Preset with 3/4 snapshots for CLEAN, CRUNCH, LEAD sounds. Which amp ?!
vincentm77
Hi everyone, I would like to use my HX Stomp (normal or XL, I own both) as a 3 channels-amp, with a channel 1 (snapshot 1) for CLEAN sounds, channel 2(snapshot 1) for CRUNCH sounds, and channel 3 (snapshot 3) for LEAD/HEAVY sounds....
Since I want to work with snapshot, I cannot change the amp model between snapshots.
What is your favorite amp for such a configuration ?!
I like the Brit2204, but it doesn't really get clean, even with low gain/drive.
My goal is to have one preset for Guns 'n Roses songs (Marshall-y amp), one preset for Metallica songs (Recto-y amp), one preset for Van Halen (EVH-y) etc...
Thanks !
Vincent
Have you tried the new 2203? IMO, it sparkles on clean settings yet still delivers the dirt with ease.
My needs are very different... but I accomplish what you are looking for by establishing a great clean platform/tone, then stacking overdrives for various dirt sounds. Granted, I have a Helix with more block real estate.
  • Upvote 2
Hi Codamedia, thanks for your suggestion, yes I will check the 2203 out.
To do what I wanna do, I am trying not to use extra overdrives pedals (models) - my goal is a have a "one amp" setup, with a consistent sound and different drive/gain settings.
I've done this with the Placatar Dirty model....the trick for me to get the cleans (unless you want the spanky clean sound, its still sorta a marshally clean) is to make sure the BE/HBE switch is to BE so its less gain from the start, also make sure the Fat/C/Saturation switches are all off.  This makes it a bit sparklier in tone in the amp.   There is a spot in the gain setting that you can get to a cleanish type setting....it will vary with pickups youre using.
You can also make the input pad switchable on snapshots I believe, so that will help, but also, if you have room in your chain for a block, add a volume block first in the chain and play with the setting.  Take the expression controller off of it and assign it to snapshots instead.  I do this all the time when I dont have the DSP to add a 2nd amp...I will just reduce the volume to a % that is similar to rolling your guitar volume down to clean up an amp.  (also essentially what the input pad is doing as well).  For me, i usually have to dip below 10%.  Too close to 1-2% and you might get some weird signal levels if you have the gate on, but that is also switchable via snapshots so on your clean snapshot turn the gate off.
  • Like 2
I use Mail Order Twin on a very clean setting exclusively.  It works very well as a clean platform for various effects, distortions.  I tried a bunch of amps, and this is the one I settled on.  Everything else was too boomy, noisy, glassy, etc....
Another vote for the Placater, lots of variety in that. A Scream808 with GAIN low and LEVEL high is very useful. Try it with different combinations of the Placater's switches.
On 2/8/2024 at 12:05 PM, PaulTBaker said:
I may be wrong, but if you have enough blocks, you can use two amps and snapshots.  Have the snapshots turn the different amps on and off.
I did this for awhile with the SLO100 amps.  Depending on the song I could get by with either Clean/Crunch, or Crunch/OD or Clean/OD.   The Clean amp when gain is topped off can get you some nice low/mid grittyish tones.  Those amps really scall well from 1>2>3 as far as gain goes.
I should revisit those amps....wish they werent so dsp heavy though.
I think OP could literally do the Clean/Crunch, throw an OD808 in front and control the gain of the amps with snapshots and use the TS808 at various levels for leads.
Cali IV Lead can do Metallica clean, crunch and lead. It can also do GnR and EVH.
You can play a complete heavy rock Top40 show with that model and a humbucker guitar.
I use it with the 4x12 Greenback 30, 906, pos6, 1.25", 45°, 110Hz, 9kHz. It sounds pretty much like a specific scooped IR from the Ownhammer Classic Rock pack.
The new Line 6 Carillon works pretty well for me like this. But I don't need too "heavy" lead sound, more bluesy, playing a semi-acoustic Ibanez with humbuckers.
