victorcastro1 Posted March 26, 2016 Share Posted March 26, 2016 I got used to not using the VDI cable, but I like the idea of not having to worry about running out of juice in the middle of a gig. I've tried setting everything on "don't force" and the settings are set to "global", but when I change patches Helix will turn off the Variax and get to the magnetic pickups. If I'm doing something wrong I can't see it. Anyone? Quote Link to comment Share on other sites More sharing options...
spikey Posted March 26, 2016 Share Posted March 26, 2016 Don't have my Helix yet, but I believe there is a setting for using mag pups. Look for it under the Variax settings. Quote Link to comment Share on other sites More sharing options...
keithbax Posted March 26, 2016 Share Posted March 26, 2016 Double check that the input is not set to Variax magnetic pickups Quote Link to comment Share on other sites More sharing options...
victorcastro1 Posted March 26, 2016 Author Share Posted March 26, 2016 If it was set to the magnetic the variax models just would not work. Can anyone check it? I read the manual, everything looks right, the manual states "Selects the Variax model and pickup position setting. When set to "Don't Force," Helix respects the Variax's current setting", but it doesn't seem to be working properly. If I set the Variax to the Tele model for example, if I change the preset, Helix will turn it off, even if I set the correct setting to "don't force". Is it a bug or something? Can anyone check on their own stuff? Quote Link to comment Share on other sites More sharing options...
silverhead Posted March 26, 2016 Share Posted March 26, 2016 In Helix the Varaiax Magnetics are a separate selection for the Input block. You do not select the mags using the Variax settings; you select them as an input. Quote Link to comment Share on other sites More sharing options...
victorcastro1 Posted March 27, 2016 Author Share Posted March 27, 2016 I know, what I meant was that, if I had it set to the Variax magnetics on the input, I would not be able to access the Variax models, so I'm sure the input is set correct. So, the input is set at Variax, not the Variax magnetics. On the settings tab, the setting that the manual states it will make Helix respect the current state of the Variax is set the correct way, it's set to "Don't Force" - and the settings are set to global. What happens is that, if I have the Variax modeling on, when I change to another preset on Helix, it will turn the Variax modeling off and go to the magnetics, but I can still turn on the modeling. Quote Link to comment Share on other sites More sharing options...
Gawwuf Posted March 28, 2016 Share Posted March 28, 2016 In the input module under variax model select Don't Force. Make sure all your patches have this as many customtone or Glenn's patches have models saved in them. Quote Link to comment Share on other sites More sharing options...
victorcastro1 Posted March 28, 2016 Author Share Posted March 28, 2016 Every settings it's possible to set to "don't force" is set to "don't force". Settings are set to global, so it's no a patch to patch issue. It will still turn off the Variax modeling. Quote Link to comment Share on other sites More sharing options...
Gawwuf Posted March 28, 2016 Share Posted March 28, 2016 Is your input set to Multi? I would put it there and leave it, try the "per patch" instead of Global, and leave the "Don't Force" in place, sorry I'm not home to test it right now. Quote Link to comment Share on other sites More sharing options...
silverhead Posted March 29, 2016 Share Posted March 29, 2016 I suggest you upgrade to the latest beta editor and firmware. They are now publicly available in the Downloads area of this website. Check the 'beta' box to make them appear in the list. Let us know if the problem persists. Quote Link to comment Share on other sites More sharing options...
victorcastro1 Posted April 8, 2016 Author Share Posted April 8, 2016 It took me a while to get back, sorry, but yeah it does. Quote Link to comment Share on other sites More sharing options...
tuplalfred Posted September 15, 2016 Share Posted September 15, 2016 I have the last Firmware update 2.01 and tried using either global or per preset and is not working, always go back to the last Variax model I was using when I saved the preset the last time, is really annoying Quote Link to comment Share on other sites More sharing options...
davidb7170 Posted September 15, 2016 Share Posted September 15, 2016 Try pushing the model knob so the models are off and then save the preset. When you recall that preset, the Variax will be recalled with the pickups on. I use my JTV's with the pickups on (models off) in nearly all my Helix presets. It recalls the state of the guitar at the last save of the preset. Also set the Helix to "per preset". Quote Link to comment Share on other sites More sharing options...
