Helix Ideascale Community Submissions
TheRealZap
Please vote this up if intrested
The 3.5 feature Disable Snapshot Control over Parameter Assignments doesn't work when the parameter assigned to a foot swtich is an ext amp command.
At the moment is not possibile to use a foot switch for (physical) amp channel control and snapshots because when you change snapshot the helix will trigger the ext amp relay inverting the footswitch state (and any other assignment eventually made to that switch).
I suggest adding a Snapshot Control on/off option like it happens for any block parameter.
  • 3 weeks later...
  • 2 weeks later...
Not sure if this is the right spot for this, but I'd like L6 to possibly add a feature in the HELIX world where Amp/Effect Parameters are automatically enabled for SNAPSHOTs so that things such as the DRIVE values in an Amp can be controlled via SNAPSHOTs for something like a CLEAN and DIRTY setting for each SNAPSHOT.  I know the feature is already there, but I'd like the option to have it enabled by default for all items in a Signal Chain.  I guess it's be a setting where for some users who'd never use it, it would be off but for others it would be on.  it would save a ton of time in creating patches without having to touch each parameter and enable it.
  • 2 weeks later...
I just noticed that in Helix Native software there are input and output level indicators. Would it be possible to add this to HX Edit? Its difficult to tell using headphones how loud an amp will be in real life going direct to a sound system but with the indicator you can see where your at and how much headroom you would have.
Thanks
Hey Line 6 Team, would you consider the following suggestions:
A way to use command center to toggle between two midi program changes on a single footswitch on the HX stomp
Having the footswitch light always illuminated when cycling between snapshots on a single switch on the HX stomp (helps with viewing snapshot changes on bright stages)
Adding the flux feature to all HX products
A smart harmonizer that intelligently harmonizes vocals to the guitar input (like TC Helicon)
Thanks!
Thanks!
if you really want these things, you want to put them on idea scale. They don't monitor this space for these ideas.
  • 1 month later...
  • 3 weeks later...
On 1/28/2024 at 10:01 PM, indigomirage said:
One more wish - please either make it so that updates don't reset all the global routing parameters (digital vs xlr inputs, etc...) or at least make these (all) parameters editable from within HX Edit (and included in backups).
This drives me bonkers.
When you perform an update to the Firmware, you are required to perform a Factory Reset. It is the “Reset” that returns all your Global settings back to the default settings. This is why you’re instructed to make backup of all the stuff in your hardware unit prior to the update.
Following a successful update of the firmware it is also suggested that you perform a “Restore from Backup” using HX Edit. When using this, you have the option to restore all your “Global Settings” to return them to how they were before. It’s very quick and very simple, but necessary as the new Firmware resets everything to how it was straight out of the box. See page 84.
https://line6.com/data/6/0a020a4167cd654eae06274c7/application/pdf/HX Edit Pilots Guide 3.70 - English .pdf
Furthermore, regarding your earlier post. There are no Line 6 staff here and only very occasionally do they visit these forums - (See the “sticky comment” in the black banner stripe at the top of this page entitled “Welcome to the Line 6 forums”).
This link is where you need to go to have any hope of your suggestion been seen by anyone from Line 6:
https://line6.ideascale.com/a/index
Before posting any new ideas, please do a search to see if it's already been listed. Multiple requests for the same thing will thin out the votes. Also, post your ideas one at a time. Many users don’t vote for combined suggestions.
Then you should use the “sticky thread” in this forum to let other users know what your suggestions are, with links to IdeaScale, so they can vote on it if they wish.
Hope this helps/makes sense.
  • 2 months later...
On 4/4/2024 at 12:20 AM, weswagner said:
Can we get a model of the hologram microcosm?
Here we go, once again,
Then you should use this “sticky thread” in this forum to let other users know what your suggestions are, with links to IdeaScale, so they can vote on it if they wish.
Regarding your request, well, that all depends on how many people vote for the idea, which at the moment stands at eleven votes.
https://line6.ideascale.com/c/search?query=microcosm
The concept of the Hologram Microcosm emulation would probably use up at least the best part of one of the DSPs already in a Helix unit. Plus the helix already has a lot of the stuff built in that is in the Microcosm, it simply requires a little thought and experimentation. You have a Looper, Glitch Delay, Euclidean Delay, Poly Capo and many reverbs to try out in various orders.
IIRC, John Nathan Cordy came up with a preset using those ideas, I think it was named "Icicles".
Do come back at let us all know when you have managed to make your own software version as a preset, or failing that, pick up a pre-owned Microcosm on Reverb and stick it in your FX Loop.
