phillips21d Posted May 27, 2015 Share Posted May 27, 2015 Is there any way to manually punch in the numbers for a tempo using the keyboard on the firehawk app? I set up patches for individual songs a lot and it's a pain to try and use the tap tempo to hit an exact tempo for every patch that I make. But it won't let me select the tempo value to just type the numbers in. Am I missing something? I would really appreciate a feature of just being able to touch the tempo number and type in a new tempo. Quote Link to comment Share on other sites More sharing options...
bond19 Posted May 27, 2015 Share Posted May 27, 2015 In the edit screen for the effect you want to change the tempo for, on the right side of the delay time, there will be a bpm - you can tap that area, and enter in a number. make sure you save up in the top right. Quote Link to comment Share on other sites More sharing options...
phillips21d Posted May 27, 2015 Author Share Posted May 27, 2015 In the edit screen for the effect you want to change the tempo for, on the right side of the delay time, there will be a bpm - you can tap that area, and enter in a number. make sure you save up in the top right. I've tried that, but it won't let me select anything there. I can tap all over the the bpm or the numbers but it doesnt let me select it, so the keyboard won't come up to enter in a new tempo. What you're saying seems like the natural thing to work, but for some reason I can't get it to come up that way either on my iPad or my iPhone. I don't get why mine won't do that. Quote Link to comment Share on other sites More sharing options...
phil_m Posted May 27, 2015 Share Posted May 27, 2015 I just tried it on my iPhone 5S, and I can't change the BPM manually either. Quote Link to comment Share on other sites More sharing options...
bond19 Posted May 27, 2015 Share Posted May 27, 2015 I will check it when I can Quote Link to comment Share on other sites More sharing options...
meuste Posted May 27, 2015 Share Posted May 27, 2015 Is there a slider for the tempo adjustment? Quote Link to comment Share on other sites More sharing options...
jaredbrown85 Posted May 27, 2015 Share Posted May 27, 2015 Is there any way to manually punch in the numbers for a tempo using the keyboard on the firehawk app? I set up patches for individual songs a lot and it's a pain to try and use the tap tempo to hit an exact tempo for every patch that I make. But it won't let me select the tempo value to just type the numbers in. Am I missing something? I would really appreciate a feature of just being able to touch the tempo number and type in a new tempo. If it's an IPhone no, Android will alow tap tempo and manual entery. Not sure why that limitation on iPhone??? Quote Link to comment Share on other sites More sharing options...
phillips21d Posted May 27, 2015 Author Share Posted May 27, 2015 Is there a slider for the tempo adjustment? No slider. Just tap tempo. The tap works, but it's just takes extra time and is a bit imprecise when you're trying to get an exact tempo number. Quote Link to comment Share on other sites More sharing options...
silverhead Posted May 27, 2015 Share Posted May 27, 2015 On my iPad I cannot manually enter the bpm. However, there is a slider that permits relatively fine precision in setting the bpm, depending on the fine motor control you have over your fingertips!! Note: If the indicated tempo is shown in note format you will have to touch the Note button in order to switch slider control to the bpm setting. Quote Link to comment Share on other sites More sharing options...
phillips21d Posted May 27, 2015 Author Share Posted May 27, 2015 On my iPad I cannot manually enter the bpm. However, there is a slider that permits relatively fine precision in setting the bpm, depending on the fine motor control you have over your fingertips!! Note: If the indicated tempo is shown in note format you will have to touch the Note button in order to switch slider control to the bpm setting. I see that option, but I get it in ms then instead of bpm, which sort of works, but then you have to calculate for each tempo what the different note values would equal in ms. Unless you're saying there's a way to have the slider actually slide bpm and not ms. That would be great if there is, but I can't get mine to do that on my iPad or my iPhone. Quote Link to comment Share on other sites More sharing options...
silverhead Posted May 27, 2015 Share Posted May 27, 2015 Ooops... sorry. You're right - it's in ms, not bpm. Thanks for the catch. Quote Link to comment Share on other sites More sharing options...
bond19 Posted May 27, 2015 Share Posted May 27, 2015 I am partly to blame for that one as well (bpm). Sorry Quote Link to comment Share on other sites More sharing options...
bond19 Posted May 27, 2015 Share Posted May 27, 2015 Just checked the app - it is in bpm. Tap the pencil, then you will be able enter the speed. Quote Link to comment Share on other sites More sharing options...
jaredbrown85 Posted May 28, 2015 Share Posted May 28, 2015 Just checked the app - it is in bpm. Tap the pencil, then you will be able enter the speed. Is that on an Apple product, or Android? Quote Link to comment Share on other sites More sharing options...
bond19 Posted May 28, 2015 Share Posted May 28, 2015 Android Quote Link to comment Share on other sites More sharing options...
phillips21d Posted May 28, 2015 Author Share Posted May 28, 2015 So it seems like the Android version has full capability to manually set tempo, but the iOS app is limited for some reason. I hope that's something that line 6 will correct in a future update. Thanks for all the replies everyone! If you find out anything else about getting it to work on the iOS app I'd appreciate if you post it. Thanks! Quote Link to comment Share on other sites More sharing options...
urbanspaceblast Posted May 28, 2015 Share Posted May 28, 2015 A guy mentions it in this clip about 50 secs in. Works on Android (BPM). Screenshot from my phone. Quote Link to comment Share on other sites More sharing options...
stevekc Posted June 16, 2015 Share Posted June 16, 2015 FWIW - the new Live Edit Mode in Firehawk FX 1.10 firmware provides a means of setting the Delay time in 1 bpm increments - using the data wheel Quote Link to comment Share on other sites More sharing options...
Stratotron Posted June 17, 2015 Share Posted June 17, 2015 I keep a couple of charts handy in my music room. 1, is a chart that converts BPM to Ms or vice versa. Very handy. Another chart I have (different subject) has the Hz at each string/fret location on the fret board. Comes in handy if a partcular note is "zinging" Quote Link to comment Share on other sites More sharing options...
stevekc Posted June 17, 2015 Share Posted June 17, 2015 BPM to Millisecond Delay Calculator tools http://www.dvfugit.com/beats-per-minute-millisecond-delay-calculator.php http://www.thewhippinpost.co.uk/tools/delay-time-calculator.htm Quote Link to comment Share on other sites More sharing options...
mcbeddall Posted June 17, 2015 Share Posted June 17, 2015 Hey that's awesome thanks for sharing Quote Link to comment Share on other sites More sharing options...
