rvroberts 79
Are you saying you installed the 2.01 firmware and the 2.01 editor and they won't talk to each other? Or did you just do one? And did you reset the Helix and reinstall you patches/IRs? I find all that messy, but so far its worked fine,,,,,ish...............
nippyjun 22
Did you update the editor. Did you do the 9/10 reboot?
Geekydaddy 13
I was able to install the FW to the Helix with no problem. Powered unit down for a while. Tried to reconnect to my PC and the Updater AND editor dont see the Helix now. tried uninstalling/reinstalling Updater and Editor several times to no avail. Yes I did the 9/10 reboot. Also tried the 10/11.
TexLefty65 17
Well, if the firmware update was successful (Helix powers up and all sounds correct) then I would first suspect a driver issue. With Helix not USB connected, try uninstalling the Line 6 Helix Driver, then download it and install again - or if you run the Line 6 Updater installer again, it also includes the Helix driver installation. Then try connecting Helix to USB again. Possibly also try a different USB 2 or 3 port on your PC too.
Geekydaddy 13
Tried all 6 ports. I've uninstalled/reinstalled 6 times. The updater does not see the Helix.
Geekydaddy 13
Could the USB port on the Helix be fried ?
spikey 606
Did you happen to change the USB cable out?
Geekydaddy 13
Yes. Tried 3
Geekydaddy 13
Opened support ticket which prompted product registration which L6 site couldn't recognize Helix either.
phil_m 4,173
Is your Helix showing up in the Device Manager under the Control Panel?
If I want to use the editor on my PC, I have to start first the Helix then after the boot is finisht then I start up my PC
with the USB cable.connected. .(This is the right order for me)
When I first boot up my PC and then the Helix. with the USB cable connected, then the editor does not recognize the Helix.
this has always been with every FW update
Geekydaddy 13
No
This is often the best course of action on a Windows based machine. Always fun when "plug and play" isn't.
spikey 606
Is there anything else usb wise on this PC/OS not working as it was once, beside Helix?
If you have another item that is usb and its working now, move it to another usb port. If Windows sees and re-configures it again, then Im thinking Helix has a port issue (as you guessed earlier).
Geekydaddy 13
L6 updater doesn't recognize Helix. Nor does product registration on L6 site. tried different cables too.
Geekydaddy 13
No. Tried Helix on Asus laptop and have same issue
spikey 606
Sigh, well that smells to me like you burnt the beans. Id contact L6 support for an RMA to repair/replace, or if its new enough maybe the dealer might replace it?
Geekydaddy 13
But the beans..... LOL. Yeah Sweetwater will do an RMA but I have to drive several hrs to swing it. I live in the boonies :(
Want to make sure there is nothing else I can do.
phil_m 4,173
It certainly does sound like it could actually be a hardware issue with the Helix's USB port. The timing of it is kind of weird given the fact that it sounds like you just updated the firmware before this happened, but I suppose stranger things have happened.
1
Geekydaddy 13
Just worked with Sweetwater tech (on remote access) . Doing an RMA : - ( ::::::
aepoc 24
Did you try plugging into a different USB port on the computer?
nippyjun 22
Call Line 6 support and see if they have other options.
miguel_lopez 13
so, do you recomend update this new FW 2.01?
silverhead 8,530
V2.01 is primarily a bug-fix release. There's really no benefit in doing it unless you are bothered by any of the bugs listed in the release notes for the update. If you would like to benefit from any of those bugs being fixed there's really no reason not to do the update, assuming you follow the update instructions. While there are users who followed all instructions and still have subsequent difficulties their numbers are very small and the problems are usually unique.
For instance, while it remains to be confirmed the OP in this thread seems to have had the Helix USB port fail. That likely has nothing to do with the firmware update itself - just a faulty piece of hardware that suddenly failed. It would have failed soon enough even if the update had not been performed.
HonestOpinion 736
I am starting to wonder if some users are having problems with firmware updating because they start the Updater and update to the latest firmware version without first downloading and installing the latest "Helix" App which installs the latest Editor, Updater, and drivers. Can old versions of the Updater see the latest firmware version? For example, can a 2.0 version of the Updater see the 2.01 firmware update? If so this could explain where some folks are having problems after their firmware update, particularly when connected by USB or trying to use the Editor after the upgrade.
