Guest Markmyers Posted March 9, 2017 Share Posted March 9, 2017 Title says it all. Trying to use app and not making progress. Tried searching and I'm coming up empty-handed. Sorry if I'm missing something obvious. Quote Link to comment Share on other sites More sharing options...
guitardad123 Posted March 9, 2017 Share Posted March 9, 2017 Can you be more specific? I assume the app runs, you just want some usage instruction This link is for Amplifi, minus the Bluetooth stuff and some appearance, the Spider Remote App is basically the same thing functionally Quote Link to comment Share on other sites More sharing options...
ADBrown Posted March 10, 2017 Share Posted March 10, 2017 Anything specific you need help with? Clicking on your amp or an effect will bring up the parameters, clicking on the icon again will let you change out the effect or amp. From the tones window you can search and call up previous saved tones. These are just a few basic pointers that should get you started, let me know if you need more specifics. Quote Link to comment Share on other sites More sharing options...
CBirnley Posted March 26, 2017 Share Posted March 26, 2017 Is there a way that I can search for a tone that someone else may have created and save that? If so, please advise. 1 Quote Link to comment Share on other sites More sharing options...
lungho Posted March 26, 2017 Share Posted March 26, 2017 The tones from customtone.com are not compatible with Spider V. Any tones for the AMPLIFi products will work with Spider V. Simply tap the "Cloud" option. The results field will be blank until you type something in the field and then tap search. Check the attached photo for guidance. Quote Link to comment Share on other sites More sharing options...
Guest joe orlando Posted March 30, 2017 Share Posted March 30, 2017 Can anyone point to a tutorial or user manual for Spider Remote? I just bought the V 60, downloaded the app to my ipad and can't find any details at all on operation. e.g., what is the difference between the app and the edit function on the amp? Quote Link to comment Share on other sites More sharing options...
ADBrown Posted March 31, 2017 Share Posted March 31, 2017 Can anyone point to a tutorial or user manual for Spider Remote? I just bought the V 60, downloaded the app to my ipad and can't find any details at all on operation. e.g., what is the difference between the app and the edit function on the amp? Any effect/amp parameter you can adjust on the app can also be adjusted on the front of the amp. On the amp when you are on the amp or effects mode screen hitting the edit button will bring up a menu with editable parameters, just as in the app. Quote Link to comment Share on other sites More sharing options...
drjeff007 Posted May 1, 2017 Share Posted May 1, 2017 If I tweak some settings within Spider Remote how do I save them? Cheers Quote Link to comment Share on other sites More sharing options...
pber2025 Posted May 1, 2017 Share Posted May 1, 2017 On Android, select Details at the top. A flashing floopy disk icon will flash at the top. Select the floppy disk icon and you will have options to save. Quote Link to comment Share on other sites More sharing options...
oldmanrockband Posted July 13, 2017 Share Posted July 13, 2017 Man, somebody needs to write a manual for this thing! Am I right in what I just read a few post up? I can search the cloud, but I have to know what I'm searching for? No drop down or listing of available patches on the cloud? And I drop a grand on this gear and I have to watch amplifi videos? Also, how do I view/change the order of the effects/amps etc. in the chain, and how do i see the chain? I don't see a chain like there is at he top of the amplifi app. Thanks Andy 5 Quote Link to comment Share on other sites More sharing options...
Thunder14 Posted September 28, 2017 Share Posted September 28, 2017 Hi, I have the Line 6 Spider V 60 Amp. I downloaded the Spider V remote app but I cannot connect the 2 together. Is there a blue tooth accessory I need? Thanks in advance 1 Quote Link to comment Share on other sites More sharing options...
guitardad123 Posted September 28, 2017 Share Posted September 28, 2017 You need your phone cable. The charger cable on my phone works fine. Some phones require an OTG (on the go) connector. None are bluetooth.There are PC/Mac editors now was well. 1 Quote Link to comment Share on other sites More sharing options...
