TheoHolsheimer 0 Posted January 18, 2019 What Expression Pedal works with Line6 HX Effects? I like to work with effects from 0% till 100% without any isues The Line6 EX-1 ? The Roland EV-5 Expression Pedal doesn’t do the job apparently, goes to 60%, no matter what I do. Never had problems with the classic Line6 Delay Pedal with the same Roland EV-5 Pedal is there a bug in the Line6 HX Effects about the expressionpedal topic? Seems there are more people to suffer with this topic. Quote Share this post Link to post Share on other sites
Kilrahi 487 Posted January 18, 2019 This is the one I recommend. It's sturdy, built like a tank, and has a dual switch. I love the thing. Well, as much as you can love a pedal. It's kind of a head scratcher that other pedals suffer. Line 6 doesn't indicate any special pedal is needed at all which is frustrating. https://www.musiciansfriend.com/amplifiers-effects/mission-engineering-helix-rack-expression-pedal-black 1 Quote Share this post Link to post Share on other sites
ledvedder5150 1 Posted January 19, 2019 You'd be better off getting this one, https://www.sweetwater.com/store/detail/EP-1--mission-engineering-inc-ep-1-expression-pedal-black. The HX Effects can't use the footswitch on the SP-1. Quote Share this post Link to post Share on other sites
Kilrahi 487 Posted January 19, 2019 32 minutes ago, ledvedder5150 said: You'd be better off getting this one, https://www.sweetwater.com/store/detail/EP-1--mission-engineering-inc-ep-1-expression-pedal-black. The HX Effects can't use the footswitch on the SP-1. Seriously? I just figured they had uniformity in official Helix products. That seems nuts . . . Quote Share this post Link to post Share on other sites
ledvedder5150 1 Posted January 19, 2019 Nope. HX Effects doesn't support the switch.... Yet. I've heard that it will be in the future. Quote Share this post Link to post Share on other sites
mzammert 0 Posted February 17, 2020 On 1/19/2019 at 4:24 PM, ledvedder5150 said: You'd be better off getting this one, https://www.sweetwater.com/store/detail/EP-1--mission-engineering-inc-ep-1-expression-pedal-black. The HX Effects can't use the footswitch on the SP-1. Does the Mission Sp-1 meanwhile works with HX Effects 2.82? Quote Share this post Link to post Share on other sites
tooloudtoobad 7 Posted February 17, 2020 Helix uses TS cable Not TRS cable............ at 10K ohms........ Quote Share this post Link to post Share on other sites
mzammert 0 Posted February 18, 2020 Sorry again. Does the Mission Engineering SP1-L6H (link) work with the Line 6 HX Effects with firmware 2.82? thx Quote Share this post Link to post Share on other sites
fabriziodalisera 6 Posted February 18, 2020 Hi, I have read somewhere that with the latest 2.82 firmware we can now use every pedal (volume or expression) connecting a standard mono TS cable. Is it true? I also have watched some videos where someone used nektar and m audio expression pedals with success, but they have TRS connectors! I am a bit confused. Please help! P.S. I know that the mission engineering works, but I would prefer buying a mid priced (made of metal, not plastic) pedal, not a super expensive one! Quote Share this post Link to post Share on other sites
C4TH 2 Posted February 18, 2020 I use the Dunlop mini (VP4?). Works perfectly. Quote Share this post Link to post Share on other sites
timeasterday 0 Posted February 18, 2020 38 minutes ago, C4TH said: I use the Dunlop mini (VP4?). Works perfectly. Do you use a TS or TRS cable? I have that pedal coming soon. Quote Share this post Link to post Share on other sites
C4TH 2 Posted February 18, 2020 8 hours ago, timeasterday said: Do you use a TS or TRS cable? I have that pedal coming soon. TS cable. Works great. I'm sure you'll be happy with it. I used a Line 6 ex1 before, which was ok, but was fairly weak and brittle. The sweep always seemed a bit odd also. But the dunlop's just right. Quote Share this post Link to post Share on other sites
