Lockdown fever hit me hard when three days into the 5 weeks (so far) I realised I was a long way from my music gear.
I searched around and found a shiny new JTV 59,  a POD HD500X, a StageSource L2M and this afternoon my DT25 will arrive to complete the Dream Rig (yeah, I'm 8 years late to the party).
All that was missing was a battery on the JTV. The dealer let me know it was missing and the price was lowered accordingly.
After reading all the useful threads on here I ordered a Line6 battery from Thommen (and a week later a spare from Andertons) but I still wanted a couple more as they are a useful size for some LED camera lights I run.
I searched the web for JTV Variax compatible batteries and bought two from different suppliers.
One will simply not charge on the Variax charger and when charged elsewhere will not be recognised by the Variax.
The other has charged happily from a third party charger AND the Variax recognises it. I'm using a third party charger as my Variax one just lights up with a constant red LED on power up without a battery so I have a new one on order.
Both batteries are branded Cameron Sino. The one that works has the model number CS-AML710BL (part no 180-7100) It is rated at 2200mAh and is 16.28Wh just like the Line 6 battery, although the case is quite different in its detailing.
The one that doesn't work in the Variax is Model No: CS-LNE100SL (Part no: BA12) It is rated at 2600mAh and 19.24Wh.
I'll be keeping both as light/camera batteries and using on as a crisis spare but as far as possible using my approved batteries when every I'm not running the POD.
The battery that did work came from batteryupgrade.co.uk.
Thommen and Andertons.co.uk are currently ( May 1st, 2020) both showing Line6 batteries in stock.
Obviously I can't guarantee the performance or safety of these batteries but the Variax seems happy to accept it.
Sorry my first post is such a long waffling one. Lockdown.....
ONLY USE Line 6 batteries in these guitars. Li-Ion is not something to mess with.
Part# 98-034-0009,... use Only these batteries, it's a known quality and quantity.
Anything else is nothing but problems and failure hazards.
When transporting or shipping these guitars, REMOVE the battery from the guitar
and send it along in a side pouch or something in the shipping box.
Noted and acted upon. As I said I now have two Line6 batteries plus the HD500X so I should be ok for power.
I have a JTV-59 US and Korean and several Official L6 LiOn Batteries (two are relatively new rarely used batteries).  All the batteries are fully charged and work in the USA but none work in the Korean.  The Korean does work when using a TSR into the Line6 power supply box.  Any ideas why or any potential fix?  Is there a reset for the battery?
The guitar works and the batteries work in the identical electronic in the USA JTV so I can only imagine it is a problem with the battery box in the Korean guitar. Did it ever work with the batteries? Have you tried carefully applying contact cleaner to the connector pins in the battery box?
"Have you tried carefully applying contact cleaner to the connector pins in the battery box? " --- That won't work.
1) Chances are, it's probably the power management circuit in the battery box, glitch in the program or intermittent
solder point, resulting in a false low signal to the main board.
2) The Korean 59 is an early serial number from 10 years ago and general servicing on it is long overdue,... the guitar
version of a car's 50,000 mile tune-up.
Surrender is for foes,... you're among friends here. And I'm the guy here at Line 6 that services these guitars.
Log a support ticket in your account and they will let you know your options.
"The Korean 59 is an early serial number from 10 years ago and general servicing on it is long overdue "
So what is this general servicing you speak of? Is it just normal guitar stuff or do the electronic innards need some kind of regular servicing?
To Mr. Psarkisian: you mention in this thread, and elsewhere, that in due course a Variax should visit your shop for an overall general maintenance procedure. If I may ask, in that my 2012 JTV69s is planned for a trip to the local line 6 authorized repair location for replacement of a faulty input jack assembly, would they also be equally capable of performing the general maintenance you refer to, or should the JTV be shipped to you at line 6 for this job?
Also, are you referring to a focus chiefly on electronics, or the physical aspects of the JTV too, as I am in good shape with all other typical adjustments. With thanks in advance for your reply.
1) Your local authorized service center should be able to handle that.
https://line6.com/find/service_center/
There's a pull down sub menu for specifics (dealer, service, guitar service), choose the one
in your area for guitar service for the one closest to you. I'm always available to them for queries
should they want to pick my brain. Usually it's for something they already know and just want
confirmation from me. They're pretty good. We wouldn't accept anything less.
2) I do electronics, and also trained in lutherie as well. Been getting paid do this in all things tech of audio/visual world,
for some 45 years now when I first became crew member for the group Iron Butterfly (1975). Lots of time at this.
3) Set-up on these is not quite the same as a passive electronics guitar. Certain quirks to deal with, so it's best to
have an authorized service center do it. Interactions between magnetics and piezos makes it touchy that way.
Thanks for your quick response, Mr Psarkissian.
Indeed, I see from the list you linked that the local authorized repairman - Coupe Communications, Ambler, PA - is where I'd planned to take it to.
On behalf of others in the forum, thank you for your highly valued advice and comments.
Best regards.
Do you check the front part of the guitar bag? My battery was there with the manual in a plastic bag
No, he’d sold it separately. Strange, but I got a discount so no problem.
Regarding that video,...
Those are Li-Ion batteries,... DO NOT mess with them.
Line 6 does not support modifications to its products.
This is a safety issue. The product can get damaged or injury to you can occur.
DO NOT DO THAT!
Thank for your advice but why not? Are that batteries in original pack not from China? It works perfect for 10% of the price.
It's a safety issue. If you damage something, Line 6 will not support it because of the modification.
If you get injured, it's becomes your responsibility. Li-Ion batteries are not something to be messed with.
Charge/discharge specs have to be correct. There are variations between manufacturers that can cause issues.
Use the correct and official battery. In this case, taking the cheap route can be dangerous.
Both my Line 6 batteries stopped recharging, I can't find replacements, all are out of stock or no longer part of portfolio. Any alternatives?
Where can I order these batteries as no music shop in NL has them anymore.
My first post has details in there but only one is recognised by the Variax despite both being recommended by the vendors only one works. And as said by the Line6 staffer on this thread you could damage your guitar and void your warranty.
