filippou2 Posted January 26, 2016 Share Posted January 26, 2016 Hello to every body! I have a POD HD500X from november,i have a problem but i don't know if it's a problem of pod or a characteristics of them. When I change a patch (also factory preset) i hear a 40ms of latency (for latency i mean a totally mute sound). The attach file is a mp3 of this situation when i press the same preset more times... What do you thing? Quote Link to comment Share on other sites More sharing options...
phil_m Posted January 26, 2016 Share Posted January 26, 2016 There is a tiny gap when you switch patches, yes. The HD500X doesn't have spillover between patches. Quote Link to comment Share on other sites More sharing options...
filippou2 Posted January 26, 2016 Author Share Posted January 26, 2016 Thank's for the answer! How can I minimeze this? :( I use to play pod in a loop of my head (H&K tubemeister) Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted January 26, 2016 Share Posted January 26, 2016 Thank's for the answer! How can I minimeze this? :( I use to play pod in a loop of my head (H&K tubemeister) I get around it by using a lot of dual-amp patches. Pairing either clean and dirty rhythm tones (with a boost assigned to a FS in the dirty amp path if I need it for leads), or a dirty rhythm and a lead tone. Then assign the channel volume of each amp to the expression pedal (ie heel down for clean, toe down for dirty), and you can transition smoothly from one sound to the other without changing patches. 2 Quote Link to comment Share on other sites More sharing options...
PeterHamm Posted January 26, 2016 Share Posted January 26, 2016 I also got around it by making patches (usually with only one amp) where I can use an EXP to go from clean to dirty AND add a distortion pedal of some kind. I almost never switch patches within a song. Quote Link to comment Share on other sites More sharing options...
filippou2 Posted January 27, 2016 Author Share Posted January 27, 2016 mmmmm.... The problem is that my pod (via midi) also control the channel of my head (H&K tubemeister 36)...for example 1A: Clean channel of AMP + some effects of pod 2A: Distortion of AMP + some effects of pod etc... And so i need to change preset every time :wacko: Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted January 27, 2016 Share Posted January 27, 2016 mmmmm.... The problem is that my pod (via midi) also control the channel of my head (H&K tubemeister 36)...for example 1A: Clean channel of AMP + some effects of pod 2A: Distortion of AMP + some effects of pod etc... And so i need to change preset every time :wacko: There's not a whole lot you can do then, unless you want to experiment with some of the amp models, and only use the head for power. Quote Link to comment Share on other sites More sharing options...
pfsmith0 Posted January 27, 2016 Share Posted January 27, 2016 The only way to NOT get the "latency" is to NOT switch patches within a song but just turn on/off FX. If you need more sound variety within the song (the main reason to switch patches) then switch to FS1-8 mode. Only switch patches between songs when there's time for the mute. The mute drives me CRAZY so that's what I do, Run the HD500 in FS1-8 to get all sorts of FX within a song. Then switch patches for the next song. I'm not sure, but I think MIDI can be used to turn on/off FX in FS1-8 mode (someone will correct me if I'm wrong), so there should be no loss flexibility using MIDI. FYI, what you're describing is not really latency but an outright mute. I.e., there's no delay in the sound. Quote Link to comment Share on other sites More sharing options...
DunedinDragon Posted January 27, 2016 Share Posted January 27, 2016 I'm with pfsmith0 on this. I've come to the conclusion that the design parameters for the HD500X kind of assumed one patch per song, and within that patch you might make changes to the configuration by way of footswitches. Since I only change patches between songs that's never been a problem for me given the variety of ways you can use dual effects on a single button and toggle them back and forth or use different signal chains, but I guess it would depend on your needs in the music. Quote Link to comment Share on other sites More sharing options...
