placing mine since I got the backpack. It's been solid since I got it when it first available. Dave Quote Link to comment Share on other sites More sharing options...
FlyingsCool Posted October 31, 2017 Share Posted October 31, 2017 Yep, me too, I'd never want that pedal sticking me in the back when I'm carrying it. It just seemed natural to put it in like that. Only think I wish for is a handle on the bottom to help pull it out. Great pack though. I love it. Quote Link to comment Share on other sites More sharing options...
erniedenov Posted October 31, 2017 Share Posted October 31, 2017 The picture above is how I've been placing mine since I got the backpack. It's been solid since I got it when it first available. Dave Same here. And the first thing I did when I got it was to tuck the shoulder straps away. My guitar is my backpack. Quote Link to comment Share on other sites More sharing options...
Digital_Igloo Posted October 31, 2017 Share Posted October 31, 2017 There's no indentation for the treadle; you can insert Helix however you want. That picture just represents how we do it here. Quote Link to comment Share on other sites More sharing options...
