USB Audio - OSX Yosemite issues
bobthedog
Hi Guys,
I see lots of people having issues with El Capitan and the Helix audio over USB but I am also having problems on Yosemite.
It doesn't matter what buffer size I choose after a while the audio just turns into noise, flipping the buffer sizes then makes it work for a while again.
My HD500 never worked over USB with 3 macs, is the helix going to be the same or am I alone here?
Cheers
Andy
No you are not alone there are 7 billion people surrounding you but I transgress I have a similar problem but I am still using Maverick every thing starts off just dandy and them you play a chord and a little while later you hear the chord. Very annoying so I go into the preferences hit the audio button disable the core audio re enable it and Whala all back to normal oh and that's using logi x but if I use a different program no issue at all
A bit of an update:
I set up the Helix and my Apollo Duo as an aggregate device with the Apollo as the clock source and drift correction turned on for the Helix.
This sorts out the input noise from the Helix, no more problems even at a buffer size of 32.
The audio out on the aggregate device does suffer from the odd click though.
Well, that's probably a good indiction of clock drift in the Helix. I hope this isn't a hardware design issue.
If that were the case, wouldn't it show up in pretty much any system with any OS? I've been recording with my Helix via USB on Windows 10 for a good 8 or 9 months now, and I've never had any issues.
Nice to know- thanks phil
Same here, Windows 7, since about October of last year. Tried in Windows 10 also with no problems.
OS X is very susceptible to bad clocking info from USB audio devices:
CoreAudio is a multi client system, each client can use a different buffer size (as long as it is smaller than the driver ring buffer) to the same audio stream, therefore each thread will need waking at different times. It is important to note that in OS X there is a disconnect between the actual driver data and the client user space data, you do not have direct access to the hardware driver as it was on OS 9. CoreAudio uses a push model where it pushes the data to the clients, same data, different sizes at different times, so it is predictive in it's timing and this is based on the driver data.
Timing issues are more general in USB interfaces and CoreAudio double checks the driver timings against an expected behaviour model, if the timings depart too much from the norm then CoreAudio will ignore them.
​What this means in the end is that the Client (Say A DAW) is woken at the wrong time to process the input audio leading to audio problems.
Windows ASIO does not work (usually) this way as the audio system is single client, unless you are running a multiple client ASIO driver for example the steinberg one. It would be interesting to see if the steinberg one suffers.
There is always many other audio Interface choices out there with mature drivers available. MOTU, UA Apollo, RME, etc etc... Just use the Helix for what it is, a kickass guitar processor. :)
that might be almost tolerable for a £300-ish effects unit like the Pod 500 HD  but  definitely not for a £1000+ unit.
This is sold as a unit with top notch audio interface functionality.
For that kind of money I expect it to do  EXACTLY WHAT IT SAYS ON THE TIN
( as we brits say )
I'm with Spikey on this one. Maybe it's because I already have a good studio interface and would actually prefer to send the Helix's analog output signal through my mic pres than go direct via the USB connection. It'll sound good, I know it and I know my mic pres. The Helix? Well, yeah it's marketed as being a very good audio interface - I wouldn't go as far as to say "Top Notch". That would imply that it could compete with the likes of Apogee, UAD and Burl... Not a snowball's chance in Hades. It is, first and foremost "a kickass guitar processor".