lumper Posted February 26, 2018 Share Posted February 26, 2018 Loving this thread, I too just got a Spider V 240 HC and although I get most of it, there are a few things that I am missing. Cant find for example anywhere to add a vol boost to the function 1 switch on the FBV MKII shortboard, it shows it in the manual and pre set manual, in the description for some of the pre sets but I cant find it anywhere. my function 1 turns on comp.I downloaded sand tried control or remote for the pedal, but I dont see how I Can reassign it to boost anywhere, Also, you mentioned the cloud for custom tones that will work, where do you search that from? I dont see anything like that in the program on Win 10. Also, trying to figure out how to assign a switch to turn on or off the wah so I can punch it on and off as I need it while staying in the patch I am using, I think I can just use it on the comp or dist switch, but I wondered what if any was a better way to do it. Ideally I would like to boost for solo, hit a delay and wah. Im trying to set up for live shows, I had my spider IV set up for years and forgot how tough it can be at first when you are out of the loop for a while. All I need is a solo vol boost, a wah switch and then a delay with a little chorus for a solo sound while in a patch, just to enhance the existing tone and thicken it a bit for a solo, it would be nice to do that in 1 switch but I think as it is I Can do it in 2, use Function 1 for boost, then use one of the programmable switched for the wah? Any tips or advice would be great, I def can use all the help I Can get. Quote Link to comment Share on other sites More sharing options...
lumper Posted February 26, 2018 Share Posted February 26, 2018 Somene said. "The tones from customtone.com are not compatible with Spider V. Any tones for the AMPLIFi products will work with Spider V. Simply tap the "Cloud" option. The results field will be blank until you type something in the field and then tap search. Check the attached photo for guidance. " Where is the Cloud option? I dont see that anywhere. UPDATE: I downloaded the android app for line 6 remote and it has a cloud search function, I used it and it worked, but when I click on a fil to download it doesnt seem to do anything, I am going to search the phone to see if maybe it created a folder and put them in there. It doesnt seem to have downloaded anything, it seems like if I search the cloud, I get results I click on them then hit edit I can see the patch and what settings were used, but no download, what am I missing? I dont have the otg thing to connect my micro usb phone cable to the amp yet. Will that make a difference? When I go to custom tones on line 6 page it shows several amps to select, Amplifi is not one of them, so if I just search for say "Godsmack" I see a list, but if I download one and save it, then try to open it with the remote editor, it doesnt see the file type, how do I know what are amplifi patches? Sorry, Im slow at first I get overwhelmed and it takes me a minute, I would really appreciate your patience and assistance., Thanks Matt 1 Quote Link to comment Share on other sites More sharing options...
tatey Posted February 27, 2018 Share Posted February 27, 2018 Hi I have just bought spider v 240 tried the spider remote app on my Samsung s6 tablet it says device incompatible, so tried my Sony Xperia m5 same message, installed Samsung smart transfer still my any ideas???? Quote Link to comment Share on other sites More sharing options...
guitardad123 Posted March 24, 2018 Share Posted March 24, 2018 Some tablets require an OTG connector for USB function needed with other devices. Samsung is one of them. Works on my new Note with the OTG adapter. Quote Link to comment Share on other sites More sharing options...
Ismael_Rod Posted March 24, 2018 Share Posted March 24, 2018 Hola a todos recientemente descargue el app spider remote, resulta que lo reconoce pero cuando intento subirle el volumen al amplificador no funciona, igual cuando desconecto el teléfono los efectos ya no suenan como antes... como puedo solucionar el tema del volumen general gracias amigos. Quote Link to comment Share on other sites More sharing options...
AESHIRA Posted May 4, 2018 Share Posted May 4, 2018 Please, How can I Organize My tones or Linguee ........It is impossible Access. Thanks you Quote Link to comment Share on other sites More sharing options...
flux1968 Posted June 28, 2019 Share Posted June 28, 2019 Why not just produce a manual or tutorial for the app explaining its functionality, features and the parameters? I just got a Spider V 20 and the Spider Remote app and I'm spending more time trying to figure out its features than I am playing. 15 Quote Link to comment Share on other sites More sharing options...
Breathcollector Posted July 28, 2019 Share Posted July 28, 2019 On 9/28/2017 at 6:08 PM, guitardad123 said: You need your phone cable. The charger cable on my phone works fine. Some phones require an OTG (on the go) connector. None are bluetooth. There are PC/Mac editors now was well. Hello mate ! I tried to connect my phone with the app, but the amp says unsupported device! Can u help me out ? 1 Quote Link to comment Share on other sites More sharing options...
