49 -
Everything posted by tooloudtoobad
you need to set a couple of patches that sound good thru the headphones you do not need every patch set to that eq thats why there is user1 2,3,4 to save patches
are you making your own patches in the helix I use the speaker sims in the power cabs I like the vintage and green speakers I make my patches on the helix to sound good thru PC+ cabs. If i switch it to FFR i get that blanket over it sound but patches were made with speaker sims from the PC's
one thing you have to do to get the two 1x12 PC+ cabs to work together is power on helix first then power on what will be cab 1 then power on cab 2.........
Got a new PC+ 212 recently - what makes the speaker modeling so good?!
tooloudtoobad replied to gearmana's topic in Powercab
I'm with gearmana I like the speaker sims from the powercabs, I have 2 1x12 plus powercabs. I dont like the frfr or IR's thru the powercabs. -
I was able to buy 3 25' AES/EBU cables for 60.00 bucks one to each of my powercabs and a spare for the price of one........
Yes I needed to download HX Edit 2.90....... things are back to normal........ Thanks..... Chuck
Made a backup of helix 2.8 before updating, did update to 2.91 I see all of my presets but all Snapshots are gone, all IRs but one are gone, did not see gen purple amp in amp list. Not sure if I should go to backup file or redo install to 2.91. When I bought the helix floor the first day I had it I updated to 2.8 really before I used it so this Is my first update with me having my own data in it. Chuck
The power cab + direct out sounds great I use the speaker emulation's on the power cab and go direct out of power cab to FOH for live gigs.
All In on Line 6: JTV-69 into Helix into Powercab 112 Plus
tooloudtoobad replied to Lone_Poor_Boy's topic in Helix
I have the same rig but I got a pair of Powercab plus cabs, dont know if i need 2 but I have them.......The helix is awesome,,,,,, I have not had the variax but a few weeks action was very high so i sent it to guitar tech for a setup still working on patches for the variax...... Have been giging with the Helix and PC's.... all gigs cancelled now bummer...... -
I tried the turning on order and it did work at home, will try at saturday's gig and report back............
- 34 replies
- powercab 212
- line 6 link
(and 1 more)
Tagged with:
I have been Having same Trouble with 2 Powercab Plus 1X12's, no sound from cab 2...... Have been just using one cab at gigs...... I will say one cab is loud enough but i have two to use....... My original thought was one for me and one i could aim more towards the rest of the band.........
- 34 replies
- powercab 212
- line 6 link
(and 1 more)
Tagged with:
What do you play your Helix through at home/ band practise?
tooloudtoobad replied to snarfarf's topic in Helix
At Home I play thru my Audio Interface into my Studio Monitors. Live I play thru a PowerCab Plus. -
PC/PC+ & Helix: How to create an effects loop?
tooloudtoobad replied to mblasick's topic in Powercab
You dont need an effects loop with the power cab you put the delays and reverbs after the amp block in the helix -
What Expression Pedal works with Line6 HX Effects?
tooloudtoobad replied to TheoHolsheimer's topic in Helix
Helix uses TS cable Not TRS cable............ at 10K ohms........- 21 replies
- expression pedal
- line6 hx effects
(and 2 more)
Tagged with:
is your katana the MKII version or the older one the new one has power amp in jack direct to power amp.....
ok played 1st gig with Helix and powercabs......... have been using helix and PC's in my studio room for a couple of months using both PC's in Mono...... set up for the gig and second powercab did not have sound..... had 1st PC on 3 foot drum riser it was plenty loud................ The other guitarist play a marshall combo and pedalboard he had a lot of Hum on the more distorted sounds........ The Helix was clear and awesome...... pretty happy so far have another gig in 5 days will see how that on goes.....