HonestOpinion 937 Posted February 18, 2020 On 1/18/2019 at 11:42 AM, Kilrahi said: This is the one I recommend. It's sturdy, built like a tank, and has a dual switch. I love the thing. Well, as much as you can love a pedal. It's kind of a head scratcher that other pedals suffer. Line 6 doesn't indicate any special pedal is needed at all which is frustrating. https://www.musiciansfriend.com/amplifiers-effects/mission-engineering-helix-rack-expression-pedal-black On 1/19/2019 at 10:24 AM, ledvedder5150 said: You'd be better off getting this one, https://www.sweetwater.com/store/detail/EP-1--mission-engineering-inc-ep-1-expression-pedal-black. The HX Effects can't use the footswitch on the SP-1. On 1/19/2019 at 3:44 PM, ledvedder5150 said: Nope. HX Effects doesn't support the switch.... Yet. I've heard that it will be in the future. @ledvedder5150 What was your source was for hearing that it will support the switch in the future. If it was Line6 and you are going to get a Mission pedal wouldn't it be better to futureproof yourself and get the one kilrahi suggested with the switch in the event that either the HX Effects supports it in the future or if you decide to get a Helix? Quote Share this post Link to post Share on other sites
caledoneus 32 Posted February 19, 2020 M-Audio makes one that is like 30 bucks and works just fine with it if you are looking for an affordable option. Quote Share this post Link to post Share on other sites
Mincer 19 Posted April 9, 2020 So no news if the switch on the more expensive Mission pedal’s switch can be used? So far, the web page description doesn’t mention the HX Effects. Don’t want to pay for features I can’t use. I have used both the Dunlop expression pedal and the 25k Ernie Ball Jr. Both do something weird with the taper...the action is in just a small area of the sweep. I am on my 3rd Line 6 EX1, which gets expensive to replace a plastic pedal. Is the other Mission pedal (without the switch) the only sure thing? Why aren’t these things universal? Quote Share this post Link to post Share on other sites
Robh55 0 Posted August 20, 2020 This has to be one of the biggest ordeals with HX Effects and Line6 in general. I have an EP1-L6H on the way and bound & determined to utilize the foot switch to engage whatever I assign it to (wah most likely). Can anyone out there confirm it’s possible? Thanks in advance!! Quote Share this post Link to post Share on other sites
chacharlafuzz 0 Posted November 13, 2020 Good morning all, I use the Morley Volume Plus pro series volume pedal (PVO +), all you have to do is connect the TS cable between the Out and the exp input of your HX, as well as activate the "mini volume" switch and turn on the sound full knob (4h). You must also reverse the polarity in the "control setting" panel. Remember to make the HX connections off and on afterwards. I think the manipulation is possible with other volume pedals. Quote Share this post Link to post Share on other sites
Alumaman 0 Posted November 18, 2020 I have plugged in my old Ernie Ball and newer Ernie Ball VP jr with JHS mod (requires 9v). They both worked fine with no tweaking required. 1/4" out from the pedal to #2 expression jack. (they would not work in #1 exp jack) Quote Share this post Link to post Share on other sites
DoctorBobski 1 Posted January 26 Posted elsewhere but I've managed to get the Boss FV-30H to work with my HX effects. TS to TS cable in output but you need a dummy jack in the input. I use a headphone adapter. Quote Share this post Link to post Share on other sites
DBCrocky 15 Posted January 29 So FYI, I just found out today you can order the Mission Ep-1-L6 from the Mission Engineering site with a Spring Load option. This means when you take your foot off, a spring will return the pedal to heel position. Then in Bypass assign for your wah/effect, you can turn the wah off when the pedal is in heel position, on otherwise. Now you've got the Morley Bad Horsey type wah where you turn it on just by pushing the pedal, and when you take your foot off the spring will put the pedal into heel position, turning it off. No having to use a toe switch! This is for Helix, not sure if the feature is available in HX Effects... Quote Share this post Link to post Share on other sites
eswart 2 Posted February 9 Cheap and light Nektar NX-P works with HX-Effects. It has a built-in TRS-cable. Quote Share this post Link to post Share on other sites