1
silverhead 8,530
I think you make a very good point. While the update instructions seem clear, the reference to downloading the Helix app/editor first could be missed by the user. What could also be confusing is that if you follow the installation instructions properly you don't actually have to download the firmware file that is linked to using the Get Download button at the bottom of the firmware download page. I expect some users read the instructions hastily, unnecessarily download the linked file and then immediately try to install it using the old Updater program. That WILL cause problems if there is a newer version of the Updater program that should be used.
Geekydaddy 13
The new updater and editor are loaded into the same download are they not?
They extract together and load separt shortcuts onto desktop. MAybe the 9/10 switch portion gets missed by some ?
silverhead 8,530
Yes, they are in the same download/installer. I'm sure the factory reset (9/10 switches) is missed by many who experience problems.
BigRalphN 70
Missed by some, ignored by others. I have seen people say they shouldn't have to restore presets every update and they don't do it.
Geekydaddy 13
Tech support emailed these instructions which were concise and may help others. My issue is the USB port on Helix. It is going back to SW.
Disconnect all of your Line 6 gear and close down all Line 6 programs.
Go to Start > Control Panel > Programs and Features > Line 6 Uninstaller
After you run the Line 6 Uninstaller, reboot your computer.
Go to Line6.com/software
Under -All Products- select Helix
Under -All Software select Drivers Under -All OS- make sure your operating system is selected Click GO Click GET DOWNLOAD Do not run it, just SAVE it
Go to your Downloads folder and find the drivers installer - Right click on it and select 'Run As Administrator'
Reboot your computer again after reinstalling the drivers
Go back to Line6.com/Software to download and re-install Line 6 Updater
Put your Helix into 'update mode' by holding down footswitches 6+12 while powering on, then connect to computer, Launch Updater and reinstall the flash memory.
HonestOpinion 736
So all of this adds up to NEVER just go to your existing version of the Updater and update to the latest firmware, it does not matter if you pull the new firmware down through the updater or download the "Flash Memory" directly from the Line6 downloads site. Remember, the "Flash Memory" download is not sufficient to do an upgrade, you need the "Helix" app. Just don't do it this way! Right now the proper procedure is always to first backup all your presets and IRs, then download the "Helix" app. Allow the "Helix" app to install the latest software, it will install the Editor, Updater, and any necessary driver(s). Only after completing this operation should you run the Updater and upgrade your firmware, either through the Updater download, or by downloading the "Flash Memory" from L6 and then pointing the Updater to it locally (the local file method may be preferred if you have a poor internet connection). After your new firmware is loaded, don't forget to do a global FS 9&10 reset. Now finally load your backed up presets and IRs. I recommend restarting your Helix one more time after loading your old presets just to be thorough. Don't forget to set your global options back to your favorite values as they have all been set back to their defaults. I have followed this sequence and never had one issue with a firmware upgrade.
For those who prefer checklists:
Helix Firmware Upgrade Instructions:
- Backup your presets and IRs. Backup your presets using "Export Setlist". You want to restore your setlists one by one as restoring a bundle will overwrite any new or changed factory presets in the new firmware. I always back up a bundle, two versions of each of my setlists, and all of my presets individually just to be on the safe side. Keep them around for a while in case you ever need to roll back to an old version of the software; they take up very little hard drive space.
- Never start a firmware update by using your current version of the Updater to update to the latest firmware version. Instead, download the latest "Helix" application, run it and let it install the latest version of the Editor, Updater, and driver(s).
- Now run the Updater. Follow all instructions in the firmware notes and upgrade to the latest version of the firmware. The firmware version should match the version of the "Helix" app you downloaded.
- Run the footswitch 9&10 global reset procedure.
- Restore your presets and IRs and restart the Helix one last time.
- Set your global settings back to your favorite settings, they have all been set to their defaults.
Guitarzman 21
Would there be a problems if I wanted to re-instal firmware 2.01 with a new laptop that has Windows 10 instead of windows 8...
Guitarzman 21
Or should i re-load firmware 2.00 first before 2.01..Please help line 6 staff Thanks
silverhead 8,530
You can load v2.01 directly - no need to go through v2.0. Windows 10 vs. 8 should make no difference.
Just make sure you follow the instructions as described on the Downloads page.
Guitarzman 21
Thanks so much for the help!!
