BigMacBaker Posted October 22, 2015 Share Posted October 22, 2015 Has anyone managed a workaround for this? I have just bought a Variax 700 in amber, it's in mint condition and is such a gorgeous guitar that I want to keep it but need to use it to its fullest capabilities, I can't justify spending more on an interface if the software just won't install. . Message reads: Variax Workbench can't be installed on this disk. This software requires Mac OS X 10.5 or above. Quote Link to comment Share on other sites More sharing options...
johoffry Posted October 23, 2015 Share Posted October 23, 2015 guessing you are trying to install the wrong software. Try installing Line6 Monkey and that should allow you to install workbench HD Quote Link to comment Share on other sites More sharing options...
MartinHines Posted October 26, 2015 Share Posted October 26, 2015 How are you trying to install Variax Workbench? through Line 6 Monkey? Over in the HD500 forum there were a bunch of people who were having trouble using a USB connection between their HD500Xs and Macs with El Capitan. At least one person was able to fix this by downloading Mac El Capitan 10.11.1 (point change upgrade). http://line6.com/support/forum/18-pod-hd/ I would suggest first trying to install Line 6 Monkey, then the USB drivers, then try to install Variax Workbench 1.75. Quote Link to comment Share on other sites More sharing options...
jakers1975 Posted November 11, 2015 Share Posted November 11, 2015 I am running El Capitan and just bought a Variax Standard. Was anxious to get workbench going to mess around with custom guitars and I cant even get monkey to install. It just hangs. Quote Link to comment Share on other sites More sharing options...
Badmadlad Posted November 11, 2015 Share Posted November 11, 2015 Im seeing the same , I haven't used my Workbench interface for years but when i try to update the usb drivers it says it "could not establish a connection - please check your cables- I have both green lights on the interface - It looks like its just not compatible? Quote Link to comment Share on other sites More sharing options...
eenymason Posted November 11, 2015 Share Posted November 11, 2015 Has anyone managed a workaround for this? I have just bought a Variax 700 in amber, it's in mint condition and is such a gorgeous guitar that I want to keep it but need to use it to its fullest capabilities, I can't justify spending more on an interface if the software just won't install. . Message reads: Variax Workbench can't be installed on this disk. This software requires Mac OS X 10.5 or above. This may be the explanation - http://line6.com/support/forum-18/announcement-73-mac-os-1011-el-capitan-problem-with-line-6-usb-audio-driver/ Quote Link to comment Share on other sites More sharing options...
leesteel Posted November 12, 2015 Share Posted November 12, 2015 I'm not making the switch to "the captain" until there is some positive solution. Cubase is still incompatible also. Quote Link to comment Share on other sites More sharing options...
jdlaboun Posted November 22, 2015 Share Posted November 22, 2015 I have the same problems with not being able to load workbench and my variax 500 won't work with Workbench HD Quote Link to comment Share on other sites More sharing options...
jemsession Posted December 12, 2015 Share Posted December 12, 2015 I copied Workbench 1.54 from my old OS X to my new MacBook. To run it needs the old Java SE 6 runtime – so I presume that this is probably also needed to install Workbench. Unfortunately my old Variax 600 doesn't work with Workbench HD. Quote Link to comment Share on other sites More sharing options...
tropikblues Posted December 21, 2015 Share Posted December 21, 2015 I tried to install WorkbenchHD on two systems running El Crapitan today. One - my laptop worked fine, the other (on my iMac) loaded, but wouldn't "find" the guitar via USB. I did both from the monkey (as the downloadable version posted at Line6 support does not seem compatible with the new OS). I have come to expect this sort of hit and miss program operation from Apple nowadays with there last two operating systems. As my laptop has very little on it other than Apple programs, and my iMac has plenty of other non-Apple programs, I am suspecting a conflict from an outside vendor program and I am trying to figure out what processes might be blocking the USB connection recognition. I will repost if I figure it out. Quote Link to comment Share on other sites More sharing options...
grundyhome Posted December 31, 2015 Share Posted December 31, 2015 I contacted Line6 support and was told that Workbench does not run on El Capitan. I couldn't get an answer if/when it will be compatible. Quote Link to comment Share on other sites More sharing options...
