vilo1968 Posted June 4, 2014 Share Posted June 4, 2014 Hello Friends.I'm using my POD HD500 connected to a stereo power amp (clone of the power of a Randall Century 200), with a 4 x 12 cabs with Celestion speakers seventy/80.This stereo power amp "Colours" signal much as it produces a very sharp and scoop sound.What power amp do you recommend to use with POD HD500? Valves or solid state?? What brands and models?I'm a guitarist in a band of modern metal.Thank you very much from now.Pdt. Excuse my English Quote Link to comment Share on other sites More sharing options...
radatats Posted June 4, 2014 Share Posted June 4, 2014 I use a Rocktron Velocity 300 into a pair of old Peavey 15" PA speakers or into my own 2X12's with Celestion V-30's and Emminence Guvnors. Sounds awesome but heavy to lug around... 1 Quote Link to comment Share on other sites More sharing options...
gunpointmetal Posted June 4, 2014 Share Posted June 4, 2014 I use a Crate Powerblock in stereo into a 4x12 running stereo out of the POD into the PB's line inputs/effects loop. No coloration from the amp as far as I can tell. I'm using an eight string guitar with passive pickups in drop E (four string bass E!) and I have no problem with clarity or cut. Make sure you're tweaking your patches at volume with the band, and disable cab sims if you're going into guitar speakers. Another thing to note, the classic "metal" sound (mids cut slightly, treble & bass boosted) is recipe for pure disaster in a live setting. My main live patch is with the Rectifier model and the bass is probably at 25-30 with the Mids and highs in the 60s-70s and then presence to taste. I also like to tweak my patches with my head at speaker level and not too far away (its loud, but necessary) so I know what a microphone would be picking up in a live setting, as well. Too many people think their rig sound awesome from ten feet away, but in reality its harsh and brittle and thin because they're basing their tweaks on how it sounds off-center and out of the "beam" 1 Quote Link to comment Share on other sites More sharing options...
joel_brown Posted June 5, 2014 Share Posted June 5, 2014 I use a pair of Marshall JCM900s into 4x12 cabs. I think any good tube amp into a good guitar cab would work fine. Quote Link to comment Share on other sites More sharing options...
scottyo78 Posted June 9, 2014 Share Posted June 9, 2014 I hereby second the Crate Power Block. :D I'm not a Crate fan per say, but these came highly recommended and when they went on sale as being discontinued, I snagged one. I've had it for 8 years with no problems at all... it's very clean, loud, bullet proof and compact (nice for traveling). Quote Link to comment Share on other sites More sharing options...
masterperry Posted January 23, 2015 Share Posted January 23, 2015 I'm using a Marshall JCM 900 with an POD XT live for the JCM 800 model. I found the JCM900 was trebly and fizzy alone. It also lacked sustain. But now with the POD going into the effects return it's very bassy. I have the output set to line, stack power amp. The amp model is set traditionally. Bass 7, mid 4, treb 6 with the gain on 5 and Cabs disabled as I have a Marshall 4x12 with 25 watt greenbacks in it. I mike the cab with an E609. It sounds great through headphones or straight into my DAW. But not so much on stage. are there any tweaks that my work for me? I also don't want to mess up the direct out signal in case I want to run direct into the PA instead of a mic. If I have to make 2 sets of patches, one for stage and 1 for studio so be it. But I really want to get this Marshall revved up for the AC/DC tribute. Any help would be appreciated. Quote Link to comment Share on other sites More sharing options...
gunpointmetal Posted January 23, 2015 Share Posted January 23, 2015 try turning down your bass and turning up your mids Quote Link to comment Share on other sites More sharing options...
NinoScholz Posted January 23, 2015 Share Posted January 23, 2015 I used to use velocity 100, then velocity 300, and now mesa 50/50 tube power. The tube power is a pretty big improvement for band/gig use. Up at high volumes it shines vs the solid state amps, and lets you use the HD Pre-amps vs full models. Since i've been using the preamp models with the 50/50 my rig really sounds like any other all tube head (i play in a band with another guitarist using a soldano HR50 and various marshalls), only way more versatile. Good speakers help a ton too - V30's were the finishing touch to my tone - really put it over the top. Quote Link to comment Share on other sites More sharing options...
namklak Posted February 9, 2015 Share Posted February 9, 2015 Crate power block. Every time I see one on CL or eBay I'm tempted to buy it just because. I'm currently using mine as part of an active power soak, but I used it with a modeler for years. If my main tube amp I'm using for gigs doesn't work,I have patches in my HD to model straight into the crate. Quote Link to comment Share on other sites More sharing options...
russgoos Posted February 9, 2015 Share Posted February 9, 2015 Guitar (Variax or electric) --> HD500X --> L6 link --> DT25 combo stack #1 --> L6 link --> DT25 combo stack #2. Sounds and feels amazing - truly a comprehensive dream rig. Love it. Fyi - "combo stack" = DT25 1x12 combo amp on top of a DT25 1x12 extension cab. The big Mesa cab in the center is unused. 2 Quote Link to comment Share on other sites More sharing options...