phil_m Posted January 27, 2016 Share Posted January 27, 2016 I'm with pfsmith0 on this. I've come to the conclusion that the design parameters for the HD500X kind of assumed one patch per song, and within that patch you might make changes to the configuration by way of footswitches. Since I only change patches between songs that's never been a problem for me given the variety of ways you can use dual effects on a single button and toggle them back and forth or use different signal chains, but I guess it would depend on your needs in the music. Well, I don't know if the designers made that assumption or not. I personally think that in the context of a full band, no one is going to notice if there's spillover between most transitions or not. I can seen if it's certain styles of music - ones where you depended on long delay and/or reverb trails to fill the audio space, yes, that would definitely be noticeable. But in a typical rock or pop song, no one is going to notice as long as your transitions are done in time with everything else. And, actually, having no spillover can actually be desirable in many transitions. The one singer I played with for a long time always got irritated if my delay tails bled into stops. Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted January 27, 2016 Share Posted January 27, 2016 The one singer I played with for a long time always got irritated if my delay tails bled into stops. You can't count that...singers get pissy if the sun moves behind a cloud without their consent. ;) Quote Link to comment Share on other sites More sharing options...
spaceatl Posted January 27, 2016 Share Posted January 27, 2016 mmmmm.... The problem is that my pod (via midi) also control the channel of my head (H&K tubemeister 36)...for example 1A: Clean channel of AMP + some effects of pod 2A: Distortion of AMP + some effects of pod etc... And so i need to change preset every time :wacko: You do not have to change presets everytime... You can program midi commands into an FS within a patch on the POD...make the command line up with your head and you head can change channels in the patch...Basically, your head has midi learning in it, so you really are not limited to PC commands...From what I recall, you can set reverb, channel, power with one command on that head and just tell the head what command to learn to trigger a whole setup on the head... Quote Link to comment Share on other sites More sharing options...
filippou2 Posted January 27, 2016 Author Share Posted January 27, 2016 You do not have to change presets everytime... You can program midi commands into an FS within a patch on the POD...make the command line up with your head and you head can change channels in the patch...Basically, your head has midi learning in it, so you really are not limited to PC commands...From what I recall, you can set reverb, channel, power with one command on that head and just tell the head what command to learn to trigger a whole setup on the head... mmm...and so with 1A preset (for example) i can configure a different midi signal for FS1 or FS2? Quote Link to comment Share on other sites More sharing options...
CipherHost Posted January 28, 2016 Share Posted January 28, 2016 mmm...and so with 1A preset (for example) i can configure a different midi signal for FS1 or FS2? Not to steal spacealt's thunder, but YES. Quote Link to comment Share on other sites More sharing options...
filippou2 Posted January 28, 2016 Author Share Posted January 28, 2016 Not to steal spacealt's thunder, but YES. Mmm..sorry for my poor english but...what's spacealt's thunder?? 😅 Quote Link to comment Share on other sites More sharing options...
CipherHost Posted January 28, 2016 Share Posted January 28, 2016 Mmm..sorry for my poor english but...what's spacealt's thunder?? It is a colloquialism. According to (http://idioms.thefreedictionary.com/steal+thunder), to steal someone's thunder would be "To use, appropriate, or preempt the use of another's idea, especially to one's own advantage and without consent by the originator.", or "to do something that takes attention away from what someone else has done." Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted January 28, 2016 Share Posted January 28, 2016 How can I minimeze this? Volume. Making sure that there isn't a drastic difference between the volume of a "blank" patch and your patch will help make the "drop to zero" less noticeable. I've also found that making patches similar in construction will help - meaning, same amp in the same position. And if same fx are used, put them in the same position. Of course, that part should just be common sense because you wouldn't really need too drastic of a change within a song. Right? Quote Link to comment Share on other sites More sharing options...
pfsmith0 Posted January 28, 2016 Share Posted January 28, 2016 It isn't so much a question of spill over as it is mute. Your signal is just.... gone... for a short blip. You really have to adjust your arrangement so it doesn't impact anything. I can't do it. It cramps my style too much. It is so much easier for me to just use the FX switches within a given song. That gives me tons of variations. Quote Link to comment Share on other sites More sharing options...
filippou2 Posted January 28, 2016 Author Share Posted January 28, 2016 It is a colloquialism. According to (http://idioms.thefreedictionary.com/steal+thunder), to steal someone's thunder would be "To use, appropriate, or preempt the use of another's idea, especially to one's own advantage and without consent by the originator.", or "to do something that takes attention away from what someone else has done." OKK thank's so much... I'm trying now....but I have a nooby question: If I set an effect control of the patch 1B in FS5 to activate tremolo (for example) the pod change into preset 1A...how can I activate the fs control (from fs5 to fs8) without change patch?? Quote Link to comment Share on other sites More sharing options...