Can Anyone recommend a good stand for Helix Floor
tooloudtoobad replied to omairangel's topic in Helix
They don't call it Helix Floor for nothing !!!!! -
VINTAGE – Based on* the ubiquitous Celestion Vintage 30 which, despite its name, is commonly used and beloved for "modern" tones. GREEN – Based on* the Celestion Greenback speaker, typically paired with vintage Marshall® Plexi amplifiers for a signature classic rock tone. CREAM – Based on* the Celestion G12M-65, a higher powered version of the ceramic C12N with a brighter top end� JARVIS – Based on* the Jensen® P12Q, often paired with Fender® amps for great rich, full clean tones� BAYOU – Based on* the Eminence Patriot Series Swamp Thang™, which provides big aggressive bottom end with classic American tone, perfect for blues and jazz� ESSEX – Based on* the Blue Bell speakers often paired with Vox® amplifiers and Class A style amps for a "chimey" tone. HF OFF/ Natural – This is the natural sound and feel of the speaker in the Powercab with the high-frequency compression driver disabled and no EQ of any kind applied DINO – Based on* the Eminence Cannabis Rex™� Uniquely constructed with a hemp-based speaker cone material, the Cannabis Rex is described as having a smoky, smooth high-end definition, and boasts a full, clean tonality, with lots of body and sparkle LECTO – Based on* the Electro-Voice® EVM 12L. Designed for professionally precise, fully overdriven, punchy tones and brilliant cleans. They are a signature component of the classic Mesa/Boogie® sound� HERALD – Based on* the Celestion G12H(55) Heritage� Featuring a heavier magnet than the original G12M Greenback, this speaker replicates the sound of the original G12H� BROWN – Based on* the Celestion G12 EVH®. While the Greenback 20 played an essential role in the sound of Eddie Van Halen's unmistakable sound, this speaker was the based on the 60s version Greenback and used in his signature amplifier. SHADE – Based on* the Mesa/Boogie Black Shadow C90� Custom made for Mesa/Boogie by Celestion in the UK, this speaker provides a tight and controlled low end, aggressive midrange attack, and strong high-bass / low-mid punch� They are a feature in many Mesa/Boogie amps� JETSON – Based on* the Jensen C12K� The C12K is often paired with Fender® amps for great for a heavy mid and solid, straight forward, slightly darker tone� Can also present bold and heavy overdriven tones� Google is your friend use it
I will be using a Helix and 2 Powercab + cabs direct to board out of the powercab, so I have always been gigging with tube amp and pedalboard, a year or two ago I bought a Boss Katana Artist 100. Took it to gig And I just could not here it good in the mix so I got rid of it and got a Friedman Runt 50 and was happy. Now after having the helix for a few months the amps just dont sound as good anymore as they did to me. I have been in the same band for over 25 years same members except we have had about 5 Singers, the other guitarist plays a few different 20 watt tube amps He cant make it to this next gig so we have a guitarist that plays a marshall up to about 6-7 with a power brake. I will see how the helix does this saturday........
anyone sorry they bought the Powercab112 instead of the PC+?
tooloudtoobad replied to Hey_Joe's topic in Powercab
whatever connection type he is using can be turned off to the Big knob...... -
you can also go to global settings and go to volume knob controls and switch it from multi to 1/4...... I am using L6 Link cable to my PC's so as long as i dont have it on multi or digital its alot louder...... -
Yes I just keep replacing IR's in the same slot, if I find something i like i may move to the next slot to be able to compare. When Using ownhammer They will have 10 of the same 1-10 bright to dark If I like one i will load like number 1,3,6, and 9 then if you need it to be brighter or darker you can change it in menu at gig.
Do you pref PC+ speakers or cab sim in presets?
tooloudtoobad replied to GrampaBob's topic in Powercab
I prefer the speaker sims in the powercab I like the Vintage and Green Sims I Have 2 Powercab + cabs I will run one with Vintage and one with Green. -
Yes it will be fine you can switch the powercab on the back, I bought the powercabs so I would have a good stage volume for gigs, at the house I could be happy playing thru my Studio monitors but I do play thru the powercabs at the house. -
I have a pair of Yamaha HS5's the helix sounds great thru them.....
