mikegibbo52 Posted May 13, 2017 Share Posted May 13, 2017 Hi I am new to helix and I have had mine for just over a week so this may be basic to advanced users. I have created a patch with a small amount of gain, slight crunch. I just want to add some sustain to the solo sound without increasing the gain. What's the trick? Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted May 14, 2017 Share Posted May 14, 2017 A little compression. 2 Quote Link to comment Share on other sites More sharing options...
aleclee Posted May 14, 2017 Share Posted May 14, 2017 Increasing master volume on the amp model might help get you some compression with minimal added dirt. Quote Link to comment Share on other sites More sharing options...
HonestOpinion Posted May 14, 2017 Share Posted May 14, 2017 Try the Deluxe compressor with anywhere up to a 6:1 ratio. Make sure the release is at least 250ms or longer and the threshold is allowing the compressor to kick in when you need it. You can also use one of the overdrives with the Gain set low and the volume boosted a bit. Also make sure your noise gate is not killing the sustain by kicking in at too low a threshold. Quote Link to comment Share on other sites More sharing options...
mileskb Posted May 14, 2017 Share Posted May 14, 2017 Messing with the amps sag and bias settings can really add a lot of sustain. Quote Link to comment Share on other sites More sharing options...
PeterHamm Posted May 14, 2017 Share Posted May 14, 2017 Also (and in ADDITION...) try the LA Studio Comp AFTER your cabinet. Quote Link to comment Share on other sites More sharing options...
zooey Posted May 14, 2017 Share Posted May 14, 2017 All those suggestion are good. Some amps also feel more compressed than others, for instance Litigator. And FWIW, and haven't been back to it since trying it yesterday, but oddly enough I think the most transparent compressor may be the multiband. Check it out. I added it as the first thing in the chain, for my clean snapshot only. The other snapshots have a comfortable but still pretty natural amount of sustain from a combination of the other techniques mentioned above. I'm not a big fan of compressors for driven sounds, distortion inherently compresses, an actual compressor loses punch and responds less to how you play. IMO, YMMV, of course. Quote Link to comment Share on other sites More sharing options...
mikegibbo52 Posted May 18, 2017 Author Share Posted May 18, 2017 Thanks so much for the quick response everyone, will try those ideas. Quote Link to comment Share on other sites More sharing options...
redmonda Posted May 18, 2017 Share Posted May 18, 2017 Here are a compressor setting that I use with good effect: Compressor - Red Comp Sensitivity: 9 Mix: 27% Level: 0db The low mix should keep your initial pick attack in check and mostly just add sustain. It's pretty transparent as well. Worth a shot... Quote Link to comment Share on other sites More sharing options...
loopinit Posted May 20, 2017 Share Posted May 20, 2017 Use the compressor with a ratio of 2:1 to 4:1, and raise the gain to raise your noise floor. I personally believe it's much better to use multiple stages of light compression, than it is to use ratios higher than 4:1 in only one compression block. I also recommend placing a noise gate immediately after the compressor to remove the white noise artifacts created from a higher noise floor. Quote Link to comment Share on other sites More sharing options...
parker1963 Posted May 23, 2017 Share Posted May 23, 2017 Compression and a little eq tailored to the frequencies you want the extra sustain on Quote Link to comment Share on other sites More sharing options...
TheDaveDaveDave Posted May 23, 2017 Share Posted May 23, 2017 Here are a compressor setting that I use with good effect: Compressor - Red Comp Sensitivity: 9 Mix: 27% Level: 0db The low mix should keep your initial pick attack in check and mostly just add sustain. It's pretty transparent as well. Worth a shot... Note that compressor settings vary GREATLY depending on the inout signal.... I.e., how hot the pickups are, pre-compressor gain structure, etc. Always season to taste! Quote Link to comment Share on other sites More sharing options...
vmoncebaiz Posted May 26, 2017 Share Posted May 26, 2017 Using an overdrive pedal with the gain set to 0 but the level up really high will give you some compression and force the amp to tighten up a little without really adding gain. Some OD models work better than others for this. Quote Link to comment Share on other sites More sharing options...
spikey Posted May 26, 2017 Share Posted May 26, 2017 distortion inherently compresses That's true, and the more you use the more you compress generally. For me, right at speaker breakup it sometimes needs just a bit of sustain/compression. Quote Link to comment Share on other sites More sharing options...
hideout Posted May 26, 2017 Share Posted May 26, 2017 If we could somehow reduce the buzziness of overdriven amp sounds I think that would help solve the problem. I'd love it and I'm thinking that because the Helix lives in the digital world, why couldn't it be done? Quote Link to comment Share on other sites More sharing options...
PeterHamm Posted May 26, 2017 Share Posted May 26, 2017 If we could somehow reduce the buzziness of overdriven amp sounds I think that would help solve the problem. I'd love it and I'm thinking that because the Helix lives in the digital world, why couldn't it be done? it can. Easily. proper use of hi and lo cuts, amp settings (sag, hum, bias, bias X and even master), etc. Most amps are just as buzzy in the real world, and that gets dialed out by the sound guy. 1 Quote Link to comment Share on other sites More sharing options...
hideout Posted May 26, 2017 Share Posted May 26, 2017 it can. Easily. proper use of hi and lo cuts, amp settings (sag, hum, bias, bias X and even master), etc. Most amps are just as buzzy in the real world, and that gets dialed out by the sound guy. I've played with all that quite a bit. You don't quite get there. Imagine a clean Fender sound with all of its sparkle and sheen but with the sustain characteristics of a dimed Marshall. The high cut especially, removes all the sheen and detail that I want to retain. The sag, master and a compressor helps to some degree but not as much as I'd like. I also find power tube distortion adds a different kind of buzz to the sound but it's still buzz and I want less of it. Quote Link to comment Share on other sites More sharing options...
zooey Posted May 26, 2017 Share Posted May 26, 2017 Try high Master settings, less preamp Gain. For some amps, that can get you compression/sustain with less distortion and mess. Quote Link to comment Share on other sites More sharing options...
Rewolf48 Posted May 27, 2017 Share Posted May 27, 2017 Real world high volume will do the trick :) Quote Link to comment Share on other sites More sharing options...
zooey Posted May 27, 2017 Share Posted May 27, 2017 Also the approach mentioned by @TheDaveDaveDave, with a compressor with the mix at less than 100%, to let some pick attack through. I'm not such a fan of the Red Comp in general (try Deluxe, LA Studio, or 3 Band), and I've never wanted mix as low as he suggested, but even at 95%, the sharp transient at the start of notes adds a lot of life and expressiveness. Quote Link to comment Share on other sites More sharing options...
hideout Posted May 27, 2017 Share Posted May 27, 2017 Real world high volume will do the trick :) Precisely what I'm trying to avoid. It shouldn't be necessary. Quote Link to comment Share on other sites More sharing options...
AlexKenivel Posted May 27, 2017 Share Posted May 27, 2017 Deluxe Compressor. Lower the threshold down a bunch, raise the release, and then raise the level while A/Bing with the compressor on and off while hitting the strings as loud as you can to match volumes. That's how I set it anyway. Works for me Quote Link to comment Share on other sites More sharing options...
