Jos_K Posted November 22, 2017 Share Posted November 22, 2017 Hi, I tried to run the echo platter in stereo (yes, from the stereo menu) But it sounds mono to me. Could someone please check it? Thanks, Jos Quote Link to comment Share on other sites More sharing options...
phil_m Posted November 22, 2017 Share Posted November 22, 2017 There is no Echo Platter effect in the Helix... Quote Link to comment Share on other sites More sharing options...
Triryche Posted November 22, 2017 Share Posted November 22, 2017 Cosmos Echo perhaps? Using the stereo version of an effect does not necessarily give it a "stereo effect", it preserves discrete L/R processing (will not mono sum). Quote Link to comment Share on other sites More sharing options...
Jos_K Posted November 22, 2017 Author Share Posted November 22, 2017 Sorry, I meant Cosmos Echo. But if stereo means preserving left and right paths, why does the stereo version have a spread parameter? Quote Link to comment Share on other sites More sharing options...
Triryche Posted November 22, 2017 Share Posted November 22, 2017 I will check it out tonight, do you by chance have a mono black after it? Quote Link to comment Share on other sites More sharing options...
Jos_K Posted November 22, 2017 Author Share Posted November 22, 2017 Thanks for asking, but no. I really made sure there's no such thing going on. Quote Link to comment Share on other sites More sharing options...
Triryche Posted November 22, 2017 Share Posted November 22, 2017 Is the there a type of spread? Quote Link to comment Share on other sites More sharing options...
Jos_K Posted November 22, 2017 Author Share Posted November 22, 2017 Not sure what you mean Quote Link to comment Share on other sites More sharing options...
duncann Posted November 22, 2017 Share Posted November 22, 2017 I've also noticed this effect sounds monoish. It does have a spread parameter, but I can't really tell that it's doing anything. Quote Link to comment Share on other sites More sharing options...
Triryche Posted November 22, 2017 Share Posted November 22, 2017 Is there a type of spread to select? Quote Link to comment Share on other sites More sharing options...
duncann Posted November 22, 2017 Share Posted November 22, 2017 There is no type of spread, just a spread parameter that goes from 0 to 10. Quote Link to comment Share on other sites More sharing options...
Jos_K Posted November 22, 2017 Author Share Posted November 22, 2017 Most stereo delays have a scale parameter to alter the delay time for one of the sides (left or right). A spread parameter usually widens the modulation part of an effect (eg. Delay with Mod). Quote Link to comment Share on other sites More sharing options...
willjrock Posted November 22, 2017 Share Posted November 22, 2017 I unfortunately havent been able to update yet yet due to some software malfunctions, but first thing is first, lets KNOW if the effect is playing back in mono. Probably the simplest way to do this is turn repeats up to 100% and read your meters. Be sure to be monitoring in stereo. Watch your meters. If the effect IS in fact in mono, both the left and right will show repeats of exactly the same volume every time provided your pan pot is centered. Record the track and limit it if you have to. Quote Link to comment Share on other sites More sharing options...
Jos_K Posted November 23, 2017 Author Share Posted November 23, 2017 I checked it. The stereo paths are retained so it processes stereo signals fed into the effect in stereo. But the effect itself is mono. Still no idea what the spread parameter is supposed to do (or the splice paramater, by the way). Anyone? Quote Link to comment Share on other sites More sharing options...
shanecgriffo Posted November 23, 2017 Share Posted November 23, 2017 i think splice introduces some random tape pitch flutuation. just every now and then Quote Link to comment Share on other sites More sharing options...
phil_m Posted November 23, 2017 Share Posted November 23, 2017 The Cosmos Echo is definitely stereo (the stereo version at least), it's just not as in your face as a ping pong delay or anything like that. To hear the stereo effect, you really need to use one of the multi-head settings and get well into self-oscillation. You start to hear it swirl all around. I can hear it even with my studio monitors, but with headphones it was more noticeable. Quote Link to comment Share on other sites More sharing options...
duncann Posted November 23, 2017 Share Posted November 23, 2017 Listening with headphones, the stereo in the stereo version is so narrow that it may as well be called mono. It really seems like it's not performing as it should, or at least could. Quote Link to comment Share on other sites More sharing options...
Jos_K Posted November 23, 2017 Author Share Posted November 23, 2017 The Cosmos Echo is definitely stereo (the stereo version at least), it's just not as in your face as a ping pong delay or anything like that. To hear the stereo effect, you really need to use one of the multi-head settings and get well into self-oscillation. You start to hear it swirl all around. I can hear it even with my studio monitors, but with headphones it was more noticeable. You've got good ears! 'Cause you're right. It is stereo. I did a test, flipping the phase of one side etc. I set the mix to 100% and let it self-oscillate. I could clearly hear a little audio, very faint, but still... It's not present when I sum the signal to mono by placing a mono gain block after the Cosmos Echo. But since the stereo effect is so barely audible, I can't help but think something's not right. And then there's the spread parameter that also in a phase cancellation test doesn't do anything audible. Quote Link to comment Share on other sites More sharing options...
Lachdanan0121 Posted November 23, 2017 Share Posted November 23, 2017 You've got good ears! 'Cause you're right. It is stereo. I did a test, flipping the phase of one side etc. I set the mix to 100% and let it self-oscillate. I could clearly hear a little audio, very faint, but still... It's not present when I sum the signal to mono by placing a mono gain block after the Cosmos Echo. But since the stereo effect is so barely audible, I can't help but think something's not right. And then there's the spread parameter that also in a phase cancellation test doesn't do anything audible. Hmm Perhaps L6 could chime in on this Tomorrow. Quote Link to comment Share on other sites More sharing options...
phil_m Posted November 23, 2017 Share Posted November 23, 2017 It’s probably worth noting that the RE-201, which the Cosmos Echo is modeled after, isn’t a stereo effect to begin with. So I’m not exactly sure what the Spread parameter is doing. It seems to have some effect on new repeats, but it doesn’t seem to affect those already self-oscillating. Quote Link to comment Share on other sites More sharing options...
brue58ski Posted November 23, 2017 Share Posted November 23, 2017 i think splice introduces some random tape pitch flutuation. just every now and then That cracks me up. I have a friend who had a Space Echo and since at one time, there was nobody offering a replacement for the tape loop, he made one himself by...wait for it...splicing one together. And you could hear the splice where I don't recall ever hearing one before that. It'll be fun to see if it actually recreates that. Quote Link to comment Share on other sites More sharing options...
duncann Posted November 24, 2017 Share Posted November 24, 2017 (edited) Haven't tried it yet, but I suppose since this effect (the original) may be designed for a narrow field, two of them placed at the end of the chain, each on their own path and panned left and right, may produce a more stereo-like sound. Quickly tried this and it does indeed widen the stereo effect considerably, with the added benefit of an increased array of options to tweak between the two cosmos echos. Also, no need to use two stereo versions, but instead just the mono versions. Edited November 24, 2017 by duncann Quote Link to comment Share on other sites More sharing options...
jbuhajla Posted November 24, 2017 Share Posted November 24, 2017 It’s probably worth noting that the RE-201, which the Cosmos Echo is modeled after, isn’t a stereo effect to begin with. Yup Quote Link to comment Share on other sites More sharing options...