CipherHost Posted January 28, 2016 Share Posted January 28, 2016 OKK thank's so much... I'm trying now....but I have a nooby question: If I set an effect control of the patch 1B in FS5 to activate tremolo (for example) the pod change into preset 1A...how can I activate the fs control (from fs5 to fs8) without change patch?? You are in "Preset Mode". Only FS1 thru FS4 are available to turn effects on or off or assign MIDI CCs. To assign FS5 thru FS8 you need to be in "Pedalboard Mode". To access the System Setup options, press and hold the VIEW button. Here you can configure several device functions, Input & Output settings and more.The first page gives you the option for the Footswitch Mode (Knob 1): Configures the function of POD HD500X footswitches FS5 through FS8 for either “Pedalboard Mode†or “Preset Modeâ€. This setting is global. The manual is your friend. http://line6.com/support/manuals/ Quote Link to comment Share on other sites More sharing options...
filippou2 Posted January 28, 2016 Author Share Posted January 28, 2016 You're right .. But The manual is not always clear ( for me)..tomorrow i'll write you The responce :) Quote Link to comment Share on other sites More sharing options...
filippou2 Posted January 30, 2016 Author Share Posted January 30, 2016 Ok guys thank's a lot, it's a good solutions.. But i'm not able to do this things: I have a digital delay always on and an analog delay off..when i'll press fs4 i'd like to turn on Analog delay and tun off the digital delay...can it be possible?because i'm not succeeding :( Quote Link to comment Share on other sites More sharing options...
DunedinDragon Posted January 30, 2016 Share Posted January 30, 2016 Just assign both the analog and digital delays to the fs4 and default the digital delay to being on and the analog delay to off. Then when you hit the fs4 it will toggle between the two. It's a bit decieving because the light on the fs4 switch will be unlit when the analog delay is on, and it will be lit when the digital delay is on. Quote Link to comment Share on other sites More sharing options...
duncann Posted January 30, 2016 Share Posted January 30, 2016 When toggling between two effects with one switch, the thing that determines the state of the light will be whatever effect is first in the chain. Quote Link to comment Share on other sites More sharing options...
filippou2 Posted January 30, 2016 Author Share Posted January 30, 2016 When toggling between two effects with one switch, the thing that determines the state of the light will be whatever effect is first in the chain. Inverting the order change this possibility...omg it's more difficult of monkey island :D Quote Link to comment Share on other sites More sharing options...
brue58ski Posted February 1, 2016 Share Posted February 1, 2016 I'm with pfsmith0 on this. I've come to the conclusion that the design parameters for the HD500X kind of assumed one patch per song, and within that patch you might make changes to the configuration by way of footswitches. Since I only change patches between songs that's never been a problem for me given the variety of ways you can use dual effects on a single button and toggle them back and forth or use different signal chains, but I guess it would depend on your needs in the music. Yes. I would say the dual stereo path capability is proof of that. Quote Link to comment Share on other sites More sharing options...
filippou2 Posted February 4, 2016 Author Share Posted February 4, 2016 Ok guys..the midi section is functionally! But in FS5-8 there's a "contradictory" situation.. for example: If i have to pass from a sound with flanger and delay to a sound without these effects but with tremolo: i have to press two button to turn off flanger and delay and one to turn on tremolo...but i have bought a multieffect pedalboard to avoid to do "tip tap" with single pedal... How is it possible that in FS5-8 I can't automatically turn off some effect and turn on one effect with only one press of buttons!?!? The solution is ABCD mode, but to change preset there's the 40 ms of silence between the presets.... Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted February 4, 2016 Share Posted February 4, 2016 Ok guys..the midi section is functionally! But in FS5-8 there's a "contradictory" situation.. for example: If i have to pass from a sound with flanger and delay to a sound without these effects but with tremolo: i have to press two button to turn off flanger and delay and one to turn on tremolo...but i have bought a multieffect pedalboard to avoid to do "tip tap" with single pedal... How is it possible that in FS5-8 I can't automatically turn off some effect and turn on one effect with only one press of buttons!?!? The solution is ABCD mode, but to change preset there's the 40 ms of silence between the presets.... You can assign multiple FX to one footswitch within the same patch. When you save the patch, have effect A turned off, and effect B turned on. That way, when you hit the switch to which you've assigned them, it will toggle one effect on and the other off simultaneously. You can do exactly what you described above, with the 3 FX you mentioned, with one tap. Quote Link to comment Share on other sites More sharing options...