JaimeLloyd Posted February 12, 2015 Share Posted February 12, 2015 I've got a HD500x on the way. Haven't tried it yet with my rig, but I've been using a Boogie 50/50 with my other modelers for a few years. HUGE improvement over the Velocity. I use the Boogie to drive two 4x12 cabs at live shows. It romps. If you can pick up a 50/50 used its well worth. Quote Link to comment Share on other sites More sharing options...
ColonelForbin Posted February 12, 2015 Share Posted February 12, 2015 Guitar (Variax or electric) --> HD500X --> L6 link --> DT25 combo stack #1 --> L6 link --> DT25 combo stack #2. Sounds and feels amazing - truly a comprehensive dream rig. Love it. Fyi - "combo stack" = DT25 1x12 combo amp on top of a DT25 1x12 extension cab. The big Mesa cab in the center is unused. That double stack is sooooooo awesome looking. Seriously. Love it!!! How has patch building been going for that? Quote Link to comment Share on other sites More sharing options...
FlyingSquirrel Posted February 13, 2015 Share Posted February 13, 2015 ISP Stealth or Carvin TS100. Quote Link to comment Share on other sites More sharing options...
Dutchguitarist Posted February 13, 2015 Share Posted February 13, 2015 I use a Marshall Valvestate Poweramp into two Marshall Speakercabinets (MC series). The nice thing with this valvestate poweramp is (to me anyway) that you can choose between Valvestate and linear state depending on your specific needs, or in other words do you want the Poweramp to add warmth or not. Quote Link to comment Share on other sites More sharing options...
BillBee Posted February 13, 2015 Share Posted February 13, 2015 I've used a Valvestate Head on occasion and it does sound real good - into either a 4x12 or 2x12. Bottom line is most any will sound good but you will have to put some time in adjusting the patches and output settings per rig. -B Quote Link to comment Share on other sites More sharing options...
russgoos Posted February 13, 2015 Share Posted February 13, 2015 That double stack is sooooooo awesome looking. Seriously. Love it!!! How has patch building been going for that? Hi ColonelForbin, patch building was initially a bit weird until I figured out a couple key settings. Most of which are second nature and are intuitive now, given some thought. In the POD HD EDIT software, on the Mixer tab in the L6 LINK and MAIN MIX sections: If using a single amp (or single preamp) patch: Amp 1 Audio = Left, Amp 1 Control = Amp 1 Amp 2 Audio = Right, Amp 2 Control = Amp 1 Main Mix = Pan both paths to CENTER. No need to pan out to L & R since there is one (pre)amp in use. Note, any stereo effects are still actually heard in stereo. For example, the ping pong delay audibly bounces back & forth between the L & R combo stacks even though the panning in the Main Mix is set to center for both path A and path B. If using a dual amp (or dual preamp) patch: Amp 1 Audio = Left, Amp 1 Control = Amp 1 Amp 2 Audio = Right, Amp 2 Control = Amp 2 Main Mix = pan Path A to 100% L, pan Path B to 100% R then boost both LEVEL sliders up 6 db to compensate for the loss during panning. (I think that last part is correct, to the best of my knowledge). The 100% pan L & R enables each combo stack to essentially become the amp model in that given path. Another thing I've found is that although the cab models sound initially cool when starting a new patch, they really don't hold up when tweaking further for some reason. IMHO, generally, the preamps with no cab sim hold up the best with these combo stacks, especially at high volumes. I've read that when using the DT amps with the 500(x) and not just 500(x) standalone, that it's best to use preamps and no cabs since the DT is a real amp & speaker. After much experimenting I agree with that almost all the time. On the AMPS tab, one of the most important settings is the Topology setting. The Topology setting can speed getting just the right tone and I've found it can be a huge time saver instead of EQing and tweaking endlessly. I've been surprised at how often I've paired up the "wrong" Topology setting with an amp and had it sound killer. I didn't expect that benefit. To a lesser extent, the Class A vs Class AB setting makes a difference too of course. Much of the Class difference seems to affect the feel of the amp more than the tone. It affects the tone too, but just not as drastically as the Topology setting. I usually only use the Triode MODE setting for vintage-y tones, which makes sense I guess. I really love the JTV Semi middle position with Class A, Topology 3 and Triode for a basis for a gritty chimey classic vintage tone. Seems to pair nicely with the AC-15, AC-30, Divide and Gibtone models. Rock & metal are more my thing, and I couldn't be happier with this rig. I'm very much looking forward to the 2.6 firmware and amp packs! Ok, well that was long-winded. Thanks for hangin' in there! Quote Link to comment Share on other sites More sharing options...
Ed_Saxman Posted February 13, 2015 Share Posted February 13, 2015 I´m using a Roland GA-212 as a stereo Power Engine (using the stereo "Main In" connectors): Quote Link to comment Share on other sites More sharing options...