wheelnut Posted January 2, 2016 Share Posted January 2, 2016 I can understand the older Workbench 1.75 might not support El Capitan (and if you own an older Variax, you probably need the older non-HD workbench) However, I can say that Workbench HD 2.12.0 works perfectly fine with my Variax Standard on a MacBook Air running El Capitan 10.11.2. Quote Link to comment Share on other sites More sharing options...
grundyhome Posted January 2, 2016 Share Posted January 2, 2016 I can understand the older Workbench 1.75 might not support El Capitan (and if you own an older Variax, you probably need the older non-HD workbench) However, I can say that Workbench HD 2.12.0 works perfectly fine with my Variax Standard on a MacBook Air running El Capitan 10.11.2. Quote Link to comment Share on other sites More sharing options...
grundyhome Posted January 2, 2016 Share Posted January 2, 2016 Thanks. I'll dig a little deeper. I'm a newbie to the Variax. Hopefully I've been loading the incorrect version. I'm running on a Mac desktop but it should be the same. Thanks again! Quote Link to comment Share on other sites More sharing options...
jakers1975 Posted January 2, 2016 Share Posted January 2, 2016 I tried to install WorkbenchHD on two systems running El Crapitan today. One - my laptop worked fine, the other (on my iMac) loaded, but wouldn't "find" the guitar via USB. I did both from the monkey (as the downloadable version posted at Line6 support does not seem compatible with the new OS). I have come to expect this sort of hit and miss program operation from Apple nowadays with there last two operating systems. As my laptop has very little on it other than Apple programs, and my iMac has plenty of other non-Apple programs, I am suspecting a conflict from an outside vendor program and I am trying to figure out what processes might be blocking the USB connection recognition. I will repost if I figure it out. Sorry the incompatibility has nothing to do with Apple. It's Line 6 that dropped the ball on this one. Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted January 2, 2016 Share Posted January 2, 2016 the original workbench will never be updated.... the answer lies in getting the correct version of java on your mac, and making the current version work... others have done it. so a forum search may be helpful. i've had no issues with workbench HD. Quote Link to comment Share on other sites More sharing options...
riktor Posted January 4, 2016 Share Posted January 4, 2016 Use an app called Pacifist. This will act as the installer in lieu of the Workbench installer that cannot verify the OS X version number. I did this today and it corrected the issue. Pacifist is free, you just have to wait twenty seconds to use it. Quote Link to comment Share on other sites More sharing options...
pol2711 Posted January 17, 2016 Share Posted January 17, 2016 thank you riktor! Used Pacifist and downloaded Java and all is working fine over here with the latest OS X Quote Link to comment Share on other sites More sharing options...
grundyhome Posted January 19, 2016 Share Posted January 19, 2016 Thanks. I'll dig a little deeper. I'm a newbie to the Variax. Hopefully I've been loading the incorrect version. I'm running on a Mac desktop but it should be the same. Thanks again! Hey all - I did as suggested and attempted to load HD 2.12 and everything went fine. Worked like a charm. I didn't use Pacifist or anything like that. Just a native installation. I think it was the non-HD version that was causing the problem. It's all good now! Quote Link to comment Share on other sites More sharing options...
elcattivo Posted February 3, 2016 Share Posted February 3, 2016 i just copied the app from my old harddrive into my line6 folder and it works. i think you can also copy it from a timemachine-backup Quote Link to comment Share on other sites More sharing options...
rickm_1122 Posted March 14, 2016 Share Posted March 14, 2016 Ok, So I have tried updating (downgrading?) the Java runtime to Version 6, used pacifist to install to get past the version check, but I get an unsatisfied link error: java.lang.UnsatisfiedLinkError: cmn.l6java.utils.L6EmbeddedUtils.nativeHideSplash()V App info: Variax Workbench 1.54 release - build 93 - Mon Mar 31 14:17:16 PDT 2008 Date: 3/14/16 1:03 PM In thread: Thread[main,5,main] OS: Mac OS X (10.11 i386) Java VM Version: 1.6.0_65 Anyone have any thought on what I can do to get around this? I'm attempting to use this with a PODX3 Live and a Variax 600 6-string and a Variax 700 bass on OS X El Capitan, iMac 27, 8Gb RAM. 1 Quote Link to comment Share on other sites More sharing options...
