Steve_roberts Posted October 6, 2019 Share Posted October 6, 2019 I want to use my Bas Horsie II, but I'm not sure I'm hooking it up right. What's the best way to integrate the external wah, so that it's available at all times? Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted October 6, 2019 Share Posted October 6, 2019 Guitar--->wah--->Helix Quote Link to comment Share on other sites More sharing options...
rd2rk Posted October 6, 2019 Share Posted October 6, 2019 1 hour ago, Steve_roberts said: I want to use my Bas Horsie II, but I'm not sure I'm hooking it up right. What's the best way to integrate the external wah, so that it's available at all times? Already asked and answered: Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted October 7, 2019 Share Posted October 7, 2019 6 hours ago, rd2rk said: Already asked and answered: Lol...I thought that I'd already seen this movie. Round and round we go. ;) Quote Link to comment Share on other sites More sharing options...
dj3000 Posted May 9, 2021 Share Posted May 9, 2021 Any settings that need changed? I'm following this verbatim. at this point if jacks had feelings, they'd be annoyed from the guitar cable plugs entering and exiting over and over again! Guitar 》 Wah 》 Guitar In... I hear absolutely nothing when I switch the pedal on. No signal at all. What could be the problem? Quote Link to comment Share on other sites More sharing options...
rd2rk Posted May 9, 2021 Share Posted May 9, 2021 Test your cables. Test your batteries OR make sure your wah's power supply is connected. Quote Link to comment Share on other sites More sharing options...
theElevators Posted May 9, 2021 Share Posted May 9, 2021 Or add it in an effects loop. Usually wah goes immediately after the guitar. However, some people put it after fuzz/distortion. Or you can go crazy and add wah to your delays or something, or at the very end of the chain for some crazy sounds. My advice, is use whatever's onboard. I like Throaty wah, personally. I like that it works as volume pedal in the heel position -- it lowers your output volume. I used to play BD for many years, and still have it on my old analog pedalboard. Quote Link to comment Share on other sites More sharing options...
brue58ski Posted May 10, 2021 Share Posted May 10, 2021 On 5/8/2021 at 8:34 PM, dj3000 said: Any settings that need changed? I'm following this verbatim. at this point if jacks had feelings, they'd be annoyed from the guitar cable plugs entering and exiting over and over again! Guitar 》 Wah 》 Guitar In... I hear absolutely nothing when I switch the pedal on. No signal at all. What could be the problem? Make sure your input is correct. Every time I've gotten no sound it's been that I have the wrong input selected (so far). If it is correct, try an FX loop (Send/Return) and put that in the patch. Quote Link to comment Share on other sites More sharing options...
dj3000 Posted May 10, 2021 Share Posted May 10, 2021 Ok. Thanks for the suggestions but after trying effects loop, battery test and cable test, same issue remains. I have a good and true signal when switching the pedal off. Nothing when switching the pedal on. Maybe bad switch or pot? I've seen many playin doctor with this thing to get it to work. 5 hours ago, brue58ski said: Make sure your input is correct. Every time I've gotten no sound it's been that I have the wrong input selected (so far). If it is correct, try an FX loop (Send/Return) and put that in the patch. By input do you mean in global settings? Quote Link to comment Share on other sites More sharing options...
rd2rk Posted May 10, 2021 Share Posted May 10, 2021 1 hour ago, dj3000 said: Ok. Thanks for the suggestions but after trying effects loop, battery test and cable test, same issue remains. I have a good and true signal when switching the pedal off. Nothing when switching the pedal on. Exactly what make and model is your wah? Quote Link to comment Share on other sites More sharing options...
dj3000 Posted May 10, 2021 Share Posted May 10, 2021 6 minutes ago, rd2rk said: Exactly what make and model is your wah? It's the Dunlop 535Q Quote Link to comment Share on other sites More sharing options...
