VinceSoliveri Posted June 30, 2013 Share Posted June 30, 2013 For the longest time I have had huge problems with my Pod HD 500. I am constantly hearing excess and un-needed noise whenever I am playing on a clean patch (and I can only assume it is happening on distorted patches although you can't hear it). No matter what amp model I'm using, the noise is persistent. I always thought maybe the pickups on my guitar are too hot, but as a raise or lower the pickups, the problem still occurs, even if I enable the PAD switch. I do not believe the pod is clipping for I have the volume knob at about 60% and the mixer volumes (VOLUME A & VOLUME B) set at -5 db. I have all the latest updates and I honestly do not know what to do. I have recorded an example the sounds I am hearing so it can give a clearer indication of what I mean. I will post the link. I recorded a direct signal with a clean patch from the Pod to my interface.Then I recorded the same riff, but with everything on the signal chain disabled. Lastly I recorded my guitar directly into my interface. When it is the completely dry signal from my guitar, i do not hear any additional noise so I can only assume its my Pod. Please help. I am getting awfully fed up with this issue. Thanks Here is the recording: http://puu.sh/3rr3I Clean problems.mp3 Quote Link to comment Share on other sites More sharing options...
silverhead Posted June 30, 2013 Share Posted June 30, 2013 Check your Inputs. Try assigninf Input 1 = Guitar and Input 2 = (any unused input; something other than Same). 1 Quote Link to comment Share on other sites More sharing options...
toneman2121 Posted June 30, 2013 Share Posted June 30, 2013 i notice if i have input 2 set to mic, i get noise Quote Link to comment Share on other sites More sharing options...
fmarinheiro Posted July 3, 2013 Share Posted July 3, 2013 Share the patch you've used it may be easier to help. Quote Link to comment Share on other sites More sharing options...
stumblinman Posted July 3, 2013 Share Posted July 3, 2013 I had this same issue a couple years ago after a flash memory update. You may try reflashing and see if it goes away. It worked for me. Good luck! Quote Link to comment Share on other sites More sharing options...
StephenSLR Posted July 4, 2013 Share Posted July 4, 2013 http://www.foobazaar.com/podhd/toneGuide/troubleshooting#noise s Quote Link to comment Share on other sites More sharing options...
moondancer Posted July 4, 2013 Share Posted July 4, 2013 May be it depends on my pc speakers, but I can't hear any disturbing noise. some fx add a very little distortion to the sound, some add a little noise. If you use the standard setup for input: All inputs at 1 and 2 you can get some clipping. Best is use input1 as "guitar" and input2 as "Variax" (only input1 goes to the tuner, and the "Variax" is digital, hence less noise). Quote Link to comment Share on other sites More sharing options...
Rewolf48 Posted July 5, 2013 Share Posted July 5, 2013 If you Mic as an active input but unused you should look at the trim knob as this can introduce hiss if turned up. Basically the approach is that unlike the demo presets where everything is active, your presets that you actually use should only have the minimum inputs active to reduce noise 1 Quote Link to comment Share on other sites More sharing options...
napynap Posted July 8, 2013 Share Posted July 8, 2013 VinceSoliveri, As confirmation, I listened to your 'clean problems' file on good speakers. The hiss is most definately there, and seems to get worse with each note that you add. Hopefully a solution will show up in these replies! Quote Link to comment Share on other sites More sharing options...