x1fush7lz Posted May 12, 2017 Share Posted May 12, 2017 I own a old Variax 300(sunburst) i Found a way to install Workbench(not HD) on Mac sierra Download the "Variax Workbench 1.73" installer First Try to install the Regular Way(double Click .dmg and follow the instructions) when it says it needs a former version of Java down-grade to it Double Click the .dmg file then Right click the installer(orange .mpkg file ) selecting "show Package Content" Select the "packages" folder then Double-Click Variax Workbench .pkg U don't need To install "Variax USB interface" install then Launch Variax Workbench and that should be it after i had an un-related problem with Logic thinking it had something to do with Java so i re-installed the latest version of Java Workbench still works 1 Quote Link to comment Share on other sites More sharing options...
mdfischer Posted December 25, 2017 Share Posted December 25, 2017 @Just Startin' This worked great! Considerably improved my mood. Thanks a lot! Couple of notes for others: "Download the "Variax Workbench 1.73" installer" ... v 1.75 reports being damaged. "when it says it needs a former version of Java down-grade to it" ... its not really a downgrade, as the OS just uses it when something asks for this version of Java. You will be directed to download it when you first try to run Variax Workbench. Just follow the trail, and then restart Workbench. 1 Quote Link to comment Share on other sites More sharing options...
psarkissian Posted December 27, 2017 Share Posted December 27, 2017 Workbench HD is not compatible and won't work with older Variax like a 700. Only original Workbench works with the older Variax guitars. Quote Link to comment Share on other sites More sharing options...
soundog Posted May 19, 2018 Share Posted May 19, 2018 Hope Line 6 doesn't leave us Variax Acoustic owners out in the woods with no Workbench one of these days... Quote Link to comment Share on other sites More sharing options...
psarkissian Posted May 21, 2018 Share Posted May 21, 2018 Not likely, too many of us old Variax players still out there,... including me. 1 Quote Link to comment Share on other sites More sharing options...
Snackbar Posted November 12, 2018 Share Posted November 12, 2018 Hi guys, I know it's been a long time, but I'm about to try to get Workbench working for my old Variax 700 in the next few weeks or so. Maybe some of you have found workarounds, if so I'd love to see them, but you may be still suffering. If so, this link is for a Cubase workaround that has exactly the same message 'Wrong Mac OSX Version': - https://www.hjorthjort.xyz/old-site/2015/12/22/cant-install-cubase.html The instructions are detailed, and so long as you don't try to install Workbench on an OS older than 10.5 (why would you?) there will be no harm to your system at all. By simply removing some script from the installer, the software will install and function normally. If the installer works in a different way, with smaller packets inside the main packet, then I will be trying this one out: - https://www.youtube.com/watch?v=_oyN3ryUuzY Again, you're taken step by step through the process. Who know if they'll work for me, it would be great to get my Liquid Mix working as well as Workbench. You may want to wait until I've gone over the barbed wire first, so I'll post again in a fortnight or so and let you know how I got on :0) Quote Link to comment Share on other sites More sharing options...
soundog Posted November 16, 2018 Share Posted November 16, 2018 Line 6 customers shouldn't have to resort to keeping an old computer or performing Java workarounds just to use their trusty old Variax guitars with Workbench. There are a few things we can do to pressure Line 6 to update Workbench so it works with recent computers and operating systems: 1) open a support ticket here https://line6.com/support/tickets/add.html and the more the merrier. Squeaky wheel gets the grease. 2) be vocal on these and other forums 3) vote for support in Line 6 Ideascale right here. You'll need to register for Ideascale if you haven't already. (In my opinion, the lack of legacy Variax support shouldn't require an "idea" for submission. But sometimes you gotta approach a problem from all angles.) Makes sense Quote Link to comment Share on other sites More sharing options...
Snackbar Posted November 18, 2018 Share Posted November 18, 2018 I'm afraid I got stuck on the barbed wire and shot to pieces! Nothing worked, so you post is truly appreciated :0) I think I've already got the older version of Java to run Line 6 Edit, so hopefully I'll be OK installing the non HD version of the Variax Workbench. Many thanks for putting me on the right path, and your absolutely right about Line 6 and many other companies lack of support for older gear. I've got a PodXT completely loaded with the expansion pack and it gives me everything I want, as does the Variax 700. Do I want a Pod HD or a James Tyler Variax... No!! Quote Link to comment Share on other sites More sharing options...