I don't know if it is something people would be interested (musicians I talk to would be for sure) but I have started the idea of a smaller footprint Helix. I am pretty sure when the Helix 2 come out, it will be the size of the Neural or something like that (other brands tend to this). If they released a full Helix the size of the HX Effects or the HX Stomp XL, I would buy it (or a little bit smaller than actual model without the expression pedal).
https://line6.ideascale.com/c/idea/106762
I think it's a great idea, personally.
… I have started the idea of a smaller footprint Helix….
To be fair, the idea of making electronic devices smaller began in the 1950’s or thereabouts when mainframe computers occupied entire basements of office buildings. I guess you mean you started an Idescale topic about it.
What exactly do you mean by a smaller footprint Helix that is different from, say, the HX Stomp XL?
I’d like to be able to wear a fully functional Helix on my wrist, or wear it on my belt like the size of the new POD Express. But there are certain physical size constraints. I haven’t done the exercise but it might be interesting to envision the minimum footprint required to physically accommodate all the Input, Output, FX Loops, Variax, USB, Optical….. hardware connectors, to say nothing of the 12 footswitches, that the Helix Floor or Rack/Control offer. Could they conceivably fit all that in a Stomp XL footprint? I don’t think so. Seems to me there’s not a lot of wasted real estate on the Helix Floor or Rack/Control. And once you start cutting out the hardware you’re no longer talking about Helix. You’re left with…. well, something like the HX family including the Stomp XL.
  • 1 month later...
Add new model amps:
VHT/Fryette Pitbull Ultra Lead
Brand: VHT Amplification
Model: Ultra Lead
Watt: 120
Rectifier: Solid State
Front panel: Hi and Lo Inputs, Gain, Volume and Tone Controls for Channels (channels 2 & 3 share Tone controls), Boost Switches, Graphic EQ, Master, Power and Standby Switches
Back panel: Power Amp Mode Switches, Impedance Selector, Speaker Outs, Line Out with Level Control, Footswitch Jack, EQ Switch (Optional EQ), Effects Loop (Jacks, Switches and Level Control), Presence, Depth
Class type: Dual Class Mode allows A, AB or Both
Number of Channels: 3 Channels With Internal Switching, Independent EQ on 1&2, Independent Boost Modes and Multifunction Footswitch
Master volume: Yes
Power Tubes: 6550
Number of Power tubes: 2 (MK50H) or 4 (MK100H)
Preamp Tubes: 12AX7 & 12AT7
Number of Preamp tubes: 5
Circuit Type: PCB
Effect loop: Parallel or Series With Effects Mix (Parallel) or Efects Level (Series)
Direct out: Variable Line Out
Half power switch: Half Power Mode
  • 3 months later...
They say "nothing happens if you don't speak up", so here goes:
1. I/O meters on all Helix / HX units. Able to toggle metering between block level, path level, and global hardware I/O.
2. Helix Rack reduced to a 2U size.
3. A Helix Floor in a HX Stomp form factor.
4. Higher resolution modeling / improved high frequency detail on all models.
  • 1 month later...
On 10/10/2024 at 11:08 PM, allthenotes said:
1) Software suggestion - Some appearance customization options on HX Edit e.g. - the ability to change display colors, switch between bars and knobs, and rotate bars 90º so they run vertically, enlarge text, etc. The signal chain graphics are very appealing graphically but the interface portion doesn't keep up imho.
2) Hardware suggestion - A desktop USB controller for HX edit for tactile control. Something like a Novation Launch control but with scribble strips showing the assigned function. This would make alternating between tweaking sounds and playing much smoother, again imho.
3) Hardware question/suggestion - not sure if it's even possible, but being able to load IRs for convolution reverb would be great. Obviously understand if this is simply a limitation of the hardware.
I just looked on IdeaScale and I don’t see your suggestions on there?
https://line6.ideascale.com/c/line6/home
  • 5 weeks later...
One thing i miss in HX stomp compred to Boss GTs is that there is no LFO to control parameters.
In Boss vocabulary it's called 'wave pedal' and it's an axtra LFO independently of the number of blocks used.
That would be a great help, especially with filter as none of the HX filters can do a simple filter whose frequency sweeps from low to high. Asheville is too resonant and too complex and Autofilter has not LFO.
Thanks
Thanks
See my previous post just above yours.
If you don’t make your feature request directly on IdeaScale, then there is absolutely no chance of it ever been seen by anyone from Line 6.
Only post here to let other users about your suggestion, then they can vote for it if they wish.
• I just added a submission to improve the already awesome Favorites:
more than 128, longer names, folders, effect/block model
https://line6.ideascale.com/c/line6/idea/115822
• also I'd like to share this submission (not mine) asking some modifiers to control parameters in helix:
imagine multiple LFO's, an Envelope follower, a Pitch follower, etc used as sources to control any parameter in any block
(easy examples: an LFO controlling the time of a delay; an envelope follower controlling the intensity of a tremolo;
advanced examples: an envelope follower controlling the depth and rate of a chorus; a pitch follower controlling the filter frequency of a synth; ...)
https://line6.ideascale.com/c/line6/idea/35852
there are other similar submissions in ideascale if you search "modifier" or "LFO" or "Envelope"
  • 1 month later...
