Helix Ideascale Community Submissions
TheRealZap
Figured I would put these all in one place to help people find and vote for the ones they like.
Dual Screen Mode:
http://line6.ideascale.com/a/dtd/Big-Screen-Dual-Mode/740269-23508
DT Amp compatibility:
http://line6.ideascale.com/a/dtd/DT-amp-compatibility-for-Helix/726817-23508
AutoWah:
http://line6.ideascale.com/a/dtd/Auto-wah-or-auto-EVERYTHING-for-Helix/727014-23508
True Bypass/Analog Through:
http://line6.ideascale.com/a/dtd/true-bypass-and-analog-dry-through-for-helix/727298-23508
Scene Mode:
http://line6.ideasca...de/727231-23508
Global Preset:
http://line6.ideasca...et/727233-23508
Phasers:
http://line6.ideasca...508
Reverse Delay:
http://line6.ideasca...508?submitted=1
Dimension Chorus
http://line6.ideascale.com/a/dtd/Dimension-Chorus-for-Helix/740549-23508
Helix control Variax
http://line6.ideascale.com/a/dtd/HD500-Helix-Control-of-Variax-Parameters/728102-23508
Add M13 Effects
http://line6.ideascale.com/a/dtd/Helix-import-M13-Effects/740566-23508
Envelope Filter:
http://line6.ideascale.com/a/dtd/Helix-effect-model-of-Solidgoldfx-Funkzilla-envelope-filter/728140-23508
AutoVolume:
http://line6.ideascale.com/a/dtd/Autovolume-for-Helix/741035-23508
High Gain Amps:
http://line6.ideascale.com/a/dtd/New-high-gain-amps-for-the-Helix-series/726782-23508
Boutique Amps:
http://line6.ideascale.com/a/dtd/Add-more-boutigue-amps/739544-23508
Vocoder:
http://line6.ideascale.com/a/dtd/Vocoder-effect/741578-23508
Multiple Looper Blocks:
http://line6.ideascale.com/a/dtd/Multiple-Looper-effect-blocks-for-Helix/741138-23508
Bass Additions:
http://line6.ideascale.com/a/dtd/More-bass-stuff-in-Helix/741738-23508
Global Signal/Spillover:
http://line6.ideascale.com/a/dtd/Optional-Global-signal-path-Spillover/741927-23508
Helix plugin saved settings:
http://line6.ideascale.com/a/dtd/HELIX-AAX-VST-Plugin-to-Remember-Settings/742318-23508
Tone Matching (Like AxeFX)
http://line6.ideascale.com/a/dtd/Tone-Matching-for-Helix/753630-23508
Amp Block EQ Settings Preset/Global
http://line6.ideascale.com/a/dtd/Amp-Block-EQ-settings-Preset-or-Global/754535-23508
Friedman Amp Pack
http://line6.ideascale.com/a/dtd/Friedman-Amp-Pack/754564-23508
Helix VST (Computer re-amping)
http://line6.ideascale.com/a/dtd/Plugin-version-included-with-Helix-for-Reamping/754897-23508
Line6 Original Amp models
http://line6.ideascale.com/a/dtd/New-Original-Amp-Models/772434-23508
Channel switching and other real amp parameters
http://line6.ideascale.com/a/dtd/Channel-option-switches/772435-23508
Mesa/Boogie MkIIc+
http://line6.ideascale.com/a/dtd/Mesa-Boogie-Mark-IIc+/772605-23508
Reverse Functionality of Bank/Preset Up/Down
http://line6.ideascale.com/a/dtd/Reverse-functionality-of-Bank-Preset-UP-DOWN/786505-23508?submitted=1
Compulsive Drive to run at 18v
http://line6.ideascale.com/a/dtd/Compulsive-Drive-setting-or-version-for-18v/786992-23508
SWR Redhead bass amp model
Helix editor with expanded A/B functionality
http://line6.ideasca...ty/787491-23508
multiple message sent when pressing a footswitch.
