titchyblackcat Posted September 14, 2021 Share Posted September 14, 2021 Hi, I'm trying to get a Beatles Vox Tone, the question is. Which Vox on the Helix would be closest to the Vox that The Beatles used ? Quote Link to comment Share on other sites More sharing options...
waymda Posted September 14, 2021 Share Posted September 14, 2021 If you search Beatles in customtone there's a bunch of pacthes you could use as a starting point. https://line6.com/customtone/search/?submitted=1&family=helix&search_term=beatles 1 Quote Link to comment Share on other sites More sharing options...
titchyblackcat Posted September 14, 2021 Author Share Posted September 14, 2021 Thanks, most of them are for variax so, i thought i'd try and make one of my own. Quote Link to comment Share on other sites More sharing options...
Schmalle Posted September 14, 2021 Share Posted September 14, 2021 I'd go for the Essex A30. It is a model of a top boost channel which gives you an extra dose of british jangle. But I think all Essex and Fawn models are a good choice and it depends on what you would define to be "The Beatles Sound". 1 Quote Link to comment Share on other sites More sharing options...
Hey_Joe Posted September 14, 2021 Share Posted September 14, 2021 13 hours ago, titchyblackcat said: Thanks, most of them are for variax so, i thought i'd try and make one of my own. You can just change the input to your non Variax guitar and use the signal chain as is. It should work just fine unless the Variax has parameter assignments to control any blocks in the CustomTone preset(s). Quote Link to comment Share on other sites More sharing options...
codamedia Posted September 15, 2021 Share Posted September 15, 2021 17 hours ago, titchyblackcat said: Which Vox on the Helix would be closest to the Vox that The Beatles used ? If I were looking to replicate those tones I'd reach for the AC30 Fawn Normal... 1 Quote Link to comment Share on other sites More sharing options...
titchyblackcat Posted September 15, 2021 Author Share Posted September 15, 2021 10 hours ago, Hey_Joe said: You can just change the input to your non Variax guitar and use the signal chain as is. It should work just fine unless the Variax has parameter assignments to control any blocks in the CustomTone preset(s). I tried that and the presets sound awful. 7 hours ago, codamedia said: If I were looking to replicate those tones I'd reach for the AC30 Fawn Normal... Thanks, Ill try that first. Quote Link to comment Share on other sites More sharing options...
codamedia Posted September 15, 2021 Share Posted September 15, 2021 45 minutes ago, MGW-Alberta said: Many times it's the guitar that gets you that last 15% to 20% of the way to the tone you're after. In this case that would mean a Rickenbacker 3 series. I was going to suggest a Gretsch for many of George's sounds... but I agree fully, the guitar choice is very important and a typical Strat or Les Paul will not be as convincing. 1 Quote Link to comment Share on other sites More sharing options...
theElevators Posted September 15, 2021 Share Posted September 15, 2021 One of the things that are very important to the Beatles guitar sound is the compression. A bright sustain-y compressed sound. 1 Quote Link to comment Share on other sites More sharing options...
titchyblackcat Posted September 16, 2021 Author Share Posted September 16, 2021 Thanks All. I'll try the suggestions. Quote Link to comment Share on other sites More sharing options...