Random1643 Posted July 30, 2019 Share Posted July 30, 2019 On 6/28/2019 at 1:11 PM, flux1968 said: Why not just produce a manual or tutorial for the app explaining its functionality, features and the parameters? This. You nailed it flux1968. And get beyond the What to the How. What are the specific steps, the instructions that I as a Spider V Remote App User need to take to get basic sh*t done, like in my case create, save and backup unique amp/mic/cab/effect profiles (batches of settings) for each instrument I play at gigs. My geek kid eventually took a look at the software and showed me how to do this, but that was after weeks of finding nothing in the Knowledge & FAQs section - there is exactly 1 video on the Videos page that pertains to the Spider V amps but has nothing to with my questions, in the Spider V Forum days after I posted the same set of questions one kind respondent offered some interesting stuff but not what I'm asking about, and Customer Service was a couple of weeks of wasted time before I gave up - lots of What and zero How. Line 6 is just a puzzle to me. Love the product but after that it feels like we're kinda out here on our own. The steps BTW to creating "profiles" are very easy but not if you don't know how. I recently received an email from Line 6 inviting me, as a Spider V 120W amp owner, to download a "Major Spider V Firmware Update," Firmware 2.0. Sounds wonderful but given the last coupla months is it a threat or an opportunity? 3 1 1 Quote Link to comment Share on other sites More sharing options...
uhartm Posted September 27, 2019 Share Posted September 27, 2019 I submitted a trouble ticket in order to find this hidden "Spider Remote Pilot's Guide." In the Overview section of the Spider V Family Pilot's Guide it states one is "available for download at https://line6.com/manuals. Well, there are only manuals for hardware, not apps. I am figuring it out as I use the app, trial and error, but I'm wasting a lot of time and still have many questions. By reading all the posts it appears I am not alone. I don't think this manual exists. Creating user manuals isn't that difficult. I've done many. it's a matter of making outline of the various functions, describing what you want the reader to understand for each function, capturing screen shots/snippets from various devices, pasting them into the document, drawing arrows, circles or boxes to call attention to a specific information, and then writing the procedures to follow for each function. 4 Quote Link to comment Share on other sites More sharing options...
czhr10 Posted October 21, 2019 Share Posted October 21, 2019 @uhartm , Did you get a reply from Line 6 on your ticket ? 1 Quote Link to comment Share on other sites More sharing options...
uhartm Posted October 21, 2019 Share Posted October 21, 2019 Yes. But not any help. Jason, Line 6, said there is no Pilot’s guide to the ‘remote app’ as of yet. Then he referred me to the video on YouTube, “Interacting with Spider V | Line 6,” which is more of a amp marketing video. The video is 6:42 min long and the remote amp isn’t discussed until 4:50 min. And ends at 5:12 min. The demo person says, “If you are happy with a sound you can save it.” But he doesn’t show you how to do it. Really? When I bought my first car, computer, wife and English setter I got user manuals. I threw the ones out for my wife and dog as they quickly got outdated. 4 2 Quote Link to comment Share on other sites More sharing options...
czhr10 Posted October 26, 2019 Share Posted October 26, 2019 On 9/27/2019 at 2:31 AM, uhartm said: I On 10/21/2019 at 6:03 PM, uhartm said: Yes. But not any help. Jason, Line 6, said there is no Pilot’s guide to the ‘remote app’ as of yet. Then he referred me to the video on YouTube, “Interacting with Spider V | Line 6,” which is more of a amp marketing video. The video is 6:42 min long and the remote amp isn’t discussed until 4:50 min. And ends at 5:12 min. The demo person says, “If you are happy with a sound you can save it.” But he doesn’t show you how to do it. Really? When I bought my first car, computer, wife and English setter I got user manuals. I threw the ones out for my wife and dog as they quickly got outdated. Ok, to bad.. I enterred an idea in the idea's form to create sucha manual.. BTW, ar you saying that you bought your wife and taht she came with a manual ? :-) Quote Link to comment Share on other sites More sharing options...
silverhead Posted October 26, 2019 Share Posted October 26, 2019 Wives come with a womanual. They're unreadable. 1 2 Quote Link to comment Share on other sites More sharing options...
KeithO47 Posted January 22, 2020 Share Posted January 22, 2020 So if I got this right no manual exists for the spider remote app and the instructions for my V20 MKII are only marginal. I'm 72 yrs and I don't have another lifetime to learn all the features and would appreciate a help screen on the web site that is product and app specific. It appears to be a great product, but unless you are a professional or a bloody genius it becomes mind numbing! 1 2 Quote Link to comment Share on other sites More sharing options...
artyr-1204 Posted January 25, 2020 Share Posted January 25, 2020 где можно скачать приложение. Quote Link to comment Share on other sites More sharing options...