filippou2 Posted February 4, 2016 Author Share Posted February 4, 2016 Mmm..try to supposed this (true situation): When i'll press FS1 The pod send a midi input to my ampli (to have crunch channel) and FS1 turn on a digital delay.. When i'll press FS2 pod send a midi input to my ampli to have clean channel and The turning on off a modulation delay.. If I want to pass from FS1 to FS2 i have to turn off The delay of The FS1 and so i have to press more on one bottom ....or there's a faster solution? Quote Link to comment Share on other sites More sharing options...
BaylorPRSer Posted December 15, 2023 Share Posted December 15, 2023 If you want to take the "one patch per song" approach, does it follow that having a high gain amp in both channels A and B is out of the question? Say I had a Treadplate in one and an Angel Fireball in the other, would it possible to get to a clean tone without changing patches? Quote Link to comment Share on other sites More sharing options...
hurghanico Posted December 15, 2023 Share Posted December 15, 2023 On 12/15/2023 at 3:51 AM, BaylorPRSer said: Say I had a Treadplate in one and an Angel Fireball in the other, would it possible to get to a clean tone without changing patches? I don't know if you noticed that this thread is 7 years old.. Anyway to answer your question You can't get a clean sound from a single patch containing 2 hi gain amps. With the POD the only solution to obtain both the hi gain and clean sounds while remaining in the same patch (to avoid latency problems when changing the sound) is by assigning 1 hi gain amp to one channel and 1 clean amp to the other. Some more modern modelers have fewer limitations. _______________________________________________________________________________________________________________________________________________________________________ All about POD HD500/X help and useful tips 1 Quote Link to comment Share on other sites More sharing options...
BaylorPRSer Posted January 9, 2024 Share Posted January 9, 2024 On 12/16/2023 at 2:22 AM, hurghanico said: I don't know if you noticed that this thread is 7 years old.. _______________________________________________________________________________________________________________________________________________________________________ All about POD HD500/X help and useful tips Hey man. Thanks for the help as usual. Sorry it took me so long to reply. Had too much going on over the holidays. I was actually under the impression that it's better forum etiquette to search to see if an issue has already been covered, and ask your question there. Is there a point where a thread is just TOO old? Let me know. I appreciate the forum, so I'd like to comply with whatever best practices are. Quote Link to comment Share on other sites More sharing options...
hurghanico Posted January 9, 2024 Share Posted January 9, 2024 On 1/9/2024 at 11:30 AM, BaylorPRSer said: Hey man. Thanks for the help as usual. Sorry it took me so long to reply. Had too much going on over the holidays. I was actually under the impression that it's better forum etiquette to search to see if an issue has already been covered, and ask your question there. Is there a point where a thread is just TOO old? Let me know. I appreciate the forum, so I'd like to comply with whatever best practices are. You're welcome.. There is certainly no deadline for any thread... it's just that the older it is, the less likely it is that any of the previous posters will notice your new post and/or possibly respond.. _______________________________________________________________________________________________________________________________________________________________________ All about POD HD500/X help and useful tips Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted January 9, 2024 Share Posted January 9, 2024 On 1/9/2024 at 5:30 AM, BaylorPRSer said: I was actually under the impression that it's better forum etiquette to search to see if an issue has already been covered, and ask your question there. Is there a point where a thread is just TOO old? It will vary with the site, the post, and what you have to say to the post. Example: Post your white guitars. No limit. Example: I upgraded to Windows 10 and can't get it to work. Limit - because Windows 10 has been patched since the post. And L6 has patched their stuff since the original W10 that didn't let things work. Also, because this is a device specific section, most respondents from old posts have moved on to the next product. You will get almost nowhere if trying to engage someone from an old post, especially someone who has 1 post, because they didn't come here to participate. They just wanted their issue fixed. Quote Link to comment Share on other sites More sharing options...