http://line6.ideasca...ch/787480-23508
Expanded Display for EQ and Compression Blocks
http://line6.ideasca...ks/787679-23508
Remember pedal position
http://line6.ideascale.com/a/dtd/Make-Helix-remember-pedal-position-when-switching-presets/787734-23508
Expression pedal scribble strip able to show the current CC data
http://line6.ideascale.com/a/dtd/Display-CC-value-of-Expression-Pedal/788250-23508
USB input Volume controls
http://line6.ideascale.com/a/dtd/USB-input-volume-control/788236-23508
Reduce speed on amp selection knob
http://line6.ideascale.com/a/dtd/Make-joystick-require-larger-turn-before-effect-changes/788248-23508
Presented in no particular order...
please post new ideas here and i'll try and update this post as a master list.
(If the ideascale submission is not posted in this thread it's not listed here)
  • Thanks 1
  • Upvote 9
  • Downvote 1
The link for the autowah is broken.
Seems that way, but you have to click on the second half of the link. Looks like the "!" causes some weird break in the link if you click in the first half.
I'd like to see the Boss T-Wah. Great little unit.
If there's any other suggestion you may have (not related to specific models, because it's not the point of the idea)
feel free to tell me, specially if it's a different, clearer way to express the concept. My English is what it is   :P
I think the title of "Auto Wah or Auto Everything" is pretty good. I'm mean why not, it's everything, right? Maybe slightly generic sounding. A lot of people might not see what a powerful idea this actually is, or could be, though. Getting people to vote for it is key. Having trouble thinking of something better for the title.
updated link
I've just edited the title in the auto-wah idea, so it won't cause any more problems.
Here's the new link
Sorry for the inconvenience. Exclamation signs never again (on ideascale at least) ;-)
I've got one -- how about a simulation of the input Z adjustment of the guitar input for the Variax VDI input.
I use my JTV's always hooked up via the VDI input, but when I mess with my regular guitars via the guitar input, I find the adjustable Z - impedance quite handy for taming a guitar that is way too trebly by reducing the input impedance -- it also knocks down the hum. It would be very helpful with the JTV mags specifically to warm up the sound. On my 69S, I usually roll my tone control way past half to get out of the tinny brittle area of the mags, and the 59 mags are sometimes too brittle sounding as well. I have to set my models to save their tone control positions, as the necessary tone control adjustments for the mags is always different than the needed tone control settings for the models....
Just a thought.
Why are the two suggestion pertaining to addional amps not listed here. Adding high gain amps has been the number one vote getter.
As Zap said in his original post, "please post new ideas here and i'll try and update this post as a master list."
If you don't see it, it is new to his list. He is doing this as a courtesy and as a convenience for members.
Post the links and I'm sure Zap will add it to the list.
If we're talking Boss, VB2 vibrato, discontinued, crazy prices. Dedicate the expression pedal or a switch to the "unlatch" mode. Really wonderful sounding pedal.
added.
One for an auto volume:
This is in case the other entry for making other effects have an auto ability via an LFO doesn't get implemented for technical reasons. I can't imagine the Helix without an auto volume.
exactly what Cipher said DT has 59 votes...
and you cant vote multiple times... like you can on 2 different amp packages....
they are different requests and play to different audiences anyway....
i think it's silly that there's already demand for "more" amp models....
when the helix comes with more than the HD to begin with.... and most everyone has not heard the ones that are already there....
i think that there will be a time and place for more amp models... but pre-release... not so much....
i think that you're just selling yourself on some "inspired by" brand name... cart before the horse or whatnot...
but vote on what you want... that's the idea.
How so?
I see 40 votes on the additional amps and 30 votes on DT integration, not to mention that there are TWO "additional amp requests" (the other with 34 votes on it).
Ah, OK. That's a different submission than the one I saw. But how come it doesn't show up under "Most Popular"? I admit I'm new to the Idea Scale, so please forgive me if I'm missing the obvious :-).
As for more amp submissions, I don't think they are silly at all. We've already heard the HD amp models, so we know what's there. Yes, they are probably better quality versions given the new HX modeling. However, there are so many NEW great amps that have their own character, like the Mesa Boogie Mark V or the Randal Satan, as well as effects pedals like those from Strymon. Not to mention the amp variety offered by the competition ;-).
