Greg099 0 Posted January 1, 2018 I just bought a brand new Variax Standard. Will these Fender locking tuners fit the pre-drilled holes on the headstock? https://smile.amazon.com/Fender-0990818100-Locking-Tuners-Chrome/dp/B000L6GD04/ref=cm_cr_srp_d_product_top?ie=UTF8 My Variax Standard has two small holes pre-drilled next to the main tuner hole. These tuners appear to have the same pins in the right location. Thanks! Greg Line 6 G50 Wireless Guitar System (2) Variax JTV-69 guitar Variax Standard guitar Quote Share this post Link to post Share on other sites
cruisinon2 2,546 Posted January 1, 2018 Aside from waiting around for someone who happens to have purchased the same tuners to respond, is to remove one of the stock ones and measure the diameter of the hole... then try and find the specs for these tuners somewhere, perhaps from Fender. The description from Amazon is useless unless it specifies the diameter of the hole required. Or look for a better set of tuners...all the good aftermarket stuff, Schaller, Sperzel, Gotoh, etc. tell you the home diameter that's required. Quote Share this post Link to post Share on other sites
Greg099 0 Posted January 10, 2018 Thanks for your response. The issue is not the hole diameter. The issue is that the Variax Standard has two pin holes next to the main hole for anchoring the machine head, and I’m trying to find out what locking tuners will fit this design. I’m not partial to Fender, they just were the only ones I could find online that even looked like the right pin hole design. Many of the ones you list use screws which will just add more holes to the headstock that I don’t need. The Variax JTV-69 came with locking tuners, so I was a bit disappointed to find they weren’t on the Standard. It would be good if they could at least spec a locking tuner that will fit the Standard for those of us now spoiled by this feature. The existing tuners have no identifying marks on them, so I can't even cross reference the manufacturer. I fear they are a cheap import model with some odd pin spacing that can’t be matched. So Line6 folks or anyone out there got a locking tuner that will fit the pre-drilled holes on the Variax Standard? Quote Share this post Link to post Share on other sites
wsexson 0 Posted January 10, 2018 The tuning machines on my Variax Standard were Ping. Other than missing the branding logo they looked just like tuners from my Fender guitars. I strongly suspect that the product that you linked to will be a drop in replacement for the stock tuners on your Variax. Quote Share this post Link to post Share on other sites
JimDiGritz 5 Posted January 26, 2018 Not sure if the two pin layout is the same, but Schaller locking tuners have two pins 'above' the hole. Worth finding a spec online with dimensions and checking Quote Share this post Link to post Share on other sites
getdusty 0 Posted November 11, 2018 Did anyone find and actually install a perfect drop in solution for upgrading a variax standard to locking tuners? I just returned a JTV 69s that came with major finish cracks and serious build issues. Apparently the music store tried to fix something and screwed it up royally then tried to sell it as “B stock”. I think I’d like to save some cash and buy a standard but I really like the convenience of locking tuners. Quote Share this post Link to post Share on other sites
jerseyboy 45 Posted November 12, 2018 On 11/11/2018 at 1:02 PM, getdusty said: Did anyone find and actually install a perfect drop in solution for upgrading a variax standard to locking tuners? I just returned a JTV 69s that came with major finish cracks and serious build issues. Apparently the music store tried to fix something and screwed it up royally then tried to sell it as “B stock”. I think I’d like to save some cash and buy a standard but I really like the convenience of locking tuners. I'm not an exact match to your inquiry but I’ve gone through many locking (Sperzel, Grover, Schaller) tuners over the years and the most recent ones to impress and upgrade my JTV59 3+3 arrangement - Hipshot w/ UMP (universal mounting kit). No drill (no nubs) installation while being very smooth and stable locking tuners. https://hipshotproducts.com/collections/guitar-tuning-machines/products/guitar-tuner-upgrade-kits 1 Quote Share this post Link to post Share on other sites
psarkissian 354 Posted November 14, 2018 Make certain the nub on the bottom of the tuner lines up with the mounting hole. 1 Quote Share this post Link to post Share on other sites
soundog 491 Posted November 20, 2018 I bought a set of AllParts locking tuners (Part No. TK-7591-010) for $35 online. They fit like a glove, swap out in minutes, and are working nicely. I used the original washers from the Variax because I like the bevel on them better than the ones provided. Sure, there are better locking tuners out there, but these are a nice match for my Standard. 1 1 Quote Share this post Link to post Share on other sites
getdusty 0 Posted November 20, 2018 Thanks for the tip and specific part number Soundog. Much appreciated! Quote Share this post Link to post Share on other sites
WILLIAMSFARRIER 1 Posted December 15, 2018 On 11/11/2018 at 12:02 PM, getdusty said: Did anyone find and actually install a perfect drop in solution for upgrading a variax standard to locking tuners? I just returned a JTV 69s that came with major finish cracks and serious build issues. Apparently the music store tried to fix something and screwed it up royally then tried to sell it as “B stock”. I think I’d like to save some cash and buy a standard but I really like the convenience of locking tuners. I just installed a set of Graphtech Ratio locking tuners on my Variax Standard. They drop in perfectly and they work great! I took them off of a parts guitar because I kept breaking high E strings on my Variax. 1 Quote Share this post Link to post Share on other sites