d0stenning Posted September 15, 2016 Share Posted September 15, 2016 when I change patches Helix will turn off the Variax and get to the magnetic pickups. I've noticed that too - pretty sure its a firmware bug. Quote Link to comment Share on other sites More sharing options...
knoxdaz10 Posted September 15, 2016 Share Posted September 15, 2016 I SET MY PATCHES TO DONT FORCE, BUT IT STILL FORCES THE VARIAX Quote Link to comment Share on other sites More sharing options...
talwilkins Posted September 15, 2016 Share Posted September 15, 2016 I suggest you upgrade to the latest beta editor and firmware. They are now publicly available in the Downloads area of this website. Check the 'beta' box to make them appear in the list. Let us know if the problem persists. What versions do you see at the beta area? Quote Link to comment Share on other sites More sharing options...
davidb7170 Posted September 15, 2016 Share Posted September 15, 2016 Unless something else is going on, this is not a bug, but expected behavior. If you save the patch with the JTV model ON, it will recall the model ON when you choose that patch the next time. If you save it with the models OFF (the pickups ON), it will recall the patch with the models OFF / PU's ON. I use this all the time. The Helix does this, the POD HD500(X) does this, and I recall correctly, my X3Live did this. I use the PU's a lot with a handful of models for acoustic patches and key-shifted patches. When I choose those, the models are on, when I choose another that I've saved with the PU's on, the PU's come on. To me it's a valuable feature, you're not stuck with ALL models or ALL PU's on your patches. Just gotta keep your head on when you're saving the patches is all... Dave Quote Link to comment Share on other sites More sharing options...
deadlocked Posted September 15, 2016 Share Posted September 15, 2016 I had similar issues until I realized that setting the mode to "Don't Force" does not mean that the Variax on/off setting changes. I found that if I set the Variax to On or Off as desired via push on the model knob and *then* saving the patch did work. So now, on patches where I want to use the mags, I push the model knob and make sure the light is off and then save the patch; if I want the Variax to use modelling, then I push down the model knob until it is lit and then save the patch like that. You will need to have the Variax mode set to "Per Patch" for this to work. I'm not home to check, but I think it was on the Input block settings, as opposed to the Global Settings, which seemed "odd" to me, as this is a global setting. Once you have it set up as I mentioned here, you can turn Variax modelling on and off as desired per patch. Quote Link to comment Share on other sites More sharing options...
silverhead Posted September 15, 2016 Share Posted September 15, 2016 What versions do you see at the beta area? I don't think there are any in the Beta area anymore. Since I posted in March the firmware is out of beta and has been promoted to the general area. Quote Link to comment Share on other sites More sharing options...
Rocco_Crocco Posted September 17, 2016 Share Posted September 17, 2016 I SET MY PATCHES TO DONT FORCE, BUT IT STILL FORCES THE VARIAX Yup me too... this happened to me on some of the Fremen Presets. I just turned the modeling off on my Variax and hit save twice on my Helix. I did it for each patch so now I don't have the issue. Quote Link to comment Share on other sites More sharing options...
soundog Posted September 17, 2016 Share Posted September 17, 2016 Same here. Thank @Rocco for the fix idea .... I'll give it a try. Quote Link to comment Share on other sites More sharing options...
isdirg1 Posted September 18, 2016 Share Posted September 18, 2016 Variax 300-700 do not work the same as JTV Variax's that's a real issue with HELIX that and not linking the Work bench is a real pain. I am sure Line 6 are working to fix this. If however they have no plans to fix then they should be open and advise future buyers that HELIX is not the same as the Pod hd series in the way it recognise ALL Variax models. Quote Link to comment Share on other sites More sharing options...
victorcastro1 Posted September 22, 2016 Author Share Posted September 22, 2016 It is a bug, I've already created a ticket and support said they would fix it. Quote Link to comment Share on other sites More sharing options...
knoxdaz10 Posted September 23, 2016 Share Posted September 23, 2016 choose your preset. then look at your variax. if it turned the light on, and u dont want it on. turn it off. then save your patch. then when u load that patch next time it wont do anything. u need dont foirce aswell Quote Link to comment Share on other sites More sharing options...