  • 2 months later...
Something that should be fairly simple to implement, but extremely useful would be to add a kick feature.
I use my Helix LT live all the time as a troubadour, and I bring my SPD-ONE kick pedal with me. It costs almost 300 euros, weighs a lot, I use ONE kick sound from it and have to play the whole song through unless I loop it. And you know how hard the looper feature is to get perfect rhythm wise.
Therefore, a feature where a simple kick sample would play 4th notes set from the tap tempo would be amazing.
Good idea! Make sure to post it on Ideascale!
Which just got me thinking because it may take years until this request would eventually be implemented, if at all. And why wait so long, right?
So I just turned on my HX Stomp, and I turned it into a drum machine right away:
4 OSC Generator → Legacy Plate → Harmonic Tremolo → LA Studio Comp
Experiment with voicings and settings until you get the sound you like.
Key settings for Harmonic Tremolo: Wave Shape = Square, Duty Cycle = very low
Legacy Plate is optional, but it can soften the harsh synth sounds before the tremolo cuts them into (drum) pieces.
My goal was something that resembles jazzy kick & brush snare, and I got there after about half an hour of experimenting. For me it turned out much better than what I was expecting.
Put them all on Path B and route all input signal to path A, with whatever other blocks needed for your instrument (in my case mostly bass guitar or upright).
To turn the drum machine on and off, simply turn the 4OSC on and off.
Also interesting is to use the Asheville Pattrn envelope filter instead. It allows for a wide variety of "true" drum patterns. It has quite an "electro pop" flavor. Save various patterns and voicing levels as snapshots and you can switch between different drum grooves. Amazing!
Honestly, I'm all for more amp models. We've got a taste of the HD stuff, sure, and it's slick. But let's be real, the market's exploded with killer amps lately. Think Mesa Mark V, Randall Satan – amps with real personality. And what about those Strymon pedals? They're changing the game. Plus, other platforms are packing a serious punch with their amp selection. It'd be awesome to see that kind of variety here.
Nice idea! I will definitely try this out. With the right amount of tweaking it should be possible I guess :D
  • 1 month later...
On 4/10/2025 at 7:47 PM, davidwarokka said:
Please extend the 500ms cap on the Elephant Man Delay algorithm to at least 1100ms seeing EHX Deluxe Memory Man Tap Tempo can actually do it?
Adriatic Delay basically does this, doesn't it?
I wasn't able to vote on ideascale anymore, so I opened a ticket with line 6,
this is the answer I got today:
the Ideascale portal has been closed, please use this contact form :
https://line6.com/company/contact/productfeedback/
Best regards
Line 6 /Ampeg Support Europe
so I guess we should rename this thread shouldn't we...
Best regards
It’s not a secret that IdeaScale is finished - See the Blue Banner at the top of this page named “ideascale Retirement”.
Yeah. If only the link to https://line6.com/company/contact/productfeedback/ in the sentence "You can connect to our new Product Feedback Form HERE." weren't broken… :D
Because a link like "https://line6.com/support/forum/90-helix-native/- https:/line6.com/company/contact/productfeedback/" ends up in an endless loop to the page you're coming from.
  • Haha 1
Because a link like "https://line6.com/support/forum/90-helix-native/- https:/line6.com/company/contact/productfeedback/" ends up un an endless loop to the page you're coming from.
Well, that is perfectly normal for this place - nobody from Line 6 seems to care. They all hang out on the Helix Facebook thing, or TGP.
I don't do Fecesbook, hehe.
And while I'm watching the TGP Helix thread since quite some time, contributing occasionally (even been quoted by DI once!), it's rather boring reading overthere.
  • Haha 1
Well, let's try this, nonetheless:
Paging @Line6TonyPlease fix the broken "HERE" link in the "ideascale Retirement" popup!
  • Haha 1
to elaborate on this:
in my view, since the product feedback / submissions to line 6 are now obviously not visible to us, this thread becaomes MORE important because if every feedback each of us sends to them is posted also here, other people can agree or be inspired to submit more feedback on the same request
the thread could be renamed to something like "Helix product feedback submissions (ex-ideascale)"
what do you think?
On 4/15/2025 at 9:15 AM, davidwarokka said:
Adriatic is based on BOSS DM2 and Elephant Man is based on EHX Deluxe Memory Man isn't it? I think they sound quite different?
In the mix they don't sound that different at all.