ABRANSHBALIYAN Posted April 9, 2020 Share Posted April 9, 2020 can anybody help me out in installing the software for spider amp. i just brought spider V 20 amp and dont know how to pair it up with mobile version or pc version Quote Link to comment Share on other sites More sharing options...
KeithO47 Posted April 9, 2020 Share Posted April 9, 2020 Just connect either the mobile device or the PC via the USB connection Quote Link to comment Share on other sites More sharing options...
ABRANSHBALIYAN Posted April 15, 2020 Share Posted April 15, 2020 I CONNECTED IT WITH A USB AND DOWNLOADED SPIDER REMOTE APP ON PC . PLZ HELP ME HOW TO PAIR IT WITH MY AMP Quote Link to comment Share on other sites More sharing options...
KeithO47 Posted April 19, 2020 Share Posted April 19, 2020 On 4/15/2020 at 2:01 AM, ABRANSHBALIYAN said: I CONNECTED IT WITH A USB AND DOWNLOADED SPIDER REMOTE APP ON PC . PLZ HELP ME HOW TO PAIR IT WITH MY AMP Connect USB to back of amp then go to presets on application and your done you can also download to your app from the cloud Quote Link to comment Share on other sites More sharing options...
florinist Posted May 7, 2020 Share Posted May 7, 2020 Hi, Like the majority that posted in this thread, I have real difficulty in using the Spider App on my Android. I have purchased an adaptor for USB to USB 3 (quite cheap on Ebay) so I can connect my phone directly into the Amp with the dedicated cable . Mind you, there is a switch with two positions at the back of the amp. One needs to choose the correspondent one, either Android or IOS. However, only after I have found this forum I discovered there is an app for my laptop as well. That makes your life much easier. You can find loads of tones, modify them to your liking, rename them, replace the pre-loaded tones from your amp with the ones you found and saved on your laptop or in "My Tones" folder online. I agree with everyone that Line 6 should come up with a tutorial or user guide for using the app. 1 Quote Link to comment Share on other sites More sharing options...
ttato1 Posted May 10, 2020 Share Posted May 10, 2020 buenos días yo tengo un v20 intente conectarlo con mi sansun a50 con sus cables correspondientes y no hay manera de conectarlo o yo no se .sin embargo con el portátil no hay problemas conecta a la primera. si alguien tiene alguna solucion para lo del movil se ria la caña. gracias Quote Link to comment Share on other sites More sharing options...
ADBrown Posted May 11, 2020 Share Posted May 11, 2020 Hi all, for anyone who is interested, Line 6 recently did a livestream lesson on Spider V Mk2 amplifiers. The video also dives into the app a bit. Quote Link to comment Share on other sites More sharing options...
Yanarchiste Posted June 7, 2020 Share Posted June 7, 2020 -This Spider Remote app doesn't work well with Samsung Note 9 phones...freezes all the time and I had to reboot it because it turned off and wouldn't open back... -I've created a sample and when I hit the "Save To SpiderV 240" option, my phone started downloading all the original banks... Took 40 minutes until I could finally save my sh*t in the hardware. -Often there are connection lost between the app and the amp. -All the samples I find on the Cloud doesn't work at all... This is very sad since I own one of the latest and best phone out there and I bought a brand new cable so I could use the app... But now I have no choice but buy another phone/tablet for this. Quote Link to comment Share on other sites More sharing options...
Alfred8805 Posted June 7, 2020 Share Posted June 7, 2020 I just purchased the V 20 mkII and i can't find the pc remote app Quote Link to comment Share on other sites More sharing options...
Yanarchiste Posted June 8, 2020 Share Posted June 8, 2020 20 hours ago, Alfred8805 said: I just purchased the V 20 mkII and i can't find the pc remote app https://line6.com/software/index.html Spider V Remote Mac/Win 2.00 Download Just go to Line6 Official site, hit the DOWNLOAD menu, choose the "Spider V Remote" in ALL SOFTWARE menu. There you GO ! I have Windows 10 and it works perfectly. Quote Link to comment Share on other sites More sharing options...
patricia1012 Posted July 14, 2020 Share Posted July 14, 2020 how do i control my spider v 60 amp with my computer Quote Link to comment Share on other sites More sharing options...
Tvanburen Posted September 15, 2020 Share Posted September 15, 2020 Hey guys, i just got the spider v 20 amp and im trying to use the remote app with it. I have the OTG cable and even when everything is plugged in and setup, the amp is not visible in the app and changing tones does not affect the sound at all, please help! Quote Link to comment Share on other sites More sharing options...