Dcsaba77 0 Posted July 8, 2020 Hi all, I have a Variax Standard guitar, and I want to change the original tuners to Hipshot Grip Lock open locking tuners. Hipshot's staggered post sets are available in various configurations, which include: Short - 18mm, 19mm, 20mm Standard - 19mm, 20mm, 21mm Tall - 20mm, 21mm, 23mm. The staggered height is measured for the base of the string post to the centre of the string hole. I've already open a support ticket, but I've not get any answer yet. Please help me to pick up the perfect size. The other question is a post hole size. Are they 10mm or different? Thanks a lot! Quote Share this post Link to post Share on other sites
psarkissian 354 Posted July 8, 2020 - Take it to your local guitar shop/music instrument retailer and check it for fit there at the counter. It saves you the trouble of multiple trips and hassle. - Check that the tuning post diameter does not result in a side-ways breaking angle with the string nut slot. - Check that the tuning post string hole is not too high. An elevation breaking angle of 12-15 degrees needs to be maintained between the tuning post and string nut slot. - Check that the screw hole mount and alignment nub line up. - Some tuner have an order of line up of the tuners to correspond to the string diameter. Quote Share this post Link to post Share on other sites
Dcsaba77 0 Posted July 8, 2020 Dear Partev, Thanks for the quick answer. Unfortunately here at the guitar shop there isn't anything in stock, so checking is not an option, only the online shopping. "Check that the tuning post string hole is not too high. An elevation breaking angle of 12-15 degrees needs to be maintained between the tuning post and string nut slot." - that is the reason why I don't know, what is the perfect size and I hope there is somebody here who already buy a Hipshot Open Grip lock upgrade kit for the Variax standard, and tell me. :) "Check that the screw hole mount and alignment nub line up".- The patented UMP (Universal Mount Plate) included free in this kit means your tuners will retrofit without drilling or screwing. Quote Share this post Link to post Share on other sites
psarkissian 354 Posted July 8, 2020 Just want to make sure everyone is aware. Very good. Quote Share this post Link to post Share on other sites
Dcsaba77 0 Posted July 8, 2020 Thanks a lot, really appreciate it! Quote Share this post Link to post Share on other sites
Dcsaba77 0 Posted July 16, 2020 Hi all, here is the solution for the Variax Standard, without any kind of drilling or any other modification. On the Hipshot website you can choose: - Hipshot Guitar Tuner Upgrade kit for 6 inline headstocks. - style: Grip - Lock open - guitar style: bass side non - staggered Perfect drop in solution, the swap takes me only 30 minutes. I am happy :) Quote Share this post Link to post Share on other sites
soundog 491 Posted July 18, 2020 Hmmm .... I wonder how much difference there can be between the Hipshot ($88) and the Allparts ($35) tuners. The Allparts I'm using fit perfectly in the Standard, they don't slip, are easy to tune, geared nicely, and accurate. What's the diff? Quote Share this post Link to post Share on other sites
Dcsaba77 0 Posted July 18, 2020 I`m sure that the Allparts is a good stuff. I`ve read that U.S. Made Variaxes use Hipshot Open Grip Lock, and I want to buy branded tuners, that `s why I decided to go for Hipshot. Satisfied...Next step: swapping mag pickups... Quote Share this post Link to post Share on other sites
psarkissian 354 Posted July 20, 2020 "I`ve read that U.S. made Variaxes use Hipshot Open Grip Locks" --- Yes they are. They have good feel to them and work really well. Quote Share this post Link to post Share on other sites
soundog 491 Posted July 20, 2020 Keep us posted on how your pickup swap goes! That's probably the next experiment I'll try on my Standard. Quote Share this post Link to post Share on other sites
psarkissian 354 Posted July 20, 2020 Check out the pick up swap topic at the top of the topic section. Quote Share this post Link to post Share on other sites
Dcsaba77 0 Posted July 20, 2020 Thanks to God (and Partev and Richie Castellano too ) there`s a lot of information about swapping pickups. I think at the end of this year I have enough money to order the new pickups. Quote Share this post Link to post Share on other sites
psarkissian 354 Posted July 20, 2020 :) And I'm honored and happy to be Richie's wing-man. Worked on one of his 69S guitars a couple weeks ago. Couple of connection glitches, some fret work, a few odds and ends. Just in time for one of his Thursday night FB live events. All sounded good. And remember to use the wiring diagrams in the Line 6 Knowledge Base. Quote Share this post Link to post Share on other sites
Dcsaba77 0 Posted July 22, 2020 Partev, what do you mean "connection glitches"? Is there any kind of cleaning method or any kind of maintenance we should do periodically? For example, is there any kind of trick to provide the best connection with the piezos? Sorry, if it is a stupid question... I am very grateful for all of your help! Quote Share this post Link to post Share on other sites
psarkissian 354 Posted July 22, 2020 Flux residue and solder beads around the connection points of the pick-ups. He cleaned the area, just needed a little extra touch-up by me. I know, it's a little off topis for locking tuners. Quote Share this post Link to post Share on other sites
Dcsaba77 0 Posted July 22, 2020 I would be very happy if you service my guitar too, but U.S. is the other end of the World : ) Quote Share this post Link to post Share on other sites
psarkissian 354 Posted July 22, 2020 The closest to you would be Yamaha in Germany (YME). Quote Share this post Link to post Share on other sites
villarriba 0 Posted August 22, 2020 Schaller M6 Pin 6L Chrome are the perfect locking tuners for the Variax Standard! Quote Share this post Link to post Share on other sites