soundog Posted May 10, 2021 Share Posted May 10, 2021 Make sure your wah pedal is working on its own (guitar -> wah -amp). Sounds like it may have issues. Quote Link to comment Share on other sites More sharing options...
dj3000 Posted May 10, 2021 Share Posted May 10, 2021 Even on the amp - no go. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted May 10, 2021 Share Posted May 10, 2021 1 hour ago, dj3000 said: It's the Dunlop 535Q That's the one I have, and it works fine. Sounds like your wah is defective. Quote Link to comment Share on other sites More sharing options...
dj3000 Posted May 11, 2021 Share Posted May 11, 2021 Yeah I'm convinced it's time to replace it. Thanks for the help. Quote Link to comment Share on other sites More sharing options...
soundog Posted May 11, 2021 Share Posted May 11, 2021 Take it apart and try to fix it. It'll be fun! 2 Quote Link to comment Share on other sites More sharing options...
rd2rk Posted May 11, 2021 Share Posted May 11, 2021 14 minutes ago, soundog said: Take it apart and try to fix it. It'll be fun! It's probably just a broken wire. 1 Quote Link to comment Share on other sites More sharing options...
soundog Posted May 11, 2021 Share Posted May 11, 2021 I always try to fix my doo-dads unless they are still under warranty. Sometimes the fix is pretty simple (like a broken connector wire, loose wiring harness, bad solder joint, etc). If I get in over my head (micro electronics, weird stuff that I don't even know what it is, etc) I usually give up. At least I know I tried to save the patient. Even then, I usually salvage components and screws (organ donor). Half the fun is trying to figure out how to take things apart! You also learn which manufacturers design and make quality stuff when you look inside. BTW, Line 6 gets an A+ (except for some of their Variax components and accessories). 1 Quote Link to comment Share on other sites More sharing options...
datacommando Posted May 11, 2021 Share Posted May 11, 2021 11 hours ago, rd2rk said: It's probably just a broken wire. Yep! Not much to go wrong with a wah pedal, a couple of jack sockets, a few wires and a variable resistor. Quote Link to comment Share on other sites More sharing options...
viola Posted May 12, 2021 Share Posted May 12, 2021 An analog (perhaps stupid !) question: several wha pedals (expecially the older ones) are "not true-bypass". Supposing the link GTR>Wha> Helix input, when the wha unit is "off" this that may negative affects the signal that go to Helix and/or the sound quality ? Quote Link to comment Share on other sites More sharing options...
rd2rk Posted May 12, 2021 Share Posted May 12, 2021 8 hours ago, viola said: An analog (perhaps stupid !) question: several wha pedals (expecially the older ones) are "not true-bypass". Supposing the link GTR>Wha> Helix input, when the wha unit is "off" this that may negative affects the signal that go to Helix and/or the sound quality ? Assuming you're referring to @dj3000, he says he's getting NO signal and, as I have the same device, that's not an issue. As to "true-bypass" vs not, that has more to do with loss of high frequencies due to cable lengths and stuff I never really understood (and not even the experts agree on). My 535Q is the only analog pedal I have, and I only use it with my HXS (my "noodle" box), I have a Floor for serious playing. 1 Quote Link to comment Share on other sites More sharing options...
Tipto73 Posted May 13, 2021 Share Posted May 13, 2021 On 5/12/2021 at 9:28 AM, viola said: An analog (perhaps stupid !) question: several wha pedals (expecially the older ones) are "not true-bypass". Supposing the link GTR>Wha> Helix input, when the wha unit is "off" this that may negative affects the signal that go to Helix and/or the sound quality ? I had an old wha VOX connecetd between guitar and Helix input who sucked tone when "off". So, a friend modified wha unit as "true bypass" pedal and immediately I heard a sea of difference. Now the tone is not affected and an the sound is more "open". So, my answer is yes. A not true bypass pedal before digital Helix input "may" affects the tone because cutting some frequencies. 1 Quote Link to comment Share on other sites More sharing options...
